Question about Maytag Dishwashers
A maytag mjd 2000 aaw dishwasher doesn't heat the water and also stops pumping through the cycle
3 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: A maytag mjd 2000 aaw
Hi and welcome to FixYa, I am Kelly
Most of the time when you start having dirty dishes post wash there is either an internal blocked screen under the lower wash arm tower or a problem with the drain. The drain problem shows up mostly inside the Air-Gap cap or at the garbage disposal / sink port connection. Pull the cap / cover off of the Air-Gap and then NOTE the installed position of the inner cap. Unscrew the cap nut and lift the cap off of the Air-Gap assembly. Food particles block the drain inside the cap. You should see a blockage as soon as you lift the cap or the particulate falls away as you lift the cap. Look into the Air-Gap with a flash light and clear any debris. Re-install all Air-Gap parts after cleaning. Make sure to pull the hose off of the garbage disposal port and clean the port.
Add water via cycle fill and then test the drain cycle. The dishwasher should be empty in less than 90 seconds. After 90 seconds interrupt the drain cycle. There should NOT be standing water in the dishwasher sump. If you have standing water in the sump after 90 seconds you will have to remove the lower wash arm and tower to clean the screen or drain holes in the tower. (depending on modeL) Another thing to pay attention to is exactly HOW the lower wash arm is installed on the tower. Some of the 2 part lower wash arms can be a nightmare to re-assemble.
When in doubt take pictures first.... (Lesson learned the hard way too many times when a 30 minute job goes in to the 2nd hour on my time!) Just make sure you do NOT remove any motor pump mounting hardware where it mates to the tub base. Even loosening a motor pump bolt or screw can cause a leak after your done.
While the lower wash arm is removed make sure that you inspect and clean the inside of the wash arm. Often food particles can block the water spray holes in the wash arm.
IF you have a direct / no Air-Gap sink connection then pull off the hose at the sink connection and clear the connection hole of any debris.
I really think that your have a drain problem vs a motor pump issue. It is possible that there is an impeller issue but at this point I doubt it.
Should you have to gain access to the internal screen of the dishwasher you will need to view this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=28553&diagram_id=28395680#d28395680
Items I, 2, 3, 4, and 5 of the link will need to be removed then inspect the screen for signs of debris build up. Again.. lets hope it does not get to the parts removal point. IF you do have to tear into the sump it is best to go down to the chopper place (Item 20 of link) and make sure the holes are not clogged. What ever happens unless your going to replace the impeller do not remove it or any seals. If you do you have a 50 - 50 chance of having a leak straight into the motor. Once removed it is best to replace both of the stem seals (Items 23 and 24).
One last thing to look for is clogged upper spray arm water holes. Just inspect for signs of blockage. Only remove it if you note food particulate in the holes.
I am speaking from many many years of in home appliance repair experience. The steps above should stop the dirty post wash dishes. If you still have the same issues after checking the above, please respond and I will help you.
Thanks for choosing FixYa,
Kelly
Posted on Jan 09, 2011
MJD2000AAW and MJD3000AAW have problems with the main control panel PCB. This manifests is lots of differing symptoms: Cycle won't complete; won't pump out; no heating works on some cycles then fails; no dispensing cleaner; runs thru cycle but does nothing except fill in water; code E3......etc
Not all these happen at the same time and the faults can be intermittent and varied.
It is not the drain because if you start a new cycle the 1st thing it does is pump out any water ok. So the pump works and so the drain is ok.
It is the control PCB ~ $200 assy. This has failed twice on my Maytag MJD2000AAW with same symptoms. Once replaced by service man once by me. It aoppears to be the micro controller not giving the correct signals at the correct time sequence.
Both times replacing PCB assy fixed problems ~2 years then fails....never never buy Maytag again because of this. Obviously the factory knows of this issue.
Posted on Mar 04, 2013
Maytag Model # MD87609AWB3 after rinse cycle it stops. I have to push button to finish drying cycle
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 24, 2011 | Maytag Dishwashers
We have a Matage dishwasher Model MJD.3000AAW. There is an error message: E4. What do we need to do?
Hi, the E4 error means the water heater element does not work properly or the filter mesh is blocked. Most likely the heating element burned out/thermal fuse or Clean the filter mesh to resolve the problem.
Jun 22, 2011 | Maytag Dishwasher
Maytag jetclean Model number MJD 3000 AAW Problem : E3 error towards end of cycle
Cause: The water heater element does not work properly or the filter mesh is blocked.
Remedy: Clean the filter mesh and if the problem continues, the main board needs to be replaced.
The Filter mesh in the bottom of the appliance.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 14, 2011 | Dishwashers
A maytag mjd 2000 aaw dishwasher doesn't heat the water and also leaves about 1/2 inch of water in the bottom, at the end of the cycle. Disshes are celaned though.
Kelly
Jan 09, 2011 | Maytag Dishwashers
Maytag mjd 2005 when started on normal gives a once-every-two-seconds "wash". Seems to pump out some water each time. When turned off and on again 'normal' button lights and the same thing happens. Will...
I have the same problem but now on all cycles - to get it off normal and try the other ones, open the door, hold down the 'normal' button for three seconds, and then at least try the other settings temporarily.
Mar 30, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Maytag DWU6602AAE. My Maytag dishwasher (14 years
SOUNDS LIKE A TIMER PROBLEM. YOU MAY WANT TO PRICE A REPLACEMENT TIMER. AND PRICE OUT NEW DISHWASHERS. GOOD LUCK!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Feb 25, 2010 | Dishwashers
I am looking for an instruction guide booklet
sorry but my sites arent finding a model mjd2000aaw. www.maytag there is section for cumsumer support wher eyou can download your manual with model info
Dec 02, 2008 | Maytag Dishwashers
Ignis dishwasher 2yrs old
your pump might be full of grit, and filters also, clean them out.
Oct 26, 2007 | Maytag 24 in. MDB9150A Built-in Dishwasher
Maytag mjd 2005dishwasher
Try what my wife does. She uses the individually contained detergent/rinse bubble packs (tab packs). No messy granular detergent and easy to simply place inside the silverware basket. Your dishes should wash spotless, like ours. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | Maytag 24 in. MDB9750AW Dishwasher
Dishwashers Logo
192 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
