Question about Garden
Engine will not start
I have a Ryobi 4stroke weed eater. It has a snow blower attachment I use. If the unit sets for a couple of weeks the carb gets gummed up & I cannot start it. I have take the carb apart & clean so it will start
Do you have a solution?
Thanks
Tony M
  • 105 Answers
Yes, that gas treatment stuff meant for this purpose is great stuff! you can get it in any hardware store or small engine repair place,...just mix some into your gas tank, pour it into your little ryobi thing and let her sit,.....no problems when you go to start it up months later
Posted on Jan 31, 2010
Why won't my McColluch weed eater create a vacuum
Did you check the muffler exhaust or spark arrester, to see if it is clogged from using to rich a oil/gas mixture ? Did you replace the diaphragm in correct position ? Find a new carb online, possibly ebay ?
May 16, 2014 | McCulloch 5pcs General Snap-In Primer Bulb...
Petrol weed eater will not start. Alomost starts
Hi Mark, I own a shop, we will not work on ryobi, have you gotten 2 seasons out of it? If so thats probably as good as it gets. But you can check carb settings. In the USA they come with limiters on the adjustment screws, not too much you can do(break them off) back your adjustments counter clockwise 1half turn.
Dec 20, 2010 | Ryobi Three Trimmer Combo
Powerpro 17" McCollich weed eater
hey harry the float inside the carb is stuck i would suggest rebuilding the carb
Jun 27, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Ryobi weed eater head won't spin
Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
Apr 27, 2010 | Ryobi Garden
I have a ryobi weed eater clean carb change filter and spark plug wont run off choke
I have the same problem. It will run if I put it halfway between Half Choke and Full Choke. But, just dies if I put it on Run or Half Choke. Don't ever loan your WE to anyone, They might just try to run it on straight gas--That is what happened on another week eater that I had.
Mar 27, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a 31 cc ryobi weed eater start for about
I think a new carburetor kit and a good carburetor tune up is in order my friend. Sounds like it's starving for gas. If it bogs down after warm up when you throttle it, then yes it needs a carb tuning. The L screw is the low side screw and should be turned in lightly until it seats then back it out one and quarter turns (1 1/4). The H screw is your high speed screw. Also, turn it in lightly until it seats, then back it out approximately a 3/4 turn. With these settings the unit should start and may even stay running. Again, if it bogs when throttled, while running turn the L screw out a little more maybe only 1/16th of a turn and then try it again. If it does rev then you'll have to adjust the H screw in about a 1/16th of a turn. But make sure you only do this after the engine has warmed up.
Hope this works, good luck
Skidooer
Sep 27, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Rhobi weed eater stalling
Try spraying some carb cleaner into the intake while its running - with the air filter out..
If that doesnt help & if it sat for a long time without being run - you might need to get the carb reuilt..
Hope this elps !!
rate me good ;o)
Jul 14, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Adjustment of the gas air mixture on a Ryobi ss30 weed eater
aside from carb adfustment. remove exhaust screen and scrape off carbon with piece of wood. also repplace the fuel pickup filter in the tank. couple buck at the home depot.
Jun 19, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Garden Logo
111 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
