Question about Samsung Computers & Internet
Samsung model 931b 19
How do i get a digital picture on my monitor ? all i get is analog. evidentally,my dell 2400 series computer hard drive has only one recepticle for plugging in the monitor
  • Quentin Packard
    Quentin Packard Jan 22, 2009
    My monitor is analog and fuzzy, how can I get digital mode?
    xp home sp3
    diamond radeon x1050
    dual monitors:
    Samsung syncmaster 730b
    Comaq FP17
Hello fixya team, i was searching thru your posting and came across a posting by grapemaster on january 11,2008. his problem was identical to mine. a "best solution",posted on 16 january stated he had to connect a digital imput sourse (such as a HDMI. i will pursue this approach and let you know the results. thans for your response! freebee
Posted on Feb 19, 2008
My syncmaster 933 flashes on and off then frequently the digital and analog word flashes out on screen and the auto adjustment
  1. asdasdasdadadaddddasdsssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssspaotin
Jan 05, 2011 | Samsung SyncMaster 931B 19" LCD Monitor
When starting computer in the morning, the monitor display flashes analog then digital then back to analog and goes blank. Power to the monitor is on. Multiple on/off of power brings display back.
Hi, 12fixlouie here. LCD monitor may have intermittant solder joint on power supply board inside unit. May only need you to resolder it to fix. Locating it is a whole other problem in itself!!! If not into monitor "teardown" and all the other stuff that you will need to attempt a repair, then let me know right away. 12fixlouie
Sep 14, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
931b flashes on &off
You need to open it up and look for caps with bulging tops. Common problem with ALL brand of monitors.
http://s807.photobucket.com/home/budm/allalbums
http://www.axtsystems.com/index.php?option=com_content&view=article&id=83:samsung931bfix&catid=48:fixingstuff&Itemid=81
Please post back what you find so it will help other people also. Use good caps, PANASONIC FM or FC series from DIGIKEY.
Apr 07, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
I have a Samsung 931b 19" LCD monitor that flickers on and off. I can here the monitor "click" on, the colors and picture are perfect when it flashes on, but it's blacking in and out repeatedly. Please...
This 2001 model year, more likely to have bad caps with bulging top or leaking liquid in the power supply section, that is the first place to look. The problem can also be in the backlight inverter circuits or bad lamps also, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Feb 28, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Screen blinks on /off - can syncmaster 931b be repaired?
This model was released in 2001, you need to open it up and look for bad caps with bulging top first, the problem can also be in the backlight inverter circuits. Post back what you see so we can guide you further, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 27, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
I am using Ubuntu 9.10 in a dual-boot config with XP. I have a Samsung Synchmaster 931B monitor in analog mode. Works fine and drivers installed under XP, but will not support extended effects under...
it's your graphics card not the monitor that often has proprietary drivers to drive compiz and other effects.
If this is not a laptop, then it is easy to interchange.
Nvidia is one such vendor that supplies special drivers for Ubuntu
Jan 29, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
No picture
Can u tell me, are u using analog signal or digital as it has two signal connector.
Ok, i can suggest you for both.
If you use digital then here it is,
Here are the complete instruction for you.
so, if you feel any trouble, ask me.
Jan 16, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Samsung 931B SyncmMaster
DO YOU MEAN WONT SWITCH FROM ANALOG TO DIGITAL!!!
THE ONLY WAY THIS WILL CHANGE IS IF YOU HAVE A DIGITAL INPUT SOURCE CONNECTED to this mointor like HDMI AS THIS MOINTOR AUTOMATICALLY SENSES ANALOG SIGNALS AND DIGITAL INPUT SIGNALS if a digital signal is available it will switch over if a digital input singal is not available you will only be able to use the analog option
Jan 11, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Computers & Internet Logo
100 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
