Question about Remote Starter with Keyless Entry
I have a 2009 silverado with remote start, it starts fine but shuts off every time I turn the key on I then have to turn it back and restart it
    Scholar:
  • 151 Answers
This is apart of its normal operation,nothing you can do.
Posted on Feb 03, 2010
Car will not start
Buick Enclave No Start Problems - Car Forums at Edmunds.com
forums.edmunds.com > Buick > Buick Enclave
Mar 1, 2009 - 31 posts - ‎13 authors
Learn more about Buick Enclave at the Edmunds.com Car Forums! Read real ... Time to take it in and see why car will not start with the remote key. Anyone else .... I drove my brand new 2011 Enclave yesterday. It sat for an ... Buick Enclave engine won't shut off. Parking brake light ...
Aug 9, 2014
Buick La Crosse Stalling/Starting Problems
Jul 26, 2006
More results from forums.edmunds.com
EnclaveForum.net: Won't start from time to time
www.enclaveforum.net > ... > Recalls, TSBs, FAQs, Links & How To's
Jun 23, 2008 - 20 posts - ‎16 authors
I have been having an issue of my Enclave not starting from time to time. If I turn the ignition back off and try again, sometimes it will start after the first ... 2011 Audi Q7; 2009 Audi A8L ... I usually just "flick" the key to let it auto-start and it normally works fine but ..... BUICK ENCLAVE Technical Service Bulletin EnclaveForum.net: 2013 BUICK ENCLAVE ...
Aug 14, 2014
EnclaveForum.net: Car continues to run after key removed
Nov 13, 2012
EnclaveForum.net: evaporation hose on gas tank - does ...
Jun 25, 2012
EnclaveForum.net: Engine won't start low fuel level
Feb 3, 2012
More results from www.enclaveforum.net
Jan 05, 2016 | 2011 Buick Enclave
Remote starter comes only briefly and shuts off
Factory Remote Starter Quits After 5 Seconds - Diesel Place ...
www.dieselplace.com/.../340832-factory-remote-starter-quits-after-5-sec...
Nov 23, 2009 - 11 posts - ‎8 authors
On my 2007.5 Duramax, the factory remote has been working fine ... I tried this morning again with the remote starter while sitting in the truck and same thing, turned off ....2008 Silverado 2500 HD CCLB Duramax 6 Spd Allison 4X4 Z71 ... shut off engine", basically its doing it foryou as your not in the truck to ... check engine light on wont shift
Oct 28, 2011
remote start
Oct 14, 2008
More results from www.dieselplace.com
Factory Remote Start Problem - 1999-2006 & 2007-2013 Chevrolet ...
www.gm-trucks.com/forums/topic/114985-factory-remote-start-problem/
Jun 12, 2010 - 10 posts - ‎8 authors
Factory Remote Start Problem - posted in 1999-2006 & 2007-2013 ... Sounds like you may have an intermittant code coming in and the dealer should be able to pull it out.2008 Sierra SLT ECSB Z71, Corsa Touring, and GMPP CAI .... the remote start button again the truck WILL shut off and the only way to ... Burning smell, white smoke - 2014 / 2015 / 2016 ...
Jan 11, 2014
2008 Silverado Electrical Issue
Aug 19, 2012
Making Factory Remote Start Run Longer
Dec 21, 2010
2000 Sierra, Starts Then Dies - Code 1631
Dec 4, 2008
More results from www.gm-trucks.com
Jan 05, 2016 | 2008 Chevrolet Silverado 2500HD
My remote start was working fine and now it starts the 2003 chevy silverado but the truck shuts right back down.
Does the truck start and run when you start it with the key? If it does then you have lost continuity from the remote starter module. Check the wiring that has been added to your ign. switch it may be just a loose connection.
Mar 11, 2013 | Cars & Trucks
I need a radio wiring digram color code for 2009 chevy silverado
2009 CHEVROLET SILVERADO C1500 4DR TRUCK WITH 4.3L ENGINE AND STANDARD AUDIO SYSTEM
Remote Start
WIRE COLOR POLARITY LOCATION
Battery RED/WHITE (+) IGNITION SWITCH HARNESS
LOW CURRENT, FOR HIGH CURRENT USE RED/BLACK AT VEHICLE FUSE BOX
Ignition 1 PINK (+) IGNITION SWITCH HARNESS
Accessory 1 BROWN (+) IGNITION SWITCH HARNESS
MAY BE YELLOW ON SOME MODELS
Accessory 2 PINK/BLACK (+) IGNTION SWITCH HARNESS
FOR REMOTE START INTEGRATION
Starter 1 YELLOW/BLACK (+) AT MODULE UNDER HOOD BEHIND DRIVER HEADLIGHT
NOT FOR REMOTE START, FOR REMOTE START INFORMATION
Starter 2 PINK/BLACK (+) IGNITION SWITCH HARNESS
Anti-Theft Type GM PASSKEY III® ANTI-THEFT SYSTEM
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense PINK (+) IGNITION SWITCH HARNESS
Tachometer WHITE (-) AT IGNITION COIL
Speed Sense YELLOW/BLACK (AC) AT ECM MODULE UNDER HOOD ON DRIVER FENDER
BLACK PLUG PIN #57
Parking Lights LIGHT BLUE (-) AT VEHICLE LIGHT SWITCH
Brake Lights LIGHT BLUE/WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
IGNITION MUST BE ON FOR THIS WIRE TO TEST
Reverse Lights DARK BLUE (+) AT BCM MODULE UNDER DRIVER DASH
Horn TAN (-) IN HARNESS AT STEERING COLUMN
ALSO AT BCM MODULE UNDER DRIVER DASH
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock WHITE (-) AT BCM MODULE UNDER DRIVERS SIDE OF DASH
THIS WIRE UNLOCKS THE REAR DOORS ONLY, WILL REQUIRE A 5-WIRE SET-UP IN EACH FRONT DOOR TO INTEGRATE OR A SERIAL DATA MODULE FROM AN ALARM MANUFACTURER
PowerLock LIGHT BLUE (+) AT BCM MODULE UNDER DRIVERS SIDE OF DASH
THIS WIRE LOCKS THE REAR DOORS ONLY, WILL REQUIRE A 5-WIRE SET-UP IN EACH FRONT DOOR TO INTEGRATE OR A SERIAL DATA MODULE FROM AN ALARM MANUFACTURER
i would use a DLPK module
DLPK (2009 Chevrolet Silverado)
W2W
CC-Heated Seats Activation
DL-Arm Factory Security
DL-Disarm Factory Security
DL-Door Lock Control
DL-Door Unlock
DL-Driver Priority Unlock
PK-Immobilizer Bypass-Data No Key Req'd
RS-RAP Shut Down (Remote ACC Power)
RS-Tach / RPM Output
SS-Entry Monitoring ALL Door Pins
SS-Entry Monitoring Driver Door Pin
SS-Entry Monitoring Front Door Pins
SS-Entry Monitoring Hood Pin
D2D
CC-Heated Seats
DL-Door Unlock
Hope helps.
Mar 31, 2011 | Chevrolet Silverado 1500 Cars & Trucks
My son has 2009 silverado extended cab with 22000 miles, he left his amp on and the battery went dead, so I took my 2009 silverado and tried to jump it. When I turned the key on the display lit up but once...
When a battery is totally dead a jump start will take time. The dead battery needs to come back up to at least 8 volts before it will start. Leave you jumper cables hooked up for a half hour or so and try again. What you really need is a battery charger, even once you get it running the alternator is going to have to run for a really long time to fully charge this battery. Also, you should be able to connect the amp to go off with the deck, it's a little more work but it is well worth the effort.
Jan 22, 2011 | 2009 Chevrolet Silverado 1500
This morning upon trying to start my 2009 Chevy Cobalt, The key would not turn and acted as if it were the wrong key.The remote start, started the vehicle just fine, so I do not think its a problem with...
do you have other keys . try it if you do . have you try rockin the steering wheel back n forth while trying to turn key. is shifter all the way in park. will the key turn it to acc, position?
Nov 24, 2010 | 2009 Chevrolet Cobalt
Car turns over but won't actually start.
put key in the ignition and try to remote start it while sitting in it. if it starts, use the brake to shut it down then take the key out and try it again. if it will not start the second try they need to install the bypass module, or install it correctly. not recommended to be done by your self. you can take it to a shop that works on them but they will likely charge you for their time.
Oct 19, 2009 | Excalibur RS-310-EDP Remote Start Keyless...
Remote Starter with Keyless Entry Logo
181 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
John
John
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
