I have a 42" vizio television. I have a digital cable converter box and a DVD/DVDR player hooked to it. The cable box is going into component 2 and the DVD is going to av2. We were watching the television and all of a sudden the Input menu started coming up and scrolling on its own. Then the television appeared to be searching for channels. I cut it off and waited a couple of minutes. Tried to turn it back on with the catv remote but it would not work. Tried to turn it on with the vizio remote and still no go. I was able to manually turn the set on. When it came back all it was was a blue screen with a "no input" flashing on the screen. I then turned it off and hooked the cable line directly to it. Turned it on manually and changed the input to tv. Still said "no input". I manually placed it on av1 and the DVD Player works just fine. Whats up?
  • jcp60 Jan 31, 2010
    The television is approximately 1 year old, it is a VIZIO VW42L HDTV10A
    This is the first time i have had an isue with this set.
  • 4,472 Answers
This is definitely sounding like an internal problem with the television. First off how long have you owned the set and how long have you had this problem? Do you have the exact model number?
Once I have more information I can assist you further.
Thank you,
Lee
Posted on Jan 31, 2010
  • Lee A.
    Lee A. Jan 31, 2010
    Is the unit less then a year old? If so it is covered under manufacturers warranty and you would want to contact them immediately.
    http://www.vizio.com/support/
    Thank you,
    Lee
Can't change to channel 3 to use the dvd player
Your Vizio TV should have provisions on the rear panel for direct connection of your DVD player. Use those connections and select your DVD player as a video input.
Mar 08, 2018 | Vizio 42 in. LCD TV
Blew out HDMI on Vizio 42
Please go for a multiple selection switch box.
Aug 19, 2012 | Vizio 42 in. LCD TV
I hook up my tv cable to the Component 1, and it works
make sure you are using component video red green blue cables for video and not just the yellow composite video cable not sure if this helps you but good luck
Nov 30, 2009 | Insignia 42" Flat-Panel Plasma HDTV
I have a Vizio P42HDTV10A with a Bose 321 system and no sound
Check you cables. make sure that the Dish Box is hooked up and if you are run'n your cables from the Dish Box to the DVD player then you will have to keep the player on.
Use to work for DirecTV i got this all the time
Aug 25, 2009 | Vizio GV42L 42 in. LCD Television
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
How do I get sound on my Vizio SV420XVT 42 Great picture but no sound
I had the same problem. I could get an analog audio signal but no digitial signal. My problem was with the cable box setting. I have Cox Cable. With the Cable remote I went to settings/settings/Audio out and selected HDMI. Worked like a charm
Oct 19, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
I have a Philips Model DVDR 3505/37 recorder. I recently hooked up a RCA analog to digital converter to the TV and to the DVD. Now it will not record. No error messages. Just no recording. Thanks
The Philips DVDR 3505/37 has a built-in analog to Digital converter. No additional converter is needed. Just do the scan for over the air channels and set to go. Works fine now.
robert2792@sbcglobal.net
Apr 28, 2008 | Philips Televison & Video
Recording from cable dvr
You have to hook up an AV cable from the box to the DVDR.. Out on the cable box to IN on the DVD player.
Then put your DVD player on AV1 - ( you can do this by pressing the INPUT SEL button on the DVDR remote)
Then put the Cable box on whatever channel you want to record. And press the record button on the DVDR and you will record whatever channel the cable box is on
If you can't get to AV1 then you have to disable cable box control (menu>setup>system>cable box control>off
Jan 12, 2008 | Samsung DVD-VR357
No audio output hooked up to my Vizio 37" LCD
You need to select digital out in the menu of the dvd player..
Jan 01, 2008 | Nakamichi DVD-10S
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
