Question about PNY 4GB Secure Digital High Capacity Memory Card
My card works I can take pictures just can't read them from my computer... computer wants to format disk then computer won't format. I have pny sd hc 4gb memory card
    President:
  • 281 Answers
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Feb 03, 2010
I dont know if its the black berry or the sd card but it won't read on the computer or the phone. I tried to format it but how can you format something that cannot be read by both deivices? any...
look at page "3/9" of this document "http://www.pqi.com.tw/upload/download/SD%20%284%29.pdf" and it will show on the lower right hand side of the picture a slot that says "write protect", move that tab to unlock the card.
BTW this is a good technical document for SD cards in general if you are interested in how the function.
Sep 14, 2011 | PNY 2GB microSD Memory Card
Every time I put my camera's SD card into my HP Printer C3150, a red exclamation mark light blinks on and off, and the SD card does not appear on "My Computer," so I can't access my pictures....
I am not an expert on such matters. It is possible the printer won't read the SD card because it wasn't formatted before use or was formatted by a computer using 64 bit software instead of 32 bit.
You could try using a card reader and downloading the images to your computer and printing from there.
Aug 11, 2017 | Office Equipment & Supplies
I have been using my PNY OPTIMA HC 4gb memory card to upload pics for months and all of a sudden it will not read or allow me to upload
Solution overview: You need to "clean" theSD card by using the clean command in Diskpart and then format the card in DiskManagement. This solution will show you how to accomplish this.
1. Plug the SD Card into the computer.
2. Press Win+R to open the Run command.
3. Type "cmd" into the dialog box and press enter to open acommand prompt.
4. Type "Diskpart" into the command line of the command promptto start Diskpart. Wait for Diskpart to load.
5. Type "List Disk" and press enter.
6. Take note of the number of the disk that's associated with your SD card.
7. Type "Select Disk X" where X = the number of the diskthat's associated with your SD card and press enter. Make sure the commandprompt reports that Disk X is selected.
8. Type "Clean" or "Clean all" and pressenter. Clean will be faster but might not solve your problem. If using theclean command doesn't solve your problem, then repeat steps 1-8 and type "Cleanall".
9. Wait for Diskpart to complete the cleaning operation - this may take sometime so wait until it's completed!
10. Close command prompt.
11. Press Win+R to open the Run command.
12. Type "DISKMGMT.MSC" into the dialog box and press enter.Wait for Disk Manager to load.
13. In Disk Manager, scroll down and select the SD Card.
14. Right click and select "New Simple Volume".
15. Select Next, Assign Drive Letter, and select "Next" again.
16. Select "FAT32" for File System and "Default"for Allocation Unit Size. Fill in whatever you want for the Volume Label. Makesure "Perform quick format" is checked and click OK.
17. Wait for formatting to complete and remove SD card from computer.
18. Plug SD card into camera to see if the problem is solved.
Good luck and thanks for using FixYa. Post back if you have any questions orproblems.
Mar 15, 2011 | PNY 4GB Secure Digital High Capacity...
PNY micro small piece inserted in mobile phone and adapter to the computer, but not copy mobile phone pictures to the computer.
for reliability buy a dedicated micro sd reader as not all the adapters work.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Mar 01, 2011 | PNY 2GB microSD Memory Card
I am trying to download a WMA Audiobook from the library site Wilbur, but it says that my PNY USB 2.0 FD USB device is incompatible
if it doesn t read your card. Its because the computer or labtop can not read HC high capacity cards. it will read a 1 GB or 2 GB but anything above will not be read. check on card if it has HC you need new hardware or a regular sd card.
Mar 29, 2010 | PNY 4GB Secure Digital High Capacity...
PNY optima SD HC 4GB card will not read
Try putting a tiny piece of scotch tape over the lock slider. See if that works.
Dec 29, 2009 | PNY 4GB Secure Digital High Capacity...
I'm useing the pny optima sd/hc 60 hd 4gb scan disk! it has photos on it useing the camera,nikon coolpixl20. using nikon transfer does not load pictures on computer.
I had same problem. Neither computer nor printer would recognize the SDcard. I took the card to Walgreen's and the card was read just fine. I suspect that we are running XP and do not have the right driver; but I can't seem to find the right driver. Morgen
Dec 07, 2009 | Nikon COOLPIX L10 Digital Camera
I have a 4gb micro sd card and it says that it only has a total of 146k of space on the disk. It won't let me copy anything on it. And i haven't placed anything on it-so i don't know why its out of space.
Is it a 4Gb micro sdHC? The 4 GB and above are all HC (High Capacity), and can only be read by HC reading devices. If you can see them at all, they will report some foolish size which yours is doing. They use a different protocal so they can not be read by a reader which is not HC. So what you need to do is get a HC capable reader.
Jun 28, 2009 | PNY 2GB microSD Memory Card
PNY Optima SD HC 8GB isnt working on laptop
Youll have to get updates for your laptop card reader or get a new one which may have to be installed. Another method you may want to try would be to put the card back into the device you used it in and then hook the device up to the computer, most likely through the USB slot....good luck
Jun 05, 2009 | PNY Optima Pro 2GB Secure Digital Memory...
Unable to read card
you act white go to the store and raise **** and say you sold me junk
Jun 20, 2008 | PNY 2GB microSD Memory Card
PNY 4GB Secure Digital High Capacity Memory Card Logo
611 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
