My 1998 GE washer was spinning off balance, i went to shut it off but it stopped spinning and now wont spin anymore in spin cycle
  • 12,061 Answers
Sounds like the balance weights come off, and when this happens there is a switch that get tripped to stop it destroying itself, problem must be remedied before it will restart
Posted on Feb 01, 2010
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
The spin cycle on my GE Profile Harmony washer has gone violent, what can cause this?
probably unbalance load inside, try to stop, move what's inside and restart, or maybe there is not enough inside and cannot balance ( one heavy item, add some item so it can balance them when spinning )
Nov 29, 2014 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Banging drum when spinning
if the drum in the washer klunks/bangs in ANY brand of washer when it is spinning, your load is off balance. stop the machine, re-distribute the wet clothes so that the weight is evenly distributed, then restar the spin. u may have to do this more than once if u did not evely distribute the weight. this is an easy one. just be sure to stop the spin soon as it starts banging. letting it bang thru an entire spin cycle could result in actual damage to the machine. some of the new machines auto shut off at an imbalance so u can correct the problem. think of spinning a top. u unevenly add weights to it then spin it again, it WILL wobble.
Feb 22, 2014 | GE G.e. Gtwn4950lws He Top Load Washer
Washer spins than it gets off balance and shuts
Hi, Washing machines can become unbalanced when the wash load has too much weight in one area of the basket. A machine in good working order can handle most problems through its balancing mechanisms. However, when washing heavy single items such as comforters, the machine's tub can become so lopsided that it damages the washer.
Washing machines that get unbalanced can shake, make banging noises, and even more across the floor. When machines are secured in one place, they can vibrate and bang so much the entire house shakes and things fall off shelves. This is not good for the washer. Bolts can come loose, and parts can break.
When washing heavy items such as pillows or down coats, stay near the washer so you can correct any balance problems as they occur. Some washers have an automatic shut-off feature when they become too far off-balance. If yours does not, stop the spin cycle, open the lid, and redistribute the load. If this is a continuing problem, you may want to wash heavy items at a coin-operated laundry in a heavy-duty machine.
Take care
Jul 14, 2010 | Whirlpool Washing Machines
Wont spin
Yes you will find a belt under the bottom of the machine. Check out first that it did not just over balance and cut out while spinning if so you will need to hit the reset buttonand check out spin cycle. Hope this helps
May 25, 2010 | GE WDSR2080D Top Load Washer
GE profile top loader, agitator and spin start and stop
Is this a newer model washer? I have one of the newer models and it does the same thing. It is supposed to do that.
May 23, 2017 | GE Profile Prodigy WPSE4200A
Washing machine shuts off before cycle is finished now it will not last one min. on before it shuts off...what to do?
We have a front-loading LG washer. Today, I took a look at it when it was beginning the spin cycle because it sounded a bit different. I noticed that it was beginning to spin and would stop because [I believe] it was detecting a strong off-balance. It would then try to spin in the opposite direction and the same happened. After two more attempts, it automatically shut off with no warning nor error. We set the washer to wash and spin again and I began to work on balancing it. After adjusting the feet and waiting for the spin cycle again, it continued successfully because of the reduced off-balance. I'm not sure if there are other reasons that would cause the washer to turn off. This is the only one I have come across so far.
Oct 22, 2009 | LG WM1812C Front Load Washer
Washer stops several times in the middle of cycle
possibly it could be your un-balance switch getting very sensitive to any type of movement of the machine, normally they only actuate during the spin cycle when you have a very off balanced load of clothes
Oct 03, 2009 | GE Profile Prodigy WPSE4200A
Kenmore 80 series washer stopped during unbalanced spin cycle
lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
Apr 29, 2008 | Kenmore 20172 Top Load Washer
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
