Question about Sony KP-51HW40 51" Rear Projection Television
I get two images one red and the other is blue and white
  • smathan1 Jan 31, 2010
    are these expensive to replace
  • 10,594 Answers
This double picture is due to failure of convergence out chips in your Sony tv. Replace convergence out chips to fix this picture issue.
Let me know if you are handy with electronics stuff repair and can solder parts in circuit board with proper tools to provide you more technical info like part numbers etc.
Or local tech will help you to get tv fixed.
Thanks.
Posted on Jan 31, 2010
  • Shahid Electronics
    Shahid Electronics Jan 31, 2010
    If your tv is Sony KP-51HW40 then it needs STK392-560 quantity-2
    Available in Part Store for $38
Picture for Wii game is in black and white only.
What type of cables are you using? My presumption is that you're using Component Video Cables - Red, Green, Blue for video, Red & White for audio.
If one of the 3 video cables is mixed up or poorly connected, you could see a Black & White image on the screen. I suggest double checking your cables for tightness and correct color attachment. Also be sure the red video is not mixed with the red audio cable. The red audio cable is marginally thinner and probably physically attached to the white audio cable.
May 05, 2011 | Nintendo Wii Console
I see no red and green colors on screen projected by pjtx 100, the rest of the colors are visible.
If you are using a component video cable (Red, Green, Blue) you may simply be missing the Red cable. It may not be fully plugged in.
You can verify that this is the case by: 1. Unplugging all video cables 2. Plug in the green cable, you should see a black and white image. 3. Plug in the blue cable, you should see some colours coming through. 4. Plug in the red cable, you should see all colours properly.
If not, unplug the blue and red cables and plug the blue cable into the red port. The colours will look incorrect, skin tones will be blue. If the colour comes through the problem is the cable. If the colour does not come through, the problem may be the projector.
Feb 28, 2011 | Hitachi PJTX100 Multimedia Projector
How do you align the colors?
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT buttons to move a red frame pointer to
IMAGE ADJUST Menu icon.
Press POINT DOWN button to move a red frame pointer to the
item that you want to adjust. and then press SELECT button.
The level of each item is displayed. Adjust each level by
pressing POINT LEFT/RIGHT button(s).
Move a red frame pointer to
the item to be selected and
IMAGE ADJUST MENU
IMAGE LEVEL ADJUSTMENT
Press POINT LEFT button to decrease contrast, and POINT RIGHT
button to increase contrast. (From 0 to 63.)
Press POINT LEFT button to adjust image darker, and POINT
RIGHT button to adjust brighter. (From 0 to 63.)
Contrast
Brightness
Press either POINT LEFT button or POINT RIGHT button to obtain
better balance of contrast. (From 0 to 15.)
Gamma
To store manually preset image, move a red frame pointer to
Store icon and press SELECT button. Image Level Menu will
appear. Move a red frame pointer to the Image 1 to 4 where you
want to set and then press SELECT button.
Image Level Menu
Move a red frame pointer to any
of Image 1 to 4 where you want
button.
Store icon
Press SELECT button at this icon to
store the adjustment.
IMAGE ADJUST
Menu icon
Press POINT LEFT button to lighten red tone and POINT RIGHT
button to deeper tone. (From 0 to 63.)
White balance (Red)
Press POINT LEFT button to lighten green tone and POINT RIGHT
White balance (Green)
Press POINT LEFT button to lighten blue tone and POINT RIGHT
White
Jan 22, 2011 | Sanyo PLC XU35 Multimedia Projector
The yellow blue and green.. which one is video plug?
What you have is a component cable. By the sound of the cable it seems like you might have this kind:
http://www.componentcable.net/images/Component%20Cable%20PS3.jpg
The Yellow / Blue / Green / Red cables are all meant for video. The back/side of your display will either have matching colors, or it will just have a yellow, white, red. You want to plug in the Blue, Green, and Red cables. If your display doesn't have this, it's not capable of component video, in which case you will want to plug in the Yellow / White / Red into the AV slots.
Dec 26, 2010 | Dynex DX-LCD32-09 LCD TV
Tv color turning green
could be a couple of things. 1 the convergence is messed up, go throught the set up and make sure the blue and red "+" are aligned to create a white image, If using component input make sure the red is to the red the blue is to the blue, try different cables for the components blue and red. Try S-video or Composite, if the problem persists, check the menu to ensure all the colors are set even, if the problem still persists,then you may have a blown projection gun.
Oct 01, 2009 | Televison & Video
From the furnace what are the blue, white, green, red wires
here's a link to a wiring diagram which is pretty standard.
http://ingramswaterandair.com/images/HCD1%20AC%20Models%20Installation%20Manual.pdf
Color what it does terminal
Blue 24V common C
White to heat control (gas valve) W
Green manual fan operation G
Red 24V power to thermostat R
Yellow activates comp during cooling Y
Sep 27, 2009 | Bryant 462AJC021BA Air Conditioner
Red shadow to left of main image InFocus LP750
You have to open the LP750 and check the alignment of your color lenses. You might be needed to adjust, also check your lamp too.
Jul 23, 2009 | InFocus LP 750 Multimedia Projector
Sony KP-51HW40 51" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
