Question about Motorola Mobility Moto Q
Motorola q shuts itself off
My morotoral q shuts itself off
this is not due to a low battery as it is fully charged
it's not due to a software update as it has the lattest software update
any ideas how i can fix this
    Sergeant:
  • 260 Answers
I am afraid there can be a plethora of possible problems here. But I recommend trying a few things before going to your dealer. First, try removing the battery and replacing it. Second, I recommend quality battery care. Read the owners manual for how to maintain your battery. It may be helpful to allow your battery to run all the way down. Then recharge it to full (but do not overcharge your batter). Then run it all the way down again. Third try replacing the battery or having a second one handy. Fourth, try removing any programs you added and then reinstall them one at a time. Finally, IF ALL ELSE FAILS try a Master Reset. Remember that a master reset will delete everything you have added to your phone. To do this you need to go to Start, System Tools, Master Reset. Good luck.
Posted on Jun 19, 2008
I have an Apple iPhone 3GS with the 4.1 software. The iPhone keeps switching itself off. I would lock the screen and want to unlock it a couple of minutes later and then it is switched off. The battery...
Software glitch or battery issue. Backup and save all your data and music. Then reboot and re-update the software. If that still don't fix it, then you got a problem with your battery power management. The system thinks the battery is low and automatically shuts off to preserve the contents. Try charging battery fully overnight with the power off and see if that helps. If not, then you will have to see the Apple dorks at the Apple store for a replacement phone. Cheers.
Nov 12, 2010 | Apple iPhone Smartphone
Moto Razor V3i Software Problem
Hi , u cud either get it done from moto service center it wud jus cost u around 350 Indian Rupees, or Make sure ur battery is charged fully, try to update the firmware using motorola phone tools.
Note: While updating the software of phone , all the phone memory contents wud be lost make sure u back it up.
Hope it helps u.
Sep 04, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Keeps Shutting OFF (battery shows fully charged)
Have you tried to update the phone's software/firmware? You should be able to get the update software from Sony Ericsson website and follow the instruction. Hope it helps.
May 24, 2009 | Sony Ericsson TM506 Cell Phone
E260 4gb sansa not turning on
some may be due to low battery power or due to software problem...while charging stop once the charge gets full,...dont overcharge the battery,,,,,,the battery life gets reduced
Jan 03, 2008 | SanDisk Sansa e260 MP3 Player
Motorola slvr unable to power on
wait until the phones battry get fully chrged working with a fully drained battery is bad to phone as wellas battery itself
Dec 04, 2007 | Motorola Mobility SLVR L7 Cellular Phone
"Fatal Application Error"
This problem may occur if the user allows the batteries to discharge to a state where the MobilePro must shut itself down. This state may cause the system storage memory to become unstable requiring a "hard" reset after the system has been fully charged again. Failure to perform the hard reset may result in data loss at a later time. The user manual states that if you receive a message indicating that the batteries are low, immediately connect the AC adapter to the device. The solution is to perform a "hard" reset after fully charging the internal batteries, and then install the service packs, software updates and user software.
Sep 14, 2005 | NEC MobilePro 780 Pocket PC
Why do I get the error: "filesys.exe has performed an illegal operation"?
Sep 14, 2005 | NEC MobilePro 900c Pocket PC
Sep 14, 2005 | NEC MobilePro 880
Sep 14, 2005 | NEC MobilePro 750
Open Questions:
boot_c_03.08.00r_mpap Paul Sager from FixYa has posted a solution for this problem previousley (as below). I have tried the Motorola and Verizon sites (tried the store as well) and the software is not available to flash the phone. Do you know of a site that would still have it available? Or can this question be sent to Paul to further comment on it? All I want to do is recover the phone numbers, notes and calandar from the phone via Activesync or Windows. Paul Sager 2335 Solutions July 14, 2010 I can help you with your Motorola Moto Q. What has happened is that the firmware of your phone has become corrupted. When this happens your phone will no longer finish its boot sequence. This is a very common situation with many phones: in fact, much of what I do here at Fixya is explain how people can fix their MP3 players, GPS and phones by reflashing the firmware. The good news is that if you take your phone into your carrier's store, they can reflash it for you right there (if they have a competent tech handy.) If you are comfortable with computers etc, you can also do it yourself. Your computer will communicate with and fix your phone, even though it doesn't seem to recognize it right now - I've seen this many many times. My only warning for you is that if you are going to flash your phone yourself, you need to get the correct firmware from motorola's site for your carrier. I just downloaded the Verizon firmware as an example - Motorola's website has about ten different carrier firmwares for their MotoQ phone. I hope that helps.
Oct 09, 2012 | Motorola Mobility Moto Q
See all Motorola Mobility Moto Q Questions
Motorola Mobility Moto Q Logo
133 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
