Question about Braun Syncro 7505 Electric Shaver
Shaver not charging.
I have a Brain Syncro 7505 shaver that I replaced the battery in and still isn't working. I checked to make sure my solders are good and I've even taken the batteries out and switched them around to make sure I had the right polarity. The lights are showing that it is charging and the batteries are warm to the touch like they are charging but I just can't get it to run. Any thoughts?
  • johntrambaug Feb 01, 2010
    Yup, that was it. Thanks for the link too. And to think I used to work for remington replacing batteries in all brands of shavers. Hopefully I do better on my laptop and drill battery repairs.
  • Braun Master
  • 1,621 Answers
The batteries should not really get warm. You may not have a good solder connection
Assuming that the batteries are in correctly with good solder joints, the problem is likely the motor. With the shaver fully assembled, remove just the foil and cutter and then turn the unit on. Use your finger to push the piece of plastic that the cutter fits into back and forth. If it starts and moves slowly or if it stutters, the brushes in the moto are probably bad. Because the motor is a sealer unit, the motor will need replaced. If you require this part, you will find it at shaveroutlet.com. See link below.
http://shaveroutlet.com/braun-7000-series-syncro-motor-drive-unit-p-110.html
Posted on Jan 31, 2010
Testimonial: "You are the man."
The top will not stay down for charging
This is a common problem with the clean/charge base for model 7526. The mechanism inside is broken. You can replace the upper housing that includes the locking arm or you can replace the whole system. Both options are available at shaveroutlet.com. See links below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
Sep 22, 2011 | Braun Syncro 7526 Electric Shaver
I need a new battery for this razor. I know its replaceable, but where dose it go and how do you get the cover off?
You will find the correct battery type for model 7505 at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
You will need two batteries. Scroll down the item page for videos showing disassembly and installation tips
Jun 21, 2011 | Braun Syncro 7505 Electric Shaver
Braun 7505 switch won't slide down to off position. battery has to run down to stop. What can I do?
Guest solution (2008) to Pry out the blue button worked great for me. Not sure what the semi-circular shapes under the button were for but the switch works fine now. The only down side was that prying the button off broke the tab holding it, but this is no big deal. Saved me the cost of a new razor and I like the Braun 7505 model because it works great and is smaller than some of the newer models.
Jul 11, 2010 | Braun Syncro 7505 Electric Shaver
Braun Syncro 7505 Shaver, Need Power Cord.
If you just need a eplacement cord, you can get one at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-charger-cord-for-7000-syncro-8000-activator-360-complete-p-120.html
If you need batteries or PC board, this will raise the price considerably and you may find a less expensive option of buying a replacement. You will also find similar replacement units at shaveroutlet.com
Jan 14, 2010 | Braun Syncro 7505 Electric Shaver
I just need to know where I can get new batteries for my braun syncro 7505. The batteries don't have any markings telling the volts or milliamps. I would greatly appreciate it if someone could help me with...
Yes, these are NiMH AA 1.2V flat top batteries. Replacements can be found on some battery websites (like onlybatteries.com). I'd get the 2200mAh rated ones, as they'll hold a longer charge than the 1650mAh ones. You will need two of them (the shaver has a 2.4V motor). This works for most Braun shaver models from 6000 to 8000.
Aug 15, 2009 | Braun Syncro 7526 Electric Shaver
Braun 7526 battery problem
Open the shaver:
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 scews
4) Open shaver
5) Remove circuit board with batteries
6) Remove and replace circuit board with batteries (or solder in the new batteries)
Oct 25, 2008 | Braun Syncro 7526 Electric Shaver
Braun Syncro 7505 Electric Shaver Logo
391 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
