Question about Linksys Wireless-G WRT54G Router
For somw strange reason i cant pick up any internet unless i plug in the network cord into my laptop.... it used to work b4.. can someone help me?
  • Linksys Master
  • 2,263 Answers
If you connect the cord to the laptop and the router it works that means the wired connection of the router is working only the wireless connection is not working.
It might be the issue of the wireless settings of the router or the computer. You will need ot check the wireless settings of the router and the computer.
to check the wireless settings of the router , you will need to open the router set up page. Is there any computer connected to the router ?
if not then you will need to connect the computer to the router and open the router set up page.
Click Here for more information about the router and wireless networking
Posted on Feb 01, 2010
I have installed, set up, and created my router's name, password, and key, but im still having trouble connecting to the internet. The little icon that looks like the earth is glowing orange, and the only...
Use the network setup wizard to connect to your network, and the internet. Unless you did this already.
You can get the wizard from Control Panel, Network ... , Connect to a Network. If wired you won't need key, it's for wireless only.
Yo did not say what OS, so info is a little generic.
Hope this helps.
Jan 26, 2011 | D-Link DIR-615 Wireless Router
My computer connects to my wireless router, but I cannot get on the internet. The "Locked" light is on - I'm not sure if this is the problem .
Thank you for contacting the experts. The first thing to do is to ensure that your router is getting internet connection.
1. Plug the ethernet cord from your modem to your laptop directly by bypassing the router to see if you can get on the internet.
2. If you are able to successfully get on the internet, then plug the cord from the modem back into the correct port on the router. Make sure you have the cord plugged into the port that says "internet".
3. Once that is plugged in correctly, depending on if you are using DSL (phone company), you will need to log into the router to change the password/user ID settings. If you are using high speed (cable company), then you will not need to put in a user id/password unless you are setting up security.
4. Power cycle your router and modem simulatneously to make sure that the router picks up the modem connection and the modem picks up the router.
I hope this was helpful and thank you for contacting the experts.
Jan 29, 2010 | Belkin (F5D7230-4) Router (587009)
My dell inspiron e1505 tells me that it cannot pick up wireless networks. My computer was picking up wireless earlier today in front half of house. we extended the signal via ethernet cord and plugged in...
Depends apon the signal and how you have the computer settings some of the older computers have programs where differant places will not be picked up !
Did you check your internet options in your control panel?
1.Check your internet options and see if your lan settings have a check mark in the top box for lan atuomatic detect settings click ok then your internet should pick up ..... if you are still haveing prombelms please let me know ... Lala linda
has a check mark on the top box so there is a
Dec 24, 2009 | Dell Inspiron 1501 Notebook
Internet dose not work
This model Dell laptop used a PCMCia card as a network adapter, which may or may not be installed in the slots on the side of the laptop. If one is installed you may need the dongle (an adapter that plugs into the card and ends in a standard network jack)
an example of several types can be found at http://tekgems.com/Products/3comdongle.htm
Aug 22, 2009 | HP Computers & Internet
My pc doesnt see my ps3 on the network and so i cant use the media server function...it simply says no media servers available.. os: vista ultimate useing wireless network and internet connection through...
you may need to plug your ps3 into the internet cable directly and wait for it to update it's system before that can work. Thats what I did and it works fine now.
Aug 15, 2009 | Sony Playstation 3 (PS3) Console
Wireless Internet wont work unless I plug in a wire
QuickSet utility Wireless options can cause these issues.
There is a setting to always deactivate on battery. Make sure this is not set up. The correct setting would be Always active on battery or Always On, or no power saving options for Wi-Fi. Depending on the version of QuickSet which you have.
Apr 21, 2009 | Dell Inspiron 1525 Laptop
Conneting ps3 online through laptop using o2 broadband
Are you connecting wirelessly or with a cord? if wireless, you need to make sure that you are selecting the same security setting as the connection that you pick in 'network settings'. If the option is 'none', then you need not worry about a password. however if it has a password, then you need to make sure that you type that password in (case sensitive). I had the same problem and this worked for me. hope this helps...please rate if it does....thanks. also, you shouldn't have to do anything with your laptop at all. try to use a direct line from your modem if you are using an ethernet cord.
Jan 12, 2009 | Sony Playstation 3 (PS3) Console
Wireless Internet For Laptops
Some access points have codes, your laptop has to be able to pick up a access point. But in 2012, There will be a thing called Wi-max which means Wireless internet will be all over the world no matter where you are. So you can go on the internet wherever you are as long as you can connect to someones access point.
Jun 11, 2008 | Internet Computers & Internet
My internet won't work on my new laptop.
First turn off you laptop. Second, go to your comcast cable modem unplug it from the wall and wait about 3mins. Now plug the comcast modem back it and wait for all the lights to come back (will take about 2-3mins). Now plug the yellow ethernet cable into your laptop if its not already and turn your laptop on. You should now have internet.
Also if you using a Comcast Surf Board modem be mindful of the standby button on top of the modem. You can tell your in standby mode if the standby light (bottom light) is amber. If it is press the standby button once to get out of standby mode.
hope that helps
May 12, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
65 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
