Question about Kenmore 84052 Dryer
Dryer timer not working Model#76812690 - Kenmore 84052 Dryer
  • 234 Answers
Ok, the dryer timer is not working......Would you like us to stop by and replace it for you ? You already know the problem, so, there is nothing for us to do. Either replace it yourself, or call a preofeesional,.///[
Posted on Jan 31, 2010
Hotpoint TVM572 timer is faulty
It is important not to open the door of the dryer if it is still running. The timer controls the cooling cycle otherwise the clothes will get damaged if kept on hot.
It is very likely the timer contacts are frozen at some point and the timer will need some attention.
It is not hard to locate it. I cannot find the actual parts drawing for your model (it is good you have provided the full model details). But to help you locate the part I have found another Hotpoint model that may be similar to yours. Check this drawing to see if the front panel is similar.
Item 100 is the timer.
HOTPOINT Electric Dryer Backsplash blower moto Parts Model NWSR483EB1WW
The actual timer for your model looks like this.
Hotpoint TVM572P Timer
As the clothes are not getting burnt or singed I will assume the thermostat is ok and keeping the temperature within the range.
Aug 07, 2014 | Hotpoint Dryers
Dryer not turning on.........before I would change the timer setting and it would would work.......after a couple of weeks, when i change the timer setting it wouldn't turn on at all. Question is
Definitely sounds like a timer problem. Sears Parts Direct should have your part. The model # you supplied is incomplete to determine if you have a gas or electric dryer. Check the model # again and go to Sears page to find the correct part.
May 08, 2012 | General Electric DBXR463EG Dryer
Kenmore gas dryer model 76812690 works perfect in timed cycle but will not advance timer and shut the dryer off in auto dry cycle. Vent is cleaned and it drys clothes but runs and does not advance timer...
Hi
I believe that everything else is fine rather it is the the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if bad replace it as it cannot be reset. If the fuse is fine then it can be due to the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jun 28, 2011 | Dryers
Model 76812690, Where on the back of the dryer is the thermal fuse located
Good day,
It is near the center toward the bottom...
It looks like this.
metal tabs pointing out.
Apr 28, 2011 | Kenmore Dryers
Dryer dries but the timer is not working on either the timing cycle or moisture cycle, what should I check?
nothing to check your timer is just bad,to look for a timer on line the model number is inside the dryer door and the part number is on the timer
May 02, 2010 | Kenmore 700 6972 Dryer
Kenmore Gas Dryer Serial Number: MF3920158
there is a heater on the back wall of the machine left hand corner there are also two relays on that same back wall and one on the blower you have to be able to take a wire off each relay and with a multimeter check each part for continuity if t hese are all good then do the same test on your heater. hope this helps
May 01, 2010 | Kenmore 73952 Gas Dryer
Kenmore Electric Dryer Model 110.6972110 timer motor NG
hi,
maybe call a generic appiance store other than sears, try maytag store. the knob pulls staight off and the timer nut is below. then take off the back cover off the control panel, sometimes those screws are on the front corners, sometimes hidden. take a picture of the timer wiring and tape and label all the wires before you remove it. unplug it first!!
jm
Nov 29, 2009 | Kenmore 62602 Electric Dryer
Trying to replace timer 8299771. Can't find my
On the new timer , you have 2 wires comming of the timer motor . The blue wire should go to one of these terminals on the timer itself . The place where there is ONLY a timer motor wire going to , is where it should go .
Sep 04, 2009 | Dryers
GE Dryer timer doesn't work
Replace the timer . If model number given , could give the part number .
Aug 09, 2009 | Kenmore 800 6983 Electric Dryer
Kenmore gas dryer model #76812690 will not heat.
does the dryer heat initially when you first turn on the dryer Or no heat at all?
the first thing i would check is tthe thermal fuse thats located on the back of the unit. test it with a multimeter and see if it has continuity, if it doesnt then replace that and your operating thermostat. the check to be sure you venting to the outside of your house is not clogged
Apr 29, 2009 | Kenmore Dryers
Kenmore 84052 Dryer Logo
82 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
