Question about K40 Vehicle Parts & Accessories
How do you set a k40 roadcase plus slip seat box?
Where is Mercedes SL500 03 Driver side fuse box number written?.
Fuse Terminal Cable ID (fused) Fused function Rating in amperes (A) F1 30 - Wiper park position heater relay (K40/2kA) F2 30 - High pressure and return flow pump relay (K40/2kF) F3 30 - Steering column forward/back adjustment relay 1 (K40/2kD)
Steering column forward/back adjustment relay 2 (K40/2kE) F4 30 - Steering column height adjustment relay 1 (K40/2kI)
Steering column height adjustment relay 2 (K40/2kJ) F5 15R - Wiper On and Off relay (K40/2kH) F8 30 RD 0.75 Central gateway control unit (N93) F9 30 PKWH 2.5 Left door control unit (N69/1) F10 15 BKVT 0.75
BKVT 0.75
BKVT 0.75 Left front headlamp unit (E1)
Right front headlamp unit (E2)
Xenon headlamp control unit (E1n1, E2n2) 15 RDGN 0.75 Restraint systems control unit (N2/7) F11 15R BKYE 1.0 Circuit 15R/30 cutoff relay (K75) F12 15R - Spare F13 30 RDGN 1.5 ABC control unit (N51/2) F14 15R BKGN 0.75 Windshield washer fluid pump (M5/1) F15 30 RDGN 1.0 Data link connector (X11/4) F16 15R PKYE 1.0 Valid for code (855) TELE AID:
D2B telephone and TELE AID transmitter/receiver (A35/17) 15R PKYE 1.0 Valid for code (853) MB standard telephone:
D2B telephone transmitter/receiver (A35/13) F17 15R RDYE 0.5 Vehicle-sensitive seat belt lock sensor (A60) F18 15R - Spare F19 15 BKYE 1.00 Valid for engines 112.973, 113.963/992:
Fused via circuit 15 connector sleeve (Z3/29):
Cylinder 1 ignition coil (T1/1)
Cylinder 2 ignition coil (T1/2)
Cylinder 3 ignition coil (T1/3)
Cylinder 4 ignition coil (T1/4)
Cylinder 5 ignition coil (T1/5)
Cylinder 6 ignition coil (T1/6)
Cylinder 7 ignition coil (T1/7)
Cylinder 8 ignition coil (T1/8) F20 15 BKGN 0.75 Data link connector (X11/4) F21 15R BKYE 0.5 Instrument cluster (A1) F22 30 RDYE 0.5 Instrument cluster (A1) F23 30 RDWH 1.0
RDWH 1.0 AAC [KLA] control and operating unit (N22)
Coolant circulation pump (M13) F24 30 RDWH 0.5 Stop lamp switch (S9/1) F25 30 RDYE 0.75 Alarm signal horn (H3) F26 30 RDBU 0.5 Lower control panel control unit (N72) F27 30 RDVT 2.5 Left front seat adjustment control unit with memory (N32/1)
Apr 22, 2015 | 2003 Mercedes-Benz SL-Class
How to set the swr on a conex 3300 hp to a k40 top load fire stick
google this ," How do I set the SWR on my radio". you will be suprised at what you find.
Aug 26, 2014 | Radio Communications
1 mile range on cb
Check cables and connectors.
• check antenna SWR,
A good SWR ranges from 1.2 to 1.5.
• check power output.
Jul 27, 2012 | Connex Cx-366ce Night Runner 40ch Cb...
My K40 unit keeps beeping 2X every 10 seconds or so.. It still goes off when radar is present but it wont stop beeping. any insights would be helpful
You have a K402000 radar system. The double beep is a rear receiver disconnect notification. If you go to the K40 website and access their dealer locator from the dealer section, you can find an authorized dealer to help you with this problem or you can call K40 directly and speak to them...they really are a great company to deal with.
Aug 20, 2011 | Calibre Radar Detector
I have a pickup with a fiberglass bed cover, inside is a Cobra 29. When the k40 antenna is on the bedcover (magnetic mount w/ 6x6 inch metal plate glued to the bedcover) radio will give me an antenna...
Well, the k40 is designed for roof or trunk mount,you would not be getting a good ground,plus you would be getting feed back from cab,no good transmit or receive. Get a good 102" fiberglass or steel whip that's bumper mount,mount it on right rear bumper and you will be good to go.
Mar 28, 2010 | Radio Communications
My unit will not come off the mute setting and how can I find out about any upgrades to my unit?
Call K40 847-888-7200
They are cool and let me talk to an engineer. They should be able to answer any questions you have.
Dec 01, 2009 | Calibre Radar Detector
Remote does not connect with unit built into car. does not go on
First, the K40 Calibre isn't a terribly good radar/laser defense system no matter what K40 claims. I would rate its radar detection capabilities as fair, and its laser jamming capabilities as poor. But on to your problem. Call K40 and see if they can talk you through any specific procedures which they have. It appears that your Bluetooth remote and the RD are not properly synced. Its best if K40 talks you through the resolution.
Mar 15, 2009 | Calibre Radar Detector
Vehicle Parts & Accessories Logo
303 people viewed this question
Top K40 Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a K40 Vehicle Part and Accessory Expert? Answer questions, earn points and help others
