Question about Coffee Makers & Espresso Machines
I have a klix 450 vending machine works fine but not heating water
My tricity bendix fridge freezer just stopped working. The power is ok as the inner light in the fridge is working.Its 10years + old Any ideas as to what the problem may be.Thanks
Here is something to try before you scrap it out.
Get down to the bottom of the freezer and find the compressor.
With the unit plugged in, find the "klix-on" which is mounted on the side of the compressor, and is about the size of your fist.
That is 2 parts-in-one, by the way.
Try to find the word "Klix-on" on one of the two pieces which are together.
Tap the klix-on with a small hammer a few times and see if the compressor kicks on.
If it does, replace the klix-on.
I bought one at my appliance parts store for $ 38.
God bless your efforts.
Dec 05, 2016 | Tricity Bendix Washing Machines
Tip
Vending Machine Supplier
About Us : <br>Upton vending A largest vending machines company in UK, that provides wide range of vending machines in North Yorkshire at affordable rates,well known for customer satisfaction.Our best services are <b><a href="http://www.uptonvending.co.uk">vending machine companies</a></b>,vending machine, snack vending machine, drink vending machine,commercial coffee machines in UK..<br>Contact Us : <br>The Vivars<br>Selby<br>North Yorkshire<br>YO8 8BE<br>Tel: 0 1757 629112<br>Fax: 01757 294600
on Aug 17, 2013 | Nu-Dell Manufacturing Vending Machines Ad...
Why are front three selections vending two cans?
There is an adjustment for the length of the cans. The columns that are not working properly have too much slack. Open it up and look behind the cans. There is a metal plate with spring loaded clips, top and bottom. Squeeze them together and move the plate forward to take out the slack. Do it top and bottom. When properly adjusted the cans will move a little (1/4 to 1/2 inch).
Apr 01, 2016 | Selectivend CB300 Satellite Ice Water Cold...
Repair vending machine
it means you have to source the error codes for this machine
Jul 10, 2014 | Coffee Makers & Espresso Machines
The vending on my maytag skybox stopped working
What do the led's do when you try to dispense a product?
May 05, 2014 | Maytag SkyBox MBV1976A Beverage Dispenser
Rowe 4900 snack machine vend motor good won't vend selection
Is it just that selection, or is it the entire shelf? If you've got a voltmeter check the lines in to see that it's actually feeding power to the motor, as it could be loose/misconfigured wiring. If that doesn't work, and it's possible, try using a known functional motor in that selection. If it works, you've got a bad motor to replace, if it doesn't work it might go back to the main board. I'm not terribly familiar with Rowe equipment, but with most snack units it's just a matter of switching things around until you've found the bad part or other problem- good luck!
Nov 05, 2013 | vendors equipment Rowe 4900 Vend Motor for...
Reset machine. Is keypad operational. Check all plugs for good connection. Check that price is correct for the selection. Price all selections again.
Yurg2
Vending machine issues
Only the fan at the compressor turns on and off with the compressor cycle. The evaporator fan runs steady to maintain air circulation and temperature balance and to affect evaporator defrost in the off cycle. Sometimes the condenser fan will run continuously to assist in the evaporation of condensed moisture from the evaporator drainage.
May 30, 2008 | Koolatron (785169015699)
Coffee Makers & Espresso Machines Logo
127 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
