Question about Roper Refrigerators
Ice build up in freezer...Auto Defrost not working Model unknown...smaller model...about 5 feet tall...2 feet wide...freezer on top..no ice maker. Bought in 2002....noise during defrost quit about 2 months ago...Freezer works but ice builds up and blocks air passages to bottem.....bottem warms up.
  • 619 Answers
If it is a magic chef the model number will be on the back of the fridge and will have to order the exact defrost timer for this model. Only place to get will be from repairclinic.com
Posted on Jan 31, 2010
Loud "clattering" noise from freezer area when refrigerator runs
There is a fan in the back of the freezer that runs when the compressor is running. It sounds like you have ice build up around the fan.
You could have one of these problems: (Sorted by most likely to least likely)
1) Auto Defrost timer, defrost bi-metal or defrost heater is defective - the unit will go into auto defrost about twice a day, if this fails you will have lots of ice built up around the cooling fins and sometimes on the fan. Pull the back off the inside of the freezer and check for ice build up around the cooling fins, there should be none or very little if its running normal.
2) Bad door gasket - if the freezer door is leaking warm moist air inside the freezer it could be condensing around the fan causing ice (you will also see ice build up on things inside your freezer too).
3) Plugged drain - the drain leads from the freezer down to the drain pain under the fridge. If this is plugged ice will build up on the bottom of the freezer and potentially around the fan.
Apr 01, 2013 | Kenmore Refrigerators
Ice maker has water but no ice
HI.TERRY.freezer has to work at its optimum.for the ice maker to work. i would try to defrost the freezer completely first and try.good luck.Ali
Jun 28, 2012 | Samsung Refrigerator Ice Maker -...
I recently replaced the evaporator fan motor. Now I have two problems: 1) Ice maker does not dump ice automatically. The water line is clear and fills up the tray. The ice freezes but will not dump the...
Hi and welcome to FixYa, I am Kelly.
You made this statement:
I have to manually make the ice dump. 2) I now have a slight build up of ice under the ice maker where it appears the water from the ice tray is leaking and the inside of the freezer also has a slight build up of frost on the walls.
From my 40 years of experience that statement is telling me that the freezers' evaporator coils are blocked with ice. (i.e frost on the walls) When the coils become blocked or built up with ice everything APPEARS to be working fine but the actual freezer temp is above 17 deg F. An ice maker will not initiate an ice-harvest cycle until the temps are between 14 - 16 Deg F. I.e it is not cold enough to automatically make ice because the ice maker thermostat is not closing at 14 - 16 deg F to start the ice harvest.
So I will pose these questions for you and answer them:
Q? What causes the ice on the walls
A: The unit is not defrosting properly.
Q? What causes a refrigerator to not defrost properly?
A: There are several; reasons that a refrigerator will not automatically defrost
1. The defrost control has failed (Most common failure)
2. The defrost heating element has failed
3. The defrost thermostat has failed
4. A wiring problem in the defrost circuit
Now.... you also made this statement:
You may have a leaking ice tray but it is quite rare. What usually causes an ice build up directly under and ice maker is the inlet water valve leaking / bypassing water when it is supposed to be shut off. An inlet water valve will bypass water when the internal diaphragm fails or debris is blocking the needle seat of the diaphragm. Either way the only remedy is to replace the inlet water valve because the valves are NOT repairable.
Reach inside your freezer and squeeze the rubber tube that fills the ice maker with water. If there is a problem with the inlet water valve the rubber tube starts freezing up with ice. Eventually when the rubber tube is totally frozen the plastic tube on the back of the refrigerator that connects to the rubber tube either leaks or separates from the rubber tube and ports water onto the floor.
If you really want to prove that there is a problem with the inlet water valve turn the ice maker OFF. Remove the plastic tube from the rubber ice maker fill tube (Just pulls out) and place it in a bucket overnight. IF you note water in the bucket the next day then the inlet water valve has for sure failed. Sometimes they LEAK intermittently when the failure first begins so the bucket test may not reveal a leaking inlet water valve. The key here is you said you have water UNDER the ice maker and you suspect a tray leak.
Here is what I recommend you do after the overnight plastic tube in a bucket leakage / bypassing test:
1. Reinstall the plastic tube on to the rubber fill tube.
2. Turn the ice maker ON
3. UNPLUG the refrigerator and so a manual defrost by removing the freezer contents then directing a fan into the freezer compartment for just over 2 hours. (Makes a water mess)
4. Return the unit to normal service
5. Check for ice production 6 - 8 hours after you performed the manual defrost.
If you have automatic ice production you most likely have and automatic defrosting problem... BUT.... there can be a problem with the freezer door / light switch. The door light switch is a 3 contact switch. One contact is a common power wire and the other 2 contacts turn on the light and provide power to the ice maker (and some times the evaporator fan also depending on unit design)
Test the door light switch amd make sure the light will go off when the door is closed. (depress the plunger) If the light stays on the door switch is bad.
Hopefully you have enough information to understand what is happening with your refrigerator and what the causes of the symptoms you have are.
I think in the end you will have to repair the automatic defrost problem and replace the inlet water valve. Do not forget about testing the door light switch.
Thanks for choosing FixYa,
Kelly
Apr 14, 2011 | GE Refrigerators
Does a Hoshizaki Model F-1001MWH have a Defrost cycle? As far as I know the "defrost" is the harvest cycle correct?
Ice makers defrost is the harvest cycle. The purpose of a defrost cycle is to clear any ice build up, right?
Jul 08, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Fridge part of my side by side registers above 40, spoils milk; freezer section which is frost free gets frosty buildup in in; ice maker quit working also. freeze food still?
Look into the back of the freezer to see if frost is building up on the rear panel. If yes that is a sign of the defrost system failed. I will need your model number. When most refrigerators begin the problem it is a sign that defrost is not happening. Ice makers stop working above 5 degrees. Send me your model number and I will help you get this solved or pointed in the right direction, Sea Breeze
Feb 13, 2010 | Refrigerators
Double door fridge stops cooling, autodefrost not working
It wud need a new defrost heater, the fridge gets its air from the freezer , if the defrost heater does not work , ice builds up in the airduct , equals to no cooling in fridge
Feb 01, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My frigidaire refrigerator is sweating on the inside. what should i do? its a one door model with ice maker and freezer on top. i don't remember the model. 5 years old.
High humidly could cause condensation or the magnetic seal could be bad.
A couple of things to try;
The easiest thing to do first is to clean around the rubber seal very good with mild soap and water and the metal which the magnetic rubber seal contacts to seal the door. If you find a crack or a deformation of the seal it will let condensation it the refrigerator.
Does the freezer auto defrost or is a lot of ice bult up around the freezer walls? If so manually defrosted the freezer.
Dripping from the Ice maker water supply?
Jul 15, 2009 | Frigidaire Refrigerators
Ice build up
You must replace the defrost heater and thermostat located behind the freezer wall panel.
May 28, 2009 | LG Refrigerators
Water leaking into freezer
It may be the defrost thermostat. This thermostat turns on a heater in the freezer a couple of times a day and melts the ice in the freezer which should go into a tube that leads to a pan underneath the refrigerator, where it sits and evaporates from the heat of the compressor. It could also be the timer which tells the refrigeator to turn off a couple of times a day and tells the defrost thermostat to turn on.
Mar 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite - top freezer
if there is ice build up at the back wall of the freezer section, then you have a problem with your defrost cycle. the freezer would not be very cold for the ice maker to work.
it's either your timer, defrost heater or your bi-metal.
tnx 4 using fixya,
drcool
Sep 30, 2008 | Kenmore Refrigerators
Refrigerators Logo
210 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
