I have an old DVD/CD Receiver and need instructions on how to connect it to a Sony Trinitron television.
  • 12,061 Answers
Normally AV out to AV in. Usually it goes Yellow = Video in or out, Red & White = L/R Audio. They are wired with RCA plugs leads, color to color. Then select an Auxiliary input and press play on tape.
Posted on Feb 01, 2010
I have a new Yamaha AV receiver rx-v381,trying to connect an old CD DVD player, Sony dvp-nc665p. I have audio, no video. No HDMI on CD DVD player. What am I doing wrong? Help!
On my Yamaha AV receiver, DVD video (usually a yellow connector) passes through to a video output which then connects to the video input of the TV.
Feb 11, 2017 | Sony Audio Players & Recorders
I am experiencing a distortion noise in my sony ha21m80 when i connect a dvd or receiver in the av input
Difficult to tell without listening to it, but 2 things spring to mind.
Is the screening on the audio input cable OK?
Is the audio level going into the TV too high and thus overloading the input circuit?
Hope this helps,
Brian.
Jul 06, 2014 | Sony FD Trinitron WEGA KV-27FS320 27" TV
RCU410MS code for Sony Trinitron KV-27EXR15
get a SONY universal remote number RM-U302 it needs no codes just press the SONY item say in your case TV and the remote will self calibrate to your type
Jul 11, 2013 | Televison & Video
Sony Trinitron KD-28DL10U switched off suddenly to standby mid programme and won't come back on.When trying the remote on I can hear it click on and immedietly off again.Switched off at set and socket and...
Hello
In time as the Sony Trinitron ages it begins to have power issues. While this can be true of most tube televisions it's the rate and severity at which this happens to Trinitrons that makes it particularly of note. Many Trinitron owners have complained of the Trinitron set turning itself off randomly and frequently. Some sets have failed to stay on for longer than a few minutes at a time. Eventually some sets will not turn on at all. These problems grow more severe with age.
Check the power cable running from the Sony Trinitron 32. Make sure the cable is completely inserted into the power connection on the rear of the TV as well as the local power outlet.
Disconnect the power cable from the electrical outlet, then plug it into a different connection. It is possible to electrical outlet has died, forcing you to obtain a power current from a different source.
Check the cable connection running from the cable/satellite receiver or VCR. If the TV is on but no picture is on the screen, the problem is most likely due to a connection issue.
Power off the cable/satellite receiver, then press the "Video" button on the remote control to switch the Trinitron 32 to the video input signal. Turn on the cable/satellite receiver and the programming now loads onto the television screen.
Nov 21, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
No DVD Picture
When you say "Traditional Cables", are you referring to the red, white, and yellow cables?
Once you connected those from Cd/DVD to the receiver, did you then connect another yellow cable from the "monitor out" on the receiver, to an input on your television?
This is generally the step that people forget about.
The back of your receiver should have a "monitor" or "tv" output on it. You need to connect another yellow cable from *it* to an input on your TV, then turn your TV to that specific input.
That should do the trick.
Mar 25, 2009 | Yamaha RX-V463 Receiver
What to listen to radio, dvd movies and tv in surround sound
we bought a flat screen tv and now surround sound does not work with tv but will work with the radio on surround sound What is w
rong
Dec 17, 2008 | Audio Players & Recorders
How to connect new HD cable box to receiver
HI:
You are using a new HD Cable box, that are using componet video cables for HD, Unfortunetly this receiver does not have componet inputs, so you will just have to run the audio from the televison directly to the receiver by connecting the video out and audio out from the television to the receiver's video Input one. This will require a normal RCA composite cables yellow,red,white. Connect one end of each of the cables to televisions output terminals, and the other to the input one on the receiver. Note: Your TV might have a seperate term called Monitor out, Connect the yellow here, and the red and white to audio out. You can do the same for the DVD but you have to use the same cables,Also the television will not display HD picture this way as this is not a HDTV Receiver. If you just want TV sound to the receiver then do not use the video(Yellow) cable just use the audio out terminals from the tv and connect to Input one on the receiver. you can do this with the cable box also but you have to use RCA type cables . If you want the full HD experience then a new up todate receiver is necessary.
Dec 06, 2008 | Sony HT-DDW740 System
CONNECTING THE PANASONIC SC HT680 TO A SONY TRINITRON COLOR TV AND CABLE BOX
audio/video OUT from the cable box to the aux IN on the panasonic right? So you can see the output from the cable box but only sound from dvd. Are you changing the input on the tv when you go from watching the cable box to watching the DVD? the panasonic handles audio, but the video from each goes to two different inputs on the sony. I hope none of this sounds condescending.
Jan 27, 2008 | Panasonic SC-HT680 System
I want to connect HD cable signal to HD projector
not directly unless it says hdtv somewhere or you need a converter box.
Oct 21, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
