Question about Protron PLTV-26 26 in. HD-Ready LCD Television
I have the pltv26 and have sound but no picture. I read where this indicated a bad inverter board so I replaced the inverter board thinking one of the transformers were bad. I put the tv back together and I have sound but still no picture. Any other suggestions?
  • 6 more comments
  • r67183 Jan 31, 2010
    How do I check that the inverter board is getting power from the main board?
  • r67183 Feb 01, 2010
    How many volts should it read?
  • r67183 Feb 02, 2010
    Is the cable that carries power to the inverter board the multi pin braided cable or the single thin black wire that plugs into the end of the inverter board. if it is the multi pin, which colored wires carry the 18-20v power?
    do you know which colored wires in the multi-pin connector bring the power from the power box to the inverter board?
    which colored wires carry the power from the power board to the inverter board and is the 18-20 volts ac or dc?
  • r67183 Feb 03, 2010
    Can you tell me which colored wires should I check for the 24v coming from the power supply as there is a multi-in connector that plugs into the inverter board that contains about a dozen different colored wires? Should the voltmeter be set for AC or DC?
    The braided cable coming to the inverter board from the power supply board has about a dozen wires that go into a multi-pin nylon connector. Do you know which colored wires I should check with volt meter to see if the inverter is receiving the 24v from the power supply? Also, is is AC or DC voltage?
    can you tell me which colored wires carry the 24v to the inverter board from the power supply on the pltv26 protron LCD tv.monitor. There are about a dozen or so wires bundled into the nylon multi-pin connector that goes into the inverter board. and I want to see if it is receiving the 24vdc from the power supply to see why I have no picture but good sound.
  • 4,889 Answers
The easiest way to check if the backlight inverter is working is to look for a dull glow on the screen. Turn on the tv and darken the room see if you notice a dull glow on the screen. If you do then the inverter is functional and what you have is most likely to be a faulty t-con board also known as video driver board or timing control board. Usually costs under 75$ for a tv of this size.
Sai.
Posted on Feb 03, 2010
  • 201 Answers
That's the problem with LCD TVs, about 4 things can cause that problem. do you have a volt meter? If so you most inverters get 24v from the power supply. If you don't have 24v that would point to the power supply. If you do have it then the main board would the most likely suspect as there is a "back light detect" line if the main fails it may not see this signal. Otherwise the panel itself is bad and it would be cheaper just to buy another TV at that point.
Posted on Feb 02, 2010
  • 10,594 Answers
Make sure inverter board is getting power from power supply board.
If above said is OK then main digital board would be defective as it controls picture and inverter board on-off function as well.
Thanks.
Posted on Jan 31, 2010
  • Shahid Electronics
    Shahid Electronics Jan 31, 2010
    Follow that connector of inverter board that goes to power supply board and check volts there with multimeter.
    Shahid Electronics Feb 01, 2010
    Inverter board supply should be 18V to 20V
Replaced the power supply/backlight inverter board and T-con boards on my Samsung 37" TV Seems worse than before
hi this is usually is a tcon board fault, but it can also be a bad panel, if it's flashing could a mainboard fault thanks
shaun
Feb 27, 2017 | Samsung Televison & Video
LG 50ln5700-uh led tv, sound no picture
Fault at its main digital board. No back-light inverter start voltage comes from it to the back-light inverter circuit. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 14, 2017 | LG Televison & Video
Westinghouse sk-32h570d sound no picture
After ignition of the back light, a control voltage will come from the main board, to control the intensity of the back light. This is true to all LCD TVs. You should check, whether this control voltage [a variable voltage according to picture displayed on the screen]. If it is not present, make sure that the main board is faulty, as this voltage is generated at the main board and send to the back light inverter board' to control the brightness. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 22, 2014 | Westinghouse Televison & Video
Turn power on greenlight comes on but no picture?
If you have sounds but no picture or backlight on your TV the problem is on the inverter board...
Please replaced it to fix your TV..
The part # of inverter board is indicate on the sticker attach to the inverter board..That part # needed to easily order the parts online or local...
Dec 22, 2011 | Televison & Video
I have a Sanyo DP42848. If I shine a flashlight on the top right corner I can see video 1. There is sound but the picture goes off after a cpl seconds. I think I have found the inverter board. If you can...
Hi Drew,
Yes that kind of symptoms is an indication of faulty inverter boards. Click this LINK for the replacement. Sorry but we are not allowed to give our contact information.
Thanks for using Fixya.
Jdvillanueva
Aug 03, 2011 | Televison & Video
No picture no sound
Hi, it could be bad inverters or a bad power supply. I'd inspect both boards. you should have 24 volts coming from the power supply to the inverter. If you have the 24 volts, bad inverter. If you don't have the 24 volts, bad power supply.
The inverter is the high voltage board that provides variable power to the backlight lamp. This is the most common. When inverter is faulty you can get no picture, or a very dim picture that can only be seen by pointing a torch light with a 45 degree angle on the LCD surface from very near distance. The inverter must be tested by reading voltages with a multimeter.
Mar 03, 2011 | Philips 60P8341 60" Rear Projection...
Just sound no picture
Black screen means the backlight inverter is not working due to not haveing the 24vdc feeding it becuase of bad power supply, or the inverter board has blown fuse, short circuits, etc,
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 11, 2010 | LG 37LP1D 37 in. LCD Television
SOUND WORKS GREAT, PICTURE SWITCHES OFF ALMOST IMMEDIATELY GREEN LIGHT STAYS ON ON POWER INDICATOR. ANY HELP WOULD BE HELPFUL
Ur LCD inverter board is dead.Replaced this LCD inverter board will get ur picture back.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.This a long board inside ur tv.
Apr 08, 2010 | Polaroid FLM-1911 19 in. LCD Television
No picture but I have sound
First possibility to get checked the power supply board.but as you mentioned that there is sound but no picture this clears that power supply is OK.
Sound, but no picture in LCD TVs is indicative of an inverter board failure. This is the board that powers the back lights that project through the LCD screen. An inverter will run about $180 plus labor. An online source for replacement inverter boards is available here. You can cross reference by your Make and model number.
The inverter board looks like this, and is normally supplied by a dedicated voltage from the power supply (24vdc or 60vdc). Most of the Polaroid models use 24vdc.
Its not that difficult, the web site that I provided you with a source for a replacement also has a little tutorial on replacing an inverter. They vary in location by manufacturer, but usually on the left or right side - and look like the picture I provided you. Just be gentle with the cables you have to remove and replace.
The tutorial is here.
this will help.thanks.
Feb 20, 2010 | Polaroid FLM-3201 Television
Protron PLTV-26 26 in. HD-Ready LCD Television Logo
115 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
