Question about Dryers
Is there a problem with my dryer if it is squeaking, something that i can fix to prevent a problem later on?
  • 619 Answers
Depends on the type you have. either drum sopports(rollers) or bearing. Both are easily fixable with the corre4ct parts. Do not try to oil.
Posted on Jan 31, 2010
Dryer starts for 10 sec and then stops, has an burn smell it runs great Although when it stops it won't restart until a few mins later. Then the same over again. Its a loud noise when going for 10 sec
It sounds like it's overheating.
Find and clean the filter.
The noise might be something caught between the drum and the mechanism. A bra underwire is common if your female (anonymous)?)
Check with a good torch...
If you rotate the drum and it squeaks it's something jammed or maybe the bearing.
Apr 20, 2016 | Dryers
The dryer squeaks... loudly! Is it more likely the glide, the felt, or something else?
Good Morning John,
I understand that the dryer on your Frigidaire laundry center, model# FEX831CS, is squeaking intermittently. I also see that you are wondering if it could be the glide, the felt, or possibly something else, that is causing this. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine the exact cause of the squeaking. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire FEX831CS Top Load Stacked...
Drum squeaks on rotation. can drum be lubed?
would not lube the drum but the two small wheels that the drum rotates on sometimes their "axles" get dry and rusty and will squeak. Put some antisieze on them and see if the noise goes away.
Mar 16, 2014 | Whirlpool Cabrio WED6400SW Electric Dryer
The dryer on my kenmore 4179 stackable makes a loud squicking sound and sometimes puts a mark like a mini feather on clothing which later seperates at that spot. Can it be fixed?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 08, 2010 | Dryers
Unusual squeak noice
easy way is a bit of furniture pollish on belt / fly wheel
Jul 23, 2010 | Kenmore 74602 Gas Dryer
Very loud squeaking noise - like a noisy loose fan belt on a car.
The dryer needs to be rebuilt, new drum belt and drum rollers to cure this problem.
Mar 24, 2017 | Frigidaire FDE336RE Dryer
Dryer squeaks while drying sounds like drum rubbing on something
A squeak can also be a slipping belt or something caught between the drum bearings usually the front but could be the back one.
Jun 14, 2009 | Dryers
Squeaking sound on new samsung dv448aew dryer
first off you need to put your foot down and tell them to replace the belt or the adjuster .dont let them leave until they have satifyed you
Mar 24, 2009 | Samsung DV448AEE Electric Dryer
My Dryer squeeks while rinning
If it is a constant squeak no ups or downs then its the bearings in the motor that turns the drum. If the sound is not monotone, meaning up and down squeaks, then the drum is rubbing something foreign.
Nov 10, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
Top Dryers Experts
