Question about Minn Kota Riptide St Saltwater 55 Bow Mount Trolling Motor
What guage wire do we use when going from trolling motor to battery?
  • 122 Answers
6 guage
Posted on Jan 31, 2010
    New Friend:
  • 32 Answers
Determine the amps of the motor. 14 gauge wire handles up to 15 amps. 12 gauge wire handles up to 20 amps. Not sure of the amps for 16 gauge or 18 gauge wire. Ehow may answer that. Stranded wire is more flexible (Workable).
Posted on May 27, 2013
My motorguide trolling motor keeps tripping the 50 amp in line breaker every time I turn it on high speed. It is a 75 lb thrust digital tour model. When I take it out of the water and run it on high...
All motors will draw higher amperage with varying loads. Your hi speed motor winding has probably shorted some its winding's without having gone to ground. It probably needs to be replaced to get your hi speed back. I have run into similar problems in heavy commercial hydronic pumps. Best to have mechanic check it out. An OHM test with factory specs. will tell for sure.
Sep 04, 2013 | Electrical Supplies
How do you wire the swithch when there is a starting battery and 2 trolling motor batteries?
The switc his designed for only two batteries. You could parallel the two trolling motor batteries and put their leads under one terminal on the switch, but any time the switch was in that position, both batteries would be feeding the trolling motor load at the same time.
In any case, always connect the starting motor to it's own terminal. You want to keep that battery seperated from the trolling motor load so that you do not run down your starting battery.
Aug 19, 2011 | Perko Battery Selector Switches Ignition...
What size wire should i use from battery to motor - bought a plug at bass pro for motor and wired with inline fuse of 15amps but keeps blowing fuse - wire i am using is typical auto wire (don't know guage)...
The new cost of your motor is nearly 1000 dollars, presumably there are comprehensive instructions on installation to minimise the risk of damage which could be very expensive. In particular damage to the motor control circuits due to incorrect fusing.
Do yourself a favour and contact the manufacturers directly
http://www.minnkotamotors.com/service/contact.aspx
regards
Mar 01, 2011 | Minn Kota Riptide Sp Saltwater 70 Bow...
Have 12 V bow mount trolling motor that doesn't start working until power is on for about 5 minutes. Then when it does start, have to have the power on 10 just to keep the prop moving. Checked prop and...
Hello, You have several points to check. #1 check your wiring connections--- plug, plug socket, wiring connections internal of trolling motor, condition of wiring to battery, battery terminal connection & charge of battery. #2 borrow someones DVM (digital multimeter) and check the resistance of the speed control as you turn it without any wires connected to it. #3 if problem not found take 2 aspirin and E-mail me of test results "for further review".
Sep 18, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Old outboard ground wire melting
1. Short in the trolling motor itself
2. TOO SMALL a ground wire. ..need at least 8 gauge wire!!!!
3. Bad/dirty/corroded battery connections
..Make sure your battery/trolling motor is not accidentally touching the metal boat.. DO NOT CONNECT ANY WIRES TO THE BOAT!!! - PERIOD!!.
Sep 11, 2017 | Minn Kota Maxxum 70 Freshwater Bow Mount...
24 volt trolling motor wiring
Just like a flashlight. Positive to neg, In a loop going to the motor. That is the jump between the batteries, One red wire coming in from motor, it will go to pos, from one battery, the neg will go to the 2nd battery pos. From the 2nd battery neg will go to the motor. That is it, one jumper connecting the 2 batteries, will create the 24 volts. Hope this helps.
Mar 22, 2010 | Boating
I just bought a 74 lb Minn Kota trolling motor that is 24 volt. It is used and has 4 wires (2 black & 2 red) coming from rolling motor. Can you please tell me how the wiring is connected to the...
I have uploaded a image of the wire system. folllow it carefully. the fuses rating should be no more than than thirty amp. go to your local outboard dealer they sell inline breakers that are designed for trolling motors. i prefer them because you don't have to replace them after a overload. you just reset the breaker.de79e02.jpg
Oct 29, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
Burning out fuses on trolling motor at battery
not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
Oct 29, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
I have a minn kota 48 AT 12/24 volt bow mount that I run on a two battery 24 volt setup. The trolling motor is on a 3 prong plug into a panel at the front of my boat. That panel has an on/off/on toggle...
use a volt meter and check for voltage at the plug, if none..check in the back near your batterys and locate the circuit breaker and reset it ...basic system = battery-breaker-wires....hope this helps ....GL
Jul 05, 2009 | Boating
I have a great white 67 lb thrust trolling motor . I can run it at 1/2 to 3/4 power and it will run for a while but when you go to full power it will shut off and you have wait a while before it kicks back...
Sounds like it's heating up. Check your wire size. For 24 volt: 6 guage wire is reccommended - that's pretty heavy. Also check the wiring of your batteries. It's easy to get mixed up if you have 24 or 36 volt system. One more thing...check the fuse size to make sure that is correct. Hope this helps. Brian
Apr 24, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Minn Kota Riptide St Saltwater 55 Bow Mount Trolling Motor Logo
13,207 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
