Question about Refrigerators
Kenmore model 106 57577790. Does not cool properly. Cool air blows, but fridge and freezer not cold enough. How can repair?
  • jcbnolen Jan 31, 2010
    I've been told could be freon. I plugged back in few hours ago to see what is going on as I have been brousing net for possible problems. the coil behind freezer comp is frosted from top coil running down and then only three coils up.....from there on up is naked of frost. where do i find freon, what rating? I'm a girl doing this on my own if possible.....can't afford the repairman's bill! Can I do this myself?
  • 619 Answers
Sounds like a freon problem. Is there frost build up on the back of the freezer wall. If there is you have a defrost problem which is much easier and affordable to repair.
Posted on Jan 31, 2010
Testimonial: "very helpful=JUST TO GET A REPLY!! THANK YOU!! I left a comment to further the conversation, any additional help GREATLY appreciated!!Thanks again!!"
  • Ricky Harrelson
    Ricky Harrelson Feb 01, 2010
    Try to let stay setting unplugged for 24 more hours ok. freon is difficult even for the most qualified. 134a is the freon type tho. OK. If any more assistance is needed my mssnger is rickmfl on yahoo. Good luck.
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
My kenmore 253 upright freezer/fridge is not cooling the fridge part correctly. It's cool but not cool enough to keep the food fresh. The freezer works well sometimes. And sometimes it seems that it's not...
Try this test. Set a window fan behind the fridge to constantly blow air across the lower coils at the floor. If the fridge works well after a while of this, then the lower fan on the fridge needs replaced. Sometimes though, after a while, the fan will finally start working again because the cycle has finally corrected itself with the test. Leave the window fan run on low for a few days before removing it. The hum you hear is the compressor moving the coolant and is supposed to do the hum sound. That's good. Now once the fridge is working, and you still have a good freezer section and not cool enough below in the fridge for you, there is a knob that sets the cool lower by opening flaps under the freezer to let more cold down to the fridge area. Set this knob to colder and the flaps will open more.
Nov 11, 2014 | Refrigerators
I have a Artic Air White Reach In Freezer. It is not blowing cold air from he top where the cold air comes in. Freezer was at 60 degrees F. I turned the defrost switch to make sure it wasn't in...
Is the freezer itself getting cold.To blow cold air.the freezer should get cold/friezed.the cold air blows from freezer to fridge side.first the freezer side gets cold, then when the freezer side gets enough cool to its set cooling temperature, at that time the defrost cycle starts.In defrost cycle the fan in the freezer starts running and the cool air from freezer starts going to fridge side.There is a ventilation passage between fridge and freezer from where this cool air passes.---------------- If in your case, the freezer is getting proper cold, but its not blowing cold air from freezer to fridge, then possibility is that, there is a blockage in ventilations.But if ventilation its clear, then its defrost problem.First try manual defrost reset procedure. The procedure is as follows: ---- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. Then its defrost board problem. ------------------------- BUT if in your case, the freezer section itself is not getting cold, then the problem is compressor related.The compressor is the part which cools the freezer frost.In the compressor, there is a refrigerant to cool the freezer.If the compressor gets weak or the refrigerant gets low, then it will not cool the freezer, if the freezer is not cool then it will blow warm air from freezer to fridge, in defrost cycle.In that case, the compressor is faulty and its the cause of problem.------------ So you will have to first check , that is your freezer getting cold or not.as per that you can start the troubleshooting.------------------
You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
May 01, 2011 | Arctic Air Freezers
Freezer side is working very cold the refrigerator side is only cool. Air does not seem to circulating properly.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 16, 2009 | Kenmore 57029 Side by Side Refrigerator
My Kenmore fridge, Model 596-58692890 is not cooling and I've lost use of the water/ice dispenser. The motor and compressor seem to be working but the cool air is not blowing. What part might need to be...
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 24, 2009 | Kenmore Refrigerators
Freezer to cold refrigerator not cold enough
sounds like your defrost timer is not working properly . Most fridge/freezers the fridge gets cooled from the cool air from the freezer . But when the defrost timer is not working properly the section between the fridge and freezer freezes up and hence doesnt allow the flow of cool air into the fridge. The defrost timer can be easily replaced.
Jan 28, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Kenmore Model # 596.735032.. Fridge is cool, Freezer is not freezing
After pulling the fridge away from the wall and removing the lower right hand panel I noticed that the compressor (big round black ball with copper tubing) was not turning on. I also noticed that there was a ticking or popping sound comming from it every couple of minutes or so. After doing some research online in numerouse forums I decided to try and replace the overheat relay that is attached to the compressor. It only took maybie five minutes at most to change it and the compressor is now working with nice cold air comming into the fridge and freezer. Hope this helps someone else with the same problem.
May 06, 2008 | Kenmore 73503 Stainless Steel Bottom...
Fridgedair side by side
what to you mean by defrosted fridg. was frost built up in freezer>? check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, OR you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
162 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
