Question about Vacuums
Irobot roomba discovery modle
The vacuum inside the bin dosnt work when bin is attatched to bot, but it works when power supply is hooked up to the (+) (-) terminials. wht should i do
  • 75 Answers
This is a rather common problem, contact the Roomba Corp.
Posted on Feb 23, 2008
Amber flashing light while on home base. New, pulled tab, placed on dock. First time said charge err1, took out battery and replaced. Now just flashes amber. Is this correct?
Your manuals are here. Flashing lights must be covered. A quick look at the site says flashing red is bin full. In fact, I found it. Flashing Amber is CHARGING.
Roomba 600/500 Battery and Charging Overview On some robots, the CLEAN light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged . homesupport.irobot.com homesupport.irobot.com/.../roomba-600%2F500-battery-and-charging- overview LabeledSupport ... clipped from Google - 12/2015 iRobot: Customer Care - Roomba 700 Anatomy homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy images?q=tbn:and9gcss8oogw3vmcv_uom0z_pxoi9q5tq9n4aqrcwbsxn0zd1blfvnacictdbyn iRobot: Customer Care - Roomba 700 Anatomy Solid Red = Battery Discharged; Amber Pulse = Charging; Solid Green = Fully Charged; Quick ... The battery indicator blinks when there is a charging issue. homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy LabeledSupport ... clipped from Google - 12/2015 iRobot Roomba 500 Series Battery Maintenance homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib iRobot Roomba 500 Series Battery Maintenance Roombas "CLEAN" light should pulse red/amber while charging. ... Green - fully charged; Amber - partially discharged; Red - nearly discharged; Flashing Red - ... homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib LabeledSupport ... clipped from Google - 12/2015 Roomba 400 Series/Discovery Battery and Charging Overview homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview Roomba 400 Series/Discovery Battery and Charging Overview Your Roomba's POWER light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged. homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview LabeledSupport ...
iRobot Owner Manuals and Quick Start Guides
Dec 31, 2015 | Roomba Vacuums
Roomba Discovery SE Bagless Robotic Vacuum: My Roomba battery charger has no lights and does n...
use a multimeter to test if it is actually putting out a charge. Is this a regular roomba charger with the green led on top? And it just doesnt light up anymore? If so then the pack is dead. replace it.
May 16, 2010 | iRobot Roomba Discovery SE Bagless Robotic...
Roomba dirt in filter but NOT in bin
possibly the vacuum fan is plugged up or not spinning fast enough to pick up heavier items. disassemble the back canister and clean the fan chamber.(THis is one area of regular maintenance). if it is all clean then try to replace the motor. The other possiblity... You have one damn clean house. :)
Sep 03, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
My roomba discovery will not operate on the clean or max buttons, will do the spot clean and goes forward then circles. Turns itself off and plays a little da do da do do do do. I have emptied tray,...
If your Roomba goes "uh-oh", beep-beep-beep, that's a 3-beep error code, indicating that your vacuum motor is stalled. Remove the grill from the outside (back) of the dustbin and make sure that the impeller (looks like a fan) turns easily and is not clogged with dirt. Then try to run the robot with the bin ON but the grill OFF. You should be able to tell whether the vacuum impeller is spinning. If not, you'll need a new bin. You can confirm wth customer support by calling 1-877-855-8593.
Jul 16, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
My Roomba Discovery doesn't appear to hold a charge
cor2an,
That sounds like a classic battery failure in the Roomba discovery series. There are sensors inside the battery pack that go bad too. Either way...it's not very practical to repair the battery....the best shot you have would be to order a replacement battery. You just pop the old one out and then put the new one in.
They are available from iRobot for $69 at this link: http://store.irobot.com/product/index.jsp?productId=2799714&cp=2804606.3358509&ab=CMS_AccSuper_Roomba400_102308&parentPage=family
There are sources of less expensive (about $35) Genuine iRobot quality batteries also. You could try www.RoboticVacParts.com at this link: http://cgi.ebay.com/OEM-iRobot-APS-battery-Roomba-400-4XXX-Discovery_W0QQitemZ270412120603QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ef5d1821b&_trksid=p4634.c0.m14.l1262&_trkparms=|301%3A1|293%3A1|294%3A30
Jun 21, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
IROBOT - CLEANED USING WATER - NOW DOESNT WORK AT ALL
you probably got the switches wet ,make sure all the water is out,then take a blow dryer to dry out the electronics
Feb 13, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
Roomba works but the dirt stops at the filter. New filter did not help.
The robot dirt tray has a vacuum motor to assist the dirt flow from the floor brushes. Yours is not working. recheck the connections on the dirt tray.
Aug 18, 2008 | iRobot Roomba Discovery SE Bagless Robotic...
Replacement screw roomba discovery brush
You can try some large hardware centers. Maybe they can match one up for you.
You can visit the link below and contact them if you want to order original parts, and if your unit ever needs to be serviced.
http://homesupport.irobot.com/cgi-bin/irobot_homesupport.cfg/php/enduser/home.php?clear_cookie=1
Jerry G.
Jul 07, 2008 | Roomba Robotic Floor Bagless Vacuum
I robot won't go forward
HAVE YOU TRIED OPENING UP THE ROOMBA AND CLEANING THE SENSORS?
Jul 06, 2008 | iRobot Roomba Discovery SE Bagless Robotic...
Irobot moving slowly
Try running th roomba with the dust bin removed to see if the main brush is turning, if not it could be an issue with the gears being stripped in the brush motor assembly or inside the brush compartment holder. If the gears are fine the brush motor itself may be blown. A new one is about $30.00.
May 01, 2008 | iRobot Roomba Discovery SE Bagless Robotic...
Vacuums Logo
51 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
