Can anything be done to make the monitor refresh faster?
  • 12,061 Answers
No.. it is not a changeable function.. The max refresh rate is exactly that. Some models can change from between 30-200HZ but even then this is automatic and depends on input signal.
Posted on Feb 01, 2010
Which tv doesn't exhibit motion blur?
You want high hz(hertz refresh rate). The higher the hz refresh rate, the better motion quality. 120 hz is typical for cheaper tv's, anything above that is good, the higher the better.
Jun 14, 2014 | Televison & Video
Please help.. my monitor has no display and my don't even beep. the LED in the monitor turns back to orange after few seconds. cpu, disk drives and ram are working..
This is one of the serious problem that arises because if you set your monitor with a high resolution with high frequency, then the monitor doesn't display anything as it's frequency is out of the rang or limit of the monitor's actual resolution capacity. Each monitor will have a limit of max frequency that is said to be the Refresh rate (for each and every resolution setting the display is refreshed.) When high resolution is set with high frequency that is not supported by the monitor, it then display a message like "frequency out of range". If you press ESC key within the few seconds of this setting, it will revert back to its initial resolution. But if you continued with the setting of same High resolution with High frequency, the monitor is not going to display anything because its frequency is out of the range. Most of old monitors like CRT's etc doesn't support 1024×768 at a refresh rate greater than 60Hz.
Jun 20, 2011 | Asrock P4I45GV R5 Motherboard
When I open game the monitor become black and show: Analogique shortcut 53.6 Khz/85 hz
Your resolution or screen refresh rate sounds like it is too high.
Try dropping your resolution to 1024 x 768 and see if the issue persists.
If it does then perhaps your game is trying to force you into a higher resolution output and faster screen refresh rate than your graphics card or your screen can handle.
Assuming that the graphic output is fine when your not playing this game and just using windows?
Thanks
Pete McDowell
Geek2Door Ltd
http://www.geek2door.com
Feb 15, 2010 | LG Flatron L1752TX 17" LCD Monitor
Flickers
I assume it is an LCD monitor, sounds like you have bad lamp or a lamp power supply. It also could be wrong refresh rate for the monitor, try changing the refresh rate on your computer.
Dec 19, 2009 | SVA-USA Computers & Internet
Monitor flickers and faint bands scroll down the
could be fixed by ajdusting the refresh rate....
you could try this (xp pro sp2)
please rate if useful, good luck
Open Display in Control Panel.
On the Settings tab, click Advanced.
On the Monitor tab, in the Refresh Frequency list, click a new refresh rate.
To open Display, click Start, click Control Panel, click Appearance and Themes, and then click Display.
  • The default refresh frequency setting is 100 Hertz, although your monitor may support a higher setting. Check your manufacturer's documentation for information regarding the settings your monitor supports.
  • A higher refresh frequency reduces any flicker on your screen, but choosing a setting that is too high for your monitor can make your display unusable and cause damage to your hardware.
  • Changes to the refresh frequency affect all users that log on to the computer.
Oct 27, 2009 | HP w1907 LCD Monitor
CTX P772 17" LCD Monitor Problem
This is caused by sending a video signal to the screen at a refresh rate higher than 60hz. A LCD Doesn't refresh the image by scanning from top to bottom like a traditional CRT or picture tube. They are hard set to 60hz and can not understand anything else. Setting it to anything else will cause it to not display a video signal, picture tearing (little blocks with horizontal movement), Offset video or convergents issues (colors appear offset giving it the 3d movie look with out glasses on)
To fix it you need to go into your operating systems display settings and pick out a LCD monitor with a refresh rate of 60hz
Hope that helps
May 12, 2008 | CTX P772 17" LCD Monitor
Daewoo computer monitor
You need to get your computer in the correct resolution and refresh rate to make the monitor work. It looks like the correct numbers for your monitor are:
Resolution: 1024x768 pixels
Refresh Rate: 60 hz
You can change these settings in the display tab or display properties (In XP - right click desktop, click properties, under settings tab adjust resolution and then click advanced, the monitor tab, and make sure refresh rate is set to 60 hz)
Mar 29, 2008 | Gateway FPD2275W LCD Monitor
Graphics card problems
Hi Jflynn,
I'm not convinced that this is an issue with a driver, but I have to ask whether you've downloaded the latest drivers for the nVidia card.
If not, go here to download them and see if that helps.
Ben
Mar 07, 2008 | Gateway FPD2275W LCD Monitor
Screen Distortion at certain Refresh Rates
Have you connected the laptop to another monitor and use the same refresh rates that cause the distortion? If the distortion appears on a different monitor, then I would have your laptop examined by a pc engineer, but, if the distortion only appears on the 997DF monitor, I suggest having the monitor checked at a repair shop, also, have you tried connecting the 997DF to a desktop PC, and use the same refresh rates?
Jun 16, 2007 | Samsung 997DF 19" CRT Monitor
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
