Question about Royal Office Equipment & Supplies
Need a part no. and where to purchase the part
Driven plastic gear is stripped where it engages motor
    Genius:
  • 1,218 Answers
For parts give Royal a call at 1-800-524-0799; ... they should be able to help.
Posted on Aug 22, 2010
Windows wont roll up or down
window regulator. no clue without looking at it if you have a cable driven one or a gear driven one though.
if cable driven, sounds like the cable has snapped. if gear driven (most likely) then the plastic gears inside the window motor on the regulator have finally worn and stripped out.
Jun 17, 2011 | 2002 Ford F350 Super Duty DRW Reg. Cab
Blades do not rotate, motor runs
Something is stripped. Most shredders are gear driven from the motor to the driver shaft and onto the driven shaft. Check that the motor has not come loose from its mountings, the drive gear has not come off the motor or the gear has stripped. You will have to split the shredder housings to do this.
Feb 22, 2011 | Fellowes Office Equipment & Supplies
Direction arrow does not work can it be replaced?
Maybe easily fixed... Take the head apart...just 3 or 4 screws up from the bottom. The direction arrow is "driven by a plastic gear that may have a "C" type ring holding the arrow and the gear together. The arrow sits on top of the gear like a car radio knob sits on its control shaft...with knurled splines. If either one is stripped or broken you'll have to purchase a new head housing...around $50-$60. Good Luck and God Bless
May 11, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
The fiber gear driven by thde motor is stripped.
Nearly impossible to find at a price that will make it worth it unless your planning to buy them in bulk from a distributor and do this type of repair often.
May 07, 2010 | Geha Primo 2700 (Cross-Cut) Shredder
My grass hog xp starts but the spool won't spin
This unit is supposedly the same as the GH700 drive system. There is a 5:1 plastic reduction gear inside the housing driven by a steel gear from the motor. It easily strips, melts, or simply breaks. The part is difficult to find. I have not found one yet for my situation.
Apr 19, 2010 | Black & Decker 14" Grass Hog Xp...
Model No MH6150MXQ - 0 Turn table will not
Hello- The motor has a plastic gear on the shaft that turns glass tray. These can crack or slip off the shaft and not engage the slots on tray. Check to see if gear is cracked or stripped. It may just be loose. Anyway, this part is less than 10$, so replace if it's bad. Let me know if this solves the problem. Have more info if needed-  Thanks- Ed
Mar 18, 2010 | Ovens
First plastic gear driven from motor pinion has
I have a simple solution if you can think outside of the box. When my gear stripped, I chucked away the electrics, and now drive the shredder via a crank handle on the side. It gives good excercise, and isn't difficult to turn with anything up to 6 or so sheets.
If you want to do this, open the machine, and remove the smaller gear at the opposite end of the drive (take off the circlip) to expose a hex shaped shaft. You can also chuck all of the electrics, and all but the two gears that are on the shredder shafts. Then cut a hole through both the top casing, and through the bucket, to line up with the shaft end and allow a 9/16 socket to pass through. When reassembled, there is sufficient room to drive the mechanism with a standard 3/8 drive ratchet, although you could make a fancier drive with a handle on.
Happy Days
Garry
Feb 05, 2010 | Fellowes P400C-2 Shredder
The headlight motor continues to run after the light has closed
I had this problem too. The problem is from a stripped plastic gear inside the motor housing. For some reason (poor engineering?) the motor keeps getting power even after the head light is closed. I purchased a new plastic gear and it only lasted me about 2 months. I recommend you check out the site below and purchase a metal gear. I did and my headlight is still working fine after a year.
http://www.bfranker.badz28.com/headlightfix/index.htm
Mar 07, 2009 | 1999 Pontiac Firebird
Speedo problems
I had the same problem. The speedo and the tacho are both stepper motors and the pointer is driven via a set of plastic gear wheels. The cogs strip and the stepper motor can not go past a cetrain point at which the pointer twitches. My solution was to strip out the console and swap the tacho and speedo gearing. If your are technically minded it is quite easy. If not, get somebody who is to do it for you. Good luck. Steve.
Jul 12, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Plate does not rotate freely and make noice
There is no belt in your model - the turntable is motor driven. The problem is either the motor itself or the coupling that engages the glass tray.
The motor (GE part # WB26X10038) is a very common failure as the internal gears are plastic and tend to strip.
You can view the motor at this link...
www.microwaveglasstrays.com
Jul 10, 2008 | GE JVM1650 1000 Watts Microwave Oven
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
