Question about Samsung BD-P1000
Lenz only comes out part way and needs a gental push to get it back when switching off or the lenz motor just keeps on running.
Sorry was a samsung p1000 camera
Posted on Feb 01, 2010
How do I wire a cutler hammer a10ago for 115 volt
I'm going to take a guess and say you are dropping a 230v motor down to a 115v motor.
If the original motor on your equipment was 3 phase, then you need to change motors.
On the other hand, if the equipment had a 230v single phase and you are switching the motor wires so you can plug the equipment into an available 115v outlet, then I would suggest reconsidering. I would recommend running a 220v service line to your equipment instead. It will save on your electric bill and the motor will last longer. A 115v motor pulls twice as much amperage as the same motor running on 230v. (it may even be too much for the 115v outlet you are planing on using) Your variable rate electric meter will tell your power company to up the rate you pay per kilowatt-hour when you use power at a lower voltage but higher amperage rate.
That said, you need to make sure that the coil in your fancy starter switch is a 115v coil. (it probably is) When you hook up the 115v plug, you need to make sure that the black wire in the Starter Switch is the wire that the switch borrows power from to kick start the magnet that keeps the circuit closed. Beyond that , you probably don't have to do anything in the switch. If there's a red wire, you can just disconnect it and tape it off and do the same in the plug.
If the a10ago's function is a mystery, it will help to understand how it works:
Basically, the contactor has three switches side by side. Where the power comes into the box, there's what looks like a lot of extra screws. That's where the thermal protector is (circuit breaker) that will protect your motor at the proper level designed for the motor. The switch has a spring that holds it open so the motor won't run. But there's an electro magnet that can hold the circuit closed. That magnet is only energized when the switch is closed because even though one of its leads is connected to the hot side of the switch, the other lead is connected past the contactor which has no power when the switch is off.
Your 'START' push button momentarily energizes the coil (or maybe it just overpowers the spring and physically pushes the switch closed). The switch closes and the motor runs and keeps running because the coil is energized. Your 'STOP' button momentarily cuts current to the coil and the switch pops open.
The purpose of this contraption is:
1. It contains a circuit breaker suited for just the motor that is running, not for every load on the circuit.
2. It has contacts that will wear much longer than a standard switch.
3. If your shop loses power with the motor running and then the power comes back on later, your motor wont start running by itself. It will wait until you press the 'START' button.
Oct 09, 2014 | Saws
My cam does seam to zoom right
Check the settings. If that's not it one of the lenzes might have been nudged/pushed in or out a bit. If that's not it you may just have a lenze that was cut wrong...maibe some one replaced it with the wrong lenz.
Sep 06, 2011 | Vivitar Video Cameras
My camera samsung lenz keep saing CARD LOCKED when I turn it on
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Apr 16, 2010 | Samsung L100 Digital Camera
We need user manual of Lenze ac 7800 ., if any one could help us with the same ., contact on nmbabrakar@yahoo.com
http://src.lenze.com/lenze-bibliothek/Lenze-Archiv/AA%20-%20Inverter%20Drives/7xxx/TB_7811-7818_EN.pdf
Mar 13, 2010 | Lenze AC Tech Lenze 8100 AC Drive Inverter
How do u wire a three phase squirrel cage motor with a motor starter with a remote start/stop/inch station and warning indicator light ?
You would first run a conductor fromL1 to L1 on the motor start then run a second conductor from L2 to L2 on the moter starter, then run a third conductor from L3 to L3 on the moter starter. next run L1 and L2 to a step down transformer so you can reduce your working voltage to 120vac, then run a conductor on one of the outputs from the step down transformer to one side of the normally closed contacts on the STOP push button, from the other side of the stop button run a wire to one side of the start button, on the other side of the start push button run a wire to one side of the magnetic motor starter coil, the other side of the coil run a wire to the other empty terminal on the transformer, this will be the neutral wire. next you need to run a wire from the normally open contactor on the magnetic moter starter to one side of your push button start switch, then run one wire from the other side of the start push button switch to the other side of the normally open contacts on the magnetic moter starter, this is your start switch latch that will keep the motor running when the start push button is released.I'm not sure how you need the warning indicator light wired up, so please reply and let me know when it needs to come on and go off
Feb 04, 2010 | Delta TP300 Shopmaster 12-Inch Portable...
The push to start switch needs to be held down for the dryer to work
Good day,
When you push the start switch, power is sent to the motor directly.
When released the centrifugal switch mounted on the motor has another electrical path to that power wire, and keeps it running.
The switch has failed.
With complete model number, you can call to see if you can buy only the switch, but more likely you'll have to replace the motor.
Sorry about that.
Jack....
Dec 04, 2009 | Kenmore Dryers
Ppc 6670
You just need the touch screen (digitizer). There are actually 2 pieces that are mistaken to be the screen. The other piece is the touch screen and beneath that is the LCD display. Be certain to order the correct piece.
To replace, you need a micro phillips head screw driver and a T-6 torx screw driver. Also patience, and a steady hand.
You must start at the back of the device, through the battery door. Remove the 2 micro phillips at the top of the battery opening (one is covered with a tamper evidence sticker). Then carefully, starting at the bottom of the camera plate, pry upwards and to the speaker to unsnap the smaller facing. Remove the camera by gentally pulling up to unplug, then unscrew the circuitry and remove. This will expose the 4 torxs (2 in batt opening) to remove the back cover. After screws are removed, gentally work the covers snaps loose around perimeter and remove (pay attention to the speaker wire) unplug it from the circuitboard. Pull the antenna nub to detach.
Remove the screws holding the circuitboard, unpluging the keyboard and slider ribbon cable. Gentally hold the ribbon cable and remove the securing tape. (dont pull too hard!) Pulling the circuitboard exposes the 4 micro phillips screws (2 each side) to detach the slider.
Remove the 4 torx screws on the back of the LCD slider, then gentally pry around to separate the housing.
To remove the LCD / Touch screen you must unplug the ribbon cables. To do this you need to open the connector's trap (black bar). It hinges. Just pry upwards from the ribbon side. Once bar is lifted ribbon will slide out. Be careful if you need to remove the gold foil tape. Remove the single screw holding the ear speaker, and the ribbon should come out. The screen will not come out after gentally prying it free of the holding snaps in the casing.
Installation is simply the reserve. Hope this helps....
Jul 03, 2008 | Audiovox PPC 6700
Roper REX4634KQ
That should be just a push to start switch. The start switch is inside the motor. When the motor turns fast enough it trips an internal switch to keep the motor running. It sounds like you have a motor on the way out.
Apr 24, 2008 | Roper REX4634KQ Electric Dryer
Scratched audiovox screen
You just need the touch screen (digitizer). There are actually 2 pieces that are mistaken to be the screen. The other piece is the touch screen and beneath that is the LCD display. The outer scratched screen is the touch screen.
Ebay, and various online retailers have them for around $40. You can do it yourself if you try.
Dec 07, 2007 | Audiovox PPC 6700
Samsung BD-P1000 Logo
100 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
