Question about Toys
I have a 1995 ford probe gt. The front driver seat is motorized, it's stuck all the way foreward and will not go backwards. I checked the fuse and there good. Anyway to move it manually?
  • kevykev_35 Jan 31, 2010
    the solution sounds good need to try it. Where can I find an illustration of the seat motor online. Hard to see under seat.
  • 6,674 Answers
Easy way would be to attach 2 jumper wires to the 2 wires at motor or connection, and use a 12 or 14 volt cordless battery to power it. If you touch wires to positive and negative on the battery, motor should work if switch is the problem. If seat goes wrong way, reverse wires on the battery. Just make sure you on the motor that moves it back and forward.
Posted on Jan 31, 2010
  • Mike Butler
    Mike Butler Jan 31, 2010
    You should be able to see the 2 wires coming from motor that powers seat forward and back, but my guess is it will take longer to find an illustration, than it will to check with a flashlight under there.
    Let me know how you make out.
What is wrong when the electric driver seat in a 1995 ford mustang will not move forward or backward but will move up and down.
check switch for proper operation //check motor control for power ,connections and wires are not damaged or disconnected===check seat track for debris or something stuck
Aug 11, 2015 | 1995 Ford Mustang
My Driver Power Seat is stuck all way forward is goes up and down but not backwards ive checked and replaced the fuse but nothing so now the car is un driveable
either the contact for forward/reverse on your power seat is faulty or the motor is going bad which is less probable than my first suggestion. If you have a little patience, a bsaic mechanical aptitude and a circuit tester (like you'ld check a fuse with) you could test the for/rev function when you press the switch to determine if its electrical problem or the motor
Apr 22, 2011 | 2004 Ford Mustang
I have a 1995 trooper V6 dual cam engine with an electric adjustable front driver seat. The seat recently stuck in the reclined possition. I tried to press the fuse for the seat, however when I try the...
has to be your wiring causing short ,or seat to far back and loading motor causing fuse to pop make sure seat not jammed in any way if not trace wiring back
Apr 22, 2010 | 1995 Isuzu Trooper
Driver's power seat will not move backward
check fuse.if fuse is good check for power at seat motor.if yes replace seat motor.if no check wires at switch.if wires is not loose or broken seat motor switch could be bad.
Dec 13, 2009 | Dodge Grand Caravan Cars & Trucks
I HAVE A 2002 MONTERO MITSUBISHI, THE DRIVER SEAT
you try moving your seat foreward when the car is on flat ground or when the rear is higher than the front.It also happen to my pajero fieldmaster
Sep 10, 2009 | 2002 Mitsubishi Montero
The electric front seats both stopped moving
Check the fuse box for a blown fuse, both seats may operate on one fuse depending on the model of vehicle and the fuse may be located either under the dash on the drivers side or in the engine compartment on the drivers side.
Aug 21, 2009 | 1995 Lexus GS 300
'96 monte carlo autoseat wotn move forward or backward
Individual motors for horizontal and vertical movement. Try moving seat while looking under at motors. Once you find the one that is not moving, try holding switch to foreward position and tap on motor with a screwdriver handle. This may get it going long enough to move so you can reach the pedals easier.
Jun 17, 2009 | 1996 Chevrolet Monte Carlo
My drivers seat wont move.
check the track for anything that have gotten stuck in it and then check the fuses and if all good the motor could simply be burned out get a 12volt tester and if the fuses are good test to see if you have power while pushing the button because it could be just a bad switch
Jan 15, 2009 | 1998 Ford Explorer
1995 Ford Probe GT no spark
Hi is your Probe a 2.5cc 24valve.If it is then you may need to check the CPS(crank position sensor) All the best.Phil
Aug 17, 2008 | 1995 Ford Probe
Toys Logo
22 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
