I have my iPod on the dock, the light is on but it's asking me to check iPod connection
  • 5,807 Answers
If there is no label such as
Made for Ipod it wont ( for Samsung )
sample only
Posted on Jan 31, 2010
  • Rommel Cana
    Rommel Cana Jan 31, 2010
    post the Ipod Dock model that you are using same with the TV
    Although sometimes they are not compatible.
Checking ipod connection
Check the pins on the inside of the Ipod and the dock. It could be making contact with the power pins but not the send receive pins. Small pin will help you bend these out gently to make contact again.
May 01, 2014 | Panasonic SC-HC271 iPod Dock/CD Player...
Tip
How to connect an iPod to my Bose Radio
<p>The manufacturer offers two radios Bose iPod connection kit to connect an iPod to the radio. You can purchase the kit to connect the wave or acoustic wave connect kit. Both kits come with a USB audio connection, an iPod dock for iPod, a battery that plugs into the wall and a remote control to use the iPod while in dock. Download all the upgrades to your iPod through Apple's website before connecting a Bose radio. <br /> <p><br /> <p>1. Connect one end of the audio cable is included with the connection kit for iPod "Aux In" on the back of the Bose radio. <br /> <p><br /> <p>2. Connect the other end of the audio cable to the "Audio Out" on the back of the iPod dock. <br /> <p><br /> <p>3. Connect the adapter to an outlet connection kit. Connect the other end of the battery to the "DC Power" on the back of the iPod dock. <br /> <p><br /> <p>4. Set the iPod dock on the right side of the face of Bose radio out. Align the IR sensor on the front of the iPod dock with the IR sensor on the front of the Bose radio. <br /> <p><br /> <p>5. Place the iPod firmly in iPod dock. Point the remote at the IR sensor, iPod dock. Press the "iPod" for the iPod <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How to connect an my iPod Nano 3rd Generation to an iHome
<p>Your iPod nano to a device like the iHome to boost output audio or video to a TV in your memory. The iHome also charge your phone as it is docked. You need to take steps to ensure that your iPod will be able to successfully dock the iHome. Once your iPod is well prepared, so you get the most out of your drive for iHome. <br /> <p><br /> <p>1. Connect your iPod to your computer and launch iTunes. <br /> <p><br /> <p>2. Click "Help" from within iTunes, click "Check for Updates". <br /> <p><br /> <p>3. Select "Yes" when asked if you want to download and install updates. If no updates are available, disconnect the iPod. <br /> <p><br /> <p>4. IHome Connect your unit to an AC outlet. <br /> <p><br /> <p>5. Remove the protective layer of your iPod Nano, if applicable. <br /> <p><br /> <p>6. Let the iPod Nano in the dock with the front facing you. You will feel it snap into place. <br />
on Jul 21, 2011 | Computers & Internet
Denon ipod dock 'no connection' problem
Double check the 'dock control' connection. On the dock and receiver to ensure it's plugged in nice and tight.
Feb 18, 2010 | Denon ASD-11R iPod Docking Station...
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
Tip
How To Connect Your iPhone, iPad, or iPod To The TV
The following devices have support for TV out:
  • iPhone
  • iPad
  • iPod touch
  • iPod nano (3rd generation and later)
  • iPod classic, iPod (5th generation), and iPod photo
Note: Other iPod models may support viewing of photos or slideshows on the iPod display but do not support TV out.
The following docks support TV out when used with an iPod model or iPhone that supports TV out:
  • Apple Universal Dock (requires either the Apple Composite AV Cable or the Apple Component AV Cable-will not work with the iPod AV Cable). Search the store for part number MB125G.
  • iPod Universal Dock or iPod with color display dock (iPod photo dock)
Important: The iPhone dock does not support TV out.
iPod models that support TV out can support viewing on a television in several ways. Use the tables below to see which cables and docks can be used with each iPod model. Check the documentation that came with the cable or iPod for information on how to connect and enable TV out.
Note: If you choose to use a third-party cable, make sure it has the "Works with iPhone" or "Made for iPod" label. Learn more about iPod and iPhone accessories.
All you need to get TV out is a compatible iPhone, iPad, or iPod and the correct cable. If your device works with the component and composite cables, then the choice depends on the TV(s) you will be connecting to.
  • Apple Composite AV Cable (part number MB129LL) will connect any iPhone, iPad, or iPod to your TV using RCA Cables.
  • Apple Component AV Cable (part number MB128LL) will connect any iPhone, iPad, or iPod (except iPod with color display (iPod photo), and iPod (5th generation)) to your TV using Component Cables.
A dock can be a welcome addition if you're going to keep your cables connected to the TV. The Apple Universal Dock includes an Apple Remote so you can pause and adjust the volume from a distance. The docks and cables are sold separately.
on Feb 21, 2011 | Apple iPhone Smartphone
Need to connect my ipod to the receiver.
You can do this a couple of ways, depending on the model of iPod.
1. Almost every iPod has an 1/8" earphone jack. Almost every Receiver has RCA input jacks. At Radio Shack, or any store with an electronics section, ask them for an cable with the 1/8" earphone plug on one end and stereo RCA jacks on the other.
Plug the RCA jacks into the receiver, taking note of the name of the input (Aux, iPod, Tape, etc) and plug the other end into the iPod. Set your receiver for the input you're connected to and press Play on your iPod. Enjoy music.
2. From the Apple Store, or any iPod dealer, purchase an iPod Dock for your particular model. Ask the same friendly folks for an audio connection cable and do the same as above for the Receiver end. On the iPod end, just set the iPod into the dock and press Play.
Jul 26, 2009 | Audio Players & Recorders
Ipod 4th gen "charging not supported"
It does that to my iPhone; if I want to charge I have to use a separate cable and run the audio into the aux. Defeats the whole purpose of a dock if you ask me, but I guess they never anticipated what they'd have to do to charge the new iPhone batteries back when they designed the pre-G3-phone docks.
May 25, 2009 | Buck Klipsch iGroove Docking Station,...
PHILLIPS HTD 7001 IPOD DOCKING STATION
I also have the same problem but now I think it's the type of I-Pod you use. Do you use the I-Pod 80 Gb video or the newer 160 Gb I-Pod with the cover flow etc. ? The documention of the HTD7001 says it's only support some I-Pods. I would know sure if I would have a type of Video I Pod wich is supported by the documentation
May 31, 2008 | Bose 3 2 1 Series I DVD Home Entertainment...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
