Question about Samsung DLP HL-P5663W 56" TV
The problem I am having with my samsung tv is it has just recently started to make a hissing sound that I can only describe as the noise of a gas leak ...the pic etc is ok only having problems with sound ,, can you help me
  • Samsung Master
  • 12,061 Answers
This is a High Tension "Leak" this is a frequent occurance, it is the High Voltage drive to the screen that causes it. really you should have it looked at by a professional serviceman get a firm "Quote" for any fix before you proceed.
Posted on Feb 01, 2010
Samsung tv blank screen
It,s shot, Get a new tv,End make shure not to get a samsung,
Nov 03, 2012 | Samsung Televison & Video
I have a Samsung HLT5076SX/XAA with power up to picture problems.
Im going to guess that you have crackling and hissing noises, as well as the infamous "click" then nothing when you try to start the tv. This is caused by circuit failure on the main board, which powers up the main inverter to charge the screen. ( a high voltage thing that makes the picture come on) when the board cannot provide a high enough starting voltage, the symptoms you described start happening. It is not an easy fix, and will probably set you back a couple hundred dollars or so to fix. I hope the best for you
Jun 09, 2012 | Samsung Televison & Video
Hi i have a gsxr 400 gk76a and the bike is sounding louder which i know is the exhuast its blowing but a hissing noise is coming from the engine is this normal. the bike is also strugling sometimes to idle...
The hissing is not normal. What you describe sounds like a head gasket going bad. As to the idle problem, clean the carbs. Leave the floats alone; the carbs are not over-flowing and the cylinders are getting gas. The floats do not get balancing, they work properly or they don't.
Jun 02, 2011 | Suzuki GSX-R 750 H Motorcycles
Kp 61HS30 TV Had the tv since 2002. been a great tv. Just recently it started making a noise when you turn it on. Noise fades away after about 10 seconds. Noise kind of sounds like a dvd player trying...
If you locate the audio board, check for dried up electrolytic capacitors and dry joints around the output IC itself.
That should fix your fault.
Nov 27, 2010 | Sony KP-61HS30 TV
Our tv is Samsung DLP HL-P4663W 46 in. Rear Projection HDTV-Ready Television After having our TV on for about 45 minutes it starts to make this hissing sound which starts low and gets louder and louder,...
hello
This looks like a colorwheel symptom, does the sound is like a mechanical sound? high pitch sound? winding, whirling or screeching noise ? well if this is the color wheel, what i think it is, it seems that it is not working properly when this happens the DMD board recognizes that it is not spinning at the correct RPM and turns off the Tv for sercurity reasons, so if you want to replace this yourself what i recommend you to do is to open the back of the Tv and search for the colorwheel it can have missing parts or it could be shattered or it could not spin correcty, hope this info. can help you.
Jun 14, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
TV Turns Off Automatically While Watching
Stop trying to turn on the set. You are causing more damage. The hissing sound you are hearing is either a High Voltage Transformer on the SMPS (Switched Mode Power Supply) indicating a short somewhere in the set or some capicitors that have shorted out. Also there can be a CRT that is leaking cooling fluid onto the Main bd or the Power/Deflection bd or both bds. Have a trained Samsung tech troubleshoot the set.
Jul 15, 2009 | Samsung HCM4215W 42" Rear Projection...
I recently hooked up my dtv box, tuned the antenna and have a great picture. On every channel I have background noise. Sounds like bacon frying, hissing noise. I also set up someone else's tv, very simple....
If there is a volume control on the remote that came with the converter box, use it to make sure the box volume is set to its maximum. Many models allow you to control the volume out from the box to the TV, and the levels are set about halfway. When you turn up the volume on the TV cause it's too low, you can get the kind of audio problem you describe. Make sure you turn the volume down on the TV first before starting with the box.
Feb 18, 2009 | Directv (R10) DTV Receiver / 70-Hours...
Samsung LW32A23W LCD TV
check out for sound module, the noise filtering system of the module is bad .replace it
Oct 11, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Car wont start
It sounds like the timing belt snaps based on the hissing sound that you described............if it cranks lightly without much load then it is confirmed the timing belt has snapped.
Oct 05, 2008 | 1991 Honda Accord
Buzzing sound
You haven't specified where the buzzing sound is coming from, if it is coming from speakers, changing capacitors in the audio section will fix the problem, especially the filters. Now if it sounds like a hissing sound from back of the tv, the CRT base socket is the culprit. It is an easy thing to fix, and the base is cheap, but make sure you purchase the exact same type of base or it will harm the CRT. Good luck.
Jan 22, 2008 | Samsung TXN2775HF 27" TV
Samsung DLP HL-P5663W 56" TV Logo
282 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
