Question about Dayton Gas Furnace Heater
Lennox merit series furnace is not kicking on until house is 8 to 10 degrees colder then set thermostat
I have the same issue with a G21Q4-5-100-1 model lennox. House drops 8 - 10 degrees. I have 3 thermostats and all react the same way. I was told by service tech that the Ignition Coontrol Module is bad and acting intermittanely. ???
Posted on Feb 16, 2010
    Scholar:
  • 185 Answers
Check the thermostat, by one placing a regular thermostat in the vicinity of it and compare the readings.
It is likely that the thermostat is the weak chain in the link.
It is either that it is defective, or it is being heated by some other heating source. ,
usually an appliance placed too close.
Posted on Jan 31, 2010
I have a Braeburn 3200 and when the the temperature reaches the desired heat setting. The furnaces heat will shut off, but the fan will continue to run indefinetly. eventually blowing very cold air up
The fan relay is stuck in the on position. When the temperature drops the heater does not ignite because the fan is already running and ignition is locked out after the heat cycle starts an the fan turns on
Nov 16, 2014 | Heating & Cooling
We have a new a/c and the system has heat strips. For a/c. we have had the thermostat set on AC at 72degrees. Now that it is getting colder and may need some heat in the house, do we switch the...
If your thermostat has an emergency heat setting this means you have a heat pump system.
Yes you need to set the thermostat to heat for heating the house.
The emergency heat setting should never be used unless your outside unit is not functioning.
The emergency heat setting overides the heat pump (the outside unit will not be energized).
The emergency heat setting will run the auxillary heat (heat strips) only.
When the thermostat is set in the heat position the heat pump will run to heat your house.
If the heat pump can't keep up (extreme cold) then then the auxillary heat will kick in to augment the heat pump until it satisfies the thermostat settings. If your room temperature gets 2 degrees below your thermostat setpoint, your auxillary heat will kick on. Example, say you are going to be gone a couple of days and you turn your heat down to 60 degrees. When you return and it is 60 degrees in your house, you turn the thermostat up to 70 degrees. Since you are turning the temperature up 2 degrees or more (10 degrees in this case) from the 60 degree room temperature then the heat pump will come on and the auxillary heat strips. The unit will continue heating like this until the temperature in the house gets to 69 degrees and the heat strips will turn off and the heat pump will continue to run until the 70 degree setpoint is reached.
Hope this helps.
SeagullAC
Sep 15, 2011 | Heating & Cooling
Lasko 5141 - I set the temp to hold @ 68 degrees at night but it seems to ignore the setting and gets into the high 70's. This is with the rotation switch on if that makes a difference. Any Help ? Thanks
Remember it is always colder at the floor level, the heater is pretty close to temp when it is above 40 degrees outside, but as the temperature gets colder outside so does the temperature at the floor level in your house because heat rises.
I use my house furnace thermostat mounted half way up the wall as a guide, When the temp outside is in the teens, I have seen as much difference between the floor temp on the heater and the wall to be 4-6 degrees different. So this means as the tempurature outside drops you need to regulate the thermostat on the heater downward to compensate for the colder floor temperatures.
Jan 10, 2011 | Lasko 5141 Ceramic Electric Heater
Problems for months, now the heat won't kick on at all
First thing to do is turn off unit at switch. Then dissconnect all t'stat wires from the thermostat. Put the red wire and the white wire together.
If it goes on then you may have not set the thermostat correctly. I use a digital one from Menards made by Honeywell it cost $18.. But if it does not light then check to see if you have 24v to coming out of the transformer. You need a meter to troubleshoot this one!
Mar 20, 2010 | Heating & Cooling
Lennox G40UH(x) series - Air not coming on
electrical connections @ the furnace may the thermostat .Tom
Jun 18, 2009 | Heating & Cooling
First floor of house is cold
The thermostat will turn your furnace on and off to satisfy the temperature setting at the location where the thermostat is located. If you move the thermostat to the first floor and set the thermostat at say seventy, it should keep the furnace on until the temperature near the thermostat hits seventy degrees.
Feb 06, 2009 | Honeywell Focus 6300B 5-2 Days...
Lennox Gas Frunace fires goes out, fires goes out, fires goes out
Check your thermostat anticipator setting. If you dont know how to do this don't try on your own or you may damage your thermostat.
Dec 12, 2008 | Honeywell Electronic Programmable...
Dayton Gas Furnace Heater Logo
1,316 people viewed this question
Top Dayton Heating & Cooling Experts
paulcarew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
