Question about Delta Faucet Delta RP17453 Pull-Down Diverter Tub Spout
I have a delta pull down tub faucet diverter under neither it goes from 1/2 to 3/4 can some one help me
  • cracklin joe May 11, 2010
    i'd love to help but i have no idea what your talking about,...try to clarify a little more, thanks
  • 126 Answers
I m having a problem understanding your question ?
Posted on May 17, 2010
2 Suggested Answers
  • 129 Answers
SOURCE: my delta faucet pull down diverter tub spout is
It sounds like it could be manufacture defect. Take it back for a new one.
Posted on Oct 05, 2009
I have a leak under my bathtub/shower it only leaks when the shower is on.It's not the drain or the pipe up to the shower head
There may be some leakage in pipe.Take the help of experts.Nowadays there are many leak detection services that can help in solving such problems.
find a leak in wall
Aug 02, 2012 | Delta Faucet Delta RP17453 Pull-Down...
I have a Delta Tub/Spout Pull Down Diverter that has a pretty persistent drip. The HOT and COLD handles are turned off and seem to be as tight as they can be. After doing some research online I believe...
If your Delta RP17453 Pull-Down Diverter Tub Spout stops dripping after 5 minutes, your ok. If it never stops dripping, you need to replace delta faucet cartridge(s) behind the handle(s). This is were the water turns on and off and stops the water flow to the tub spout.
Delta faucets are some of the easiest to repair, and parts are usually available at any hardware store or home center. If you have a two handle faucet, replace both delta seats and springs and stems. If you have a single handle Delta faucet, replace the entire cartridge.
Jan 26, 2011 | Delta Faucet Delta RP17453 Pull-Down...
I have a garden tub w/o a shower attached. However, the fixture in the tub is the Delta pull down diverter (dont know why they would put that in a tub w/o a shower). Anyway, the diverter was pulled down...
If it was me... I would replace that spout...
the spout either is threaded on or it has a set screw on the bottom at the back that you loosen and then pull the spout off by pulling straight away from the wall...
Check and see if the spout has the hole for the set screw...if not then twist it counter clockwise and it will turn off...
then repalce the spout with a new one with out the diverter...
heatman101
Aug 05, 2010 | Delta Faucet Delta RP17453 Pull-Down...
My delta faucet pull down diverter tub spout is
Sep 28, 2009 | Delta Faucet Delta RP17453 Pull-Down...
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
Jun 09, 2009 | Delta Faucet #RP320 Divert Assembly
I just moved into a new place with Delta shower and tub. However, I have no idea how to divert the water to the showerhead. There is nothing to pull up (which is what i usually see in hotel tubs) to divert...
On the bottom of your tub faucet is a ringed part that is about a 1/2 wide. Turn the water on, grasp that firmly in your fingers, and pull it straight down. Your faucet should come on.
Sirwriter
May 15, 2009 | Delta Faucet #RP320 Divert Assembly
Delta diverted spout is stuck! Can't pull it down
You probably have lime deposits built up which won't allow you to pull it down anymore. Try spraying lime away on it and use an onld toothbrush and work it up in there. If this doesn't work, you can replace the spout with a generic one. The spout should just twist off. Sometimes they can be stubborn. Hopefully this helps.
Apr 03, 2009 | Delta Faucet #RP320 Divert Assembly
Diverter Tub Spout stuck
Its probably just stuck on some lime and mineral deposits. You can try and spray some lime away on it and then try to loosen it. Or you can unscrew the whole spout so you can soak it. If that doesn't work, you can either contact Delta for an exact replacement or you can purchase a generic one.
Apr 01, 2009 | Delta Faucet Delta RP17453 Pull-Down...
Delta Faucet Delta RP17453 Pull-Down Diverter Tub Spout Logo
260 people viewed this question
Top Delta Faucet Plumbing Experts
Donni Steen
Ed Mac
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
