Question about Dishwashers
When draining water out of the sink, it backflows into the dishwasher. Doesn't the dishwasher have a backflow preventer valve where the drain tube connects to it?
  • 5 Answers
Actually no they do not have a back flow preventer, make sure the dishwasher drain connection is installed on top of the "P" trap, if it is then you are having drain problems , remove and clean the "P" trap if it not clodded then you need your pipes cleaned out if it is backing up in dishwasher.. Do it sooner than later or may become totally stopped up..
Posted on Feb 01, 2010
Can backflow mounted to sink be moved under sink?
Hi Del:
I'm not sure what you mean by "backflow".
How is this related to your dishwasher?
The discharge from the dishwasher has to be connected to the drain from the sink, upstream of the trap that protects the sink.
A hand sprayer is typically integrated with the sink faucet.
Reply as a COMMENT to this post to discuss.
Cheers
Mar 09, 2016 | Kenmore Dishwashers
I want to install an RO unit. For the RO faucet connection I would like to use the air gap connection on the sink that connects to my GLD5960 SS dishwasher. Can I get rid of the air gap connection from...
The airgap prevents the water from the sink backflowing into the dishwasher. You could espically if your dishwasher hasa corragated plastic drain hose attach it under the sink so at one point the hose is higher that the nozzle of the disposer it connects to so the hose is still higher that the level of the nozzle and water wont backfill into the dishwasher.
Gene
Aug 09, 2011 | GE Dishwashers
Questions about snaking the drain line for a Bosch SHU5305. Should I be able to snake all the way from the sink connection into the dishwasher or is there some type of backflow prevention or something...
I would NOT recommend you snake into your dishwasher because you could damage the drain pump.
If you think you have blockage, then take the unit out and disconnect the drain line and take it outside and use a hose on it.
Just remember to disconnect the power first.
Jul 16, 2011 | Dishwashers
Some water from when the 20 yr old garbage disposal is used ends up at bottom of our Meile dishwasher. problem with the dishwasher backflow preventer ? or with disposal itself?
Your drain hose should be secured up inside the cabinet at a level higher than the base of the sink to prevent water from going from the disposer back into the dishwasher. There is a anti back-up valve in most dishwashers, but they are not totally effective against water from the sink coming back into the machine.
Get yourself some bread ties and get that hose up as high as you can under the sink so that it comes out of the disposer, goes up, and then back down to the dishwasher. This will also prevent crud from getting accumulated at the end of the drain hose where it connects.
Oct 07, 2010 | Miele Dishwashers
WHEN I RUN MY SINK IT DRAINS INTO MY DISHWASHER BOTTOM. I HAVE SNAKED THE HOLE AND IT STILL FILLS THE BOTTOM THEN I RUN IT EMPTY THEN FILL AND RUN AGAIN. HELP
The dishwasher drain line that connects to the garbage disposal or pipe under the sink should be looped above the height of disposal or pipe to prevent
sink water from backflowing into dishwasher.
Most dishwashers have some form of internal backflow preventer inside the water sump assy..
Yours may be degraded or stuck open.
Jan 16, 2010 | Dishwashers
Dishes smell like wet dog hair when cycle ends
There is a product called " Dishwasher Magic " to clean, deodorize, and disinfect dishwashers. Hardware, appliance parts, and possibly grocery stores should carry it. It comes in a rectangular 12 once bottle.
Also, check to see that the drain hose loops up higher than the outlet into the drain so no water will run back into your dishwasher from the drain or disposer.
Jun 08, 2009 | GE Nautilus 24" Built-in Dishwasher
Unit shuts down in middle od wash
I highly doubt a clogged sink drain would cause any damage to the dishwasher. Any backpressure would be relieved by pushing drain water up and into the sink(s).
Sounds like just a coincidence...although very suspicious, I agree.
May 07, 2009 | Dishwashers
Water in top drawer
I am not a repairman but have installed several duel drawer dishwashers. Most dishwashers have a check valve preventing backflow. Water under pressure will always follow the path of least resistance and in your case it is going into the upper drawer. Be sure the drain is open and flowing easily under your sink whether that be the disposal or a TEE. It may help if the drain line is elevated as high as it can go under the sink just before it reaches the drain. How often do you use the top drawer? Perhaps run a cycle on the hottest cycle without dishes to attemt to clean or force through any contaminants in the check valve through into the drain. Hope this helps, Ken
May 01, 2009 | KitchenAid 23 in. KUDD01DPPA Stainless...
Drains Technical Question
Plumbing codes call for a gap between potable water and a drain. This usually looks like the distance between the faucet and the top of the sink or bathtub (one inch or more). Without the "gap", waste water could siphon back into the drinking supply. This "does" happen in situations where a city main is shut off causing a drain-down of the system with plumbing that has been done improperly. Sometimes it is a hose left in a mud puddle, or maybe a hose lying in bleach water. People have died this way. The plumbing code helps protect the general public from these dangers. Current improvements include antisiphon faucets for garden hoses, the air gap for the dishwasher, proper installation of water heater T&P relief drains, and backflow preventers for irrigation systems.
Aug 27, 2008 | Elkay LK58 Drain
Dishwashers Logo
140 people viewed this question
Top Dishwashers Experts
Owen Barnes
