Question about GE Dryers
GE Dryer DDG7580B does not heat. vents are clear, dryer tumbles, just no gas ignition. Other gas appliances working well. Help!
Replace the ceramic ignitor WE4X444. An easy fix. Nut is on the gas valve (not the line) to remove the burner assembly to replace the ignitor.
Good luck..
Posted on Nov 03, 2011
We have a GE gas dryer model ddg7580b. We've been out of our house since hurricane Sandy. We has tree damage - no water damage. We're just back in. The plumber re-opened the gas line and opened the...
If you remove the access panel at the bottom front of the dryer, you can see whether the igniter is working. A plumber might not check operation of your appliance but an appliance repair tech probably would. You can disconnect the vent and probe it to detect any debris.
Oct 30, 2013 | GE Dryers
Ge profile dryer how do you get to the burner? ge profile dryer tumbles but no heat what is wrong?
Since you have a gas dryer, your problem is probably caused by the ingition panel.Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty.If this helps solve your problem, please come back to Fixya and rate my advice.
Jul 26, 2011 | GE Profile DPSB620GCWW Gas Dryer
The dryer tumbles however there is no heat. I have checked the venting, the gas line and the internal vent...also the settings. When I remove the rear venting hose, I smell gas. Led to believe that the...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jun 17, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Dryer has no heat. Tested some of the fuses and they test good. Is there a way to test the igniter with a multimeter?
have you checked the dryer vent that goes through the outside wall sometimes the outlet gets clogged up with lint and the heat will recirculate instead of venting outside, the recirculation somestimes tell the dryer sensor that the clothes are dry and will stop sending heat to the dryer or very little heat clear the vent and see if that helps also check the pipe at the bottom of the dryer they sometimes clog up as well if no sucess call a gas appliance repair service you do not want to fool aroud with gas appliances re igniters or where burners are concerned
Jan 09, 2010 | Whirlpool LGR5636L Gas Dryer
There is no heat but the cycle runs it's normal time and stops when time runs out.
I have provided the following checklists for both gas and electric dryers; courtesy of www.repairclinic.com. They also provide repair parts, disassembly instructions and diagrams to help assist repairing your dryer.
Firstly, ascertain that you have made a positive heat selection, then read on.
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric Dryer Checklist:
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Gas Dryer checklist:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Jul 14, 2009 | Dryers
My GE dryer is tumbling & heating but not drying.
there may be heat but if your heating element is not working properly it will heat some but will not dry cloths
Nov 15, 2008 | GE DBL333EA Electric Dryer
Heat and clean vent, but way too long to dry
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE';
Aug 22, 2008 | Whirlpool LGR7646E Dryer
Initial gas burn does not reignite
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's no heat
It won't tumble
Drying is too slow
It overheats
It's noisy
It won't start
Hope this may help;
DON'T FORGET TO RATE;
Jul 26, 2008 | Whirlpool LGR7646E Dryer
No heat from gas dryer
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Here are some things to look for:
Igniter
Gas valve coils
Thermal fuse
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 09, 2008 | Whirlpool LGR7648KQ Dryer
Dryers Logo
113 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
