Question about HP Compaq Presario CQ50-110US Laptop
Connection to network but no internet connection any ideas?
  • 1,428 Answers
Ensure that the signal is excellent by changing your position if it is a wireless connection.
Posted on Jan 31, 2010
Not connecting to the internet
Router ?
Problems authenticating a router in a computer is a common problem when installing a router or if your internet service gets disrupted. It is easy to solve and only requires a few steps to fix. A router forwards data from a computer to a computer network. The network can be between multiple computers, such as one would need in an office. The network can also, and more usually in households, used for connecting to the internet. Open "System Preferences" in the Applications folder in Finder. Open "Network" under "Internet and Wireless." Click "Advanced" and select "TCP/IP." Select "Renew DHCP License" and click ok. Attempt to connect to the internet. If the internet is still not connecting, restart the router and try the steps again. b> For non-Macs b> Open "Wireless Network Connection" from the wireless tab at the bottom of the screen. Select "Change Advanced Settings." Choose the "Wireless Networks" tab. Choose the wireless network you want to connect to and select the "Properties" button. Under the "Association" tab, make sure the Network Authentication has the proper security level chosen. Enter your network key if your security code is anything other than "Open" or "Shared." Select OK and try to connect. Go Back to "Wireless Networks" tab -> "Properties" and click on "Authentication" tab and un-select the "Enable authentication for the network" selection if the network key is still not authenticating the router. Select OK and try to connect.
Hope this helps.
Jan 14, 2013 | Computers & Internet
My pc is not connected to the Internet. My home network is working fine, laptop..xbox...wiifii...etc. Just the pc is not connecting. Already switched out the Ethernet cable. Other than replacing the...
1) tell us do ur pc is directly connected to your internet modem or its using wifi??
2) Do your network card is installed properly and after connecting it to router is it getting any ip from router or not?
3) Do you know that it is reaching till your router?
Sep 07, 2010 | Acer Computers & Internet
Hello, iam ishan I am using G Five U800 Mobile with idea Network Provider.I want to connect internet my laptop computer HOW CAN I DO THIS? IS THERE ANY POSSIBILITES PLS ...
you can use mobile to connect to the internet.
Initially your network provider must support internet connection facilities .
Then your mobile must contain inbuilt modem and driver for that modem.
The G five mobile does not have a inbuilt modem so it is not possible to connect to internet
Mar 12, 2010 | Computers & Internet
I am trying to install the d-link ethernet switch to my virgin modem 256. I can succesfully get either my PC or my laptop connected to the internet but NOT both at the same time. Any ideas how to solve...
You need two cables one from the Modem into the internet port on the back of the router and another from Computer Port 1 into your computer then you should be able to connect via wireless. If not get onto the router CP and check the settings.
Jan 06, 2010 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
My labtop keeps on disconnecting from the internet it says something like unable to connect the preffered wireless network and I dont have any idea why.
Open "Networks".
Click "View Available Networks".
Click your preferred wireless network.
Click "Disconnect", to prevent your computer, in the future, from connecting to that non-functional network.
Choose a different network.
Click "Connect".
Nov 08, 2009 | Dell Inspiron E1505 Notebook
I cannot get my Dell Inspiron Laptop to connect with Belkin router, any idea why??
Are you trying to connect to the wireless network on the laptop ?
It is very simple.
first you will need to make sure that you have all the wireless settings of the network.
Click Here for more info about wireless network connections
Oct 17, 2009 | Belkin (F5D5231-4) Router
Network and internet connection problems
Please run system restore to factory setting. Restart the system and hold down F11 button till you hear a beep.
That will return the system to its factory position. It will definately resolve your aches about connecting.
rate this fixya
Apr 15, 2009 | HP Pavilion dv6768se Notebook
WiFi
Go to Configure Wireless Networks
select the wireless after say connected doble click that connection when open the another screen with network name verify you network name is correct, in Connects To: verify select The internet. In the next tab select you Authentication and Data encrypted as you have in your router. and type your network key. select ok. Verify en the next tab if your select USe 1EE... and select EAP typel, select ok. Verify do you have W up in your PDA.
Lucky
Mar 07, 2008 | Siemens SX66
Internet sharing
Hi, Could be done. On the Dell XP - 1. Activate your Internet Connection Sharing. Go to Control Panel, Click on Network Connections, right click on your Local Area Connection, Properties, Advanced tab, check Allow other network users to connect through this computer's internet connection. In Home networking connection, choose "Local Area Connection", OK; 2. Back to General settings, click on Internet Protocol (TCP/IP), click on Properties, tick Use the following IP address: IP address 192.168.0.1, Subnet mask 255.255.255.0, Default gateway 192.168.0.1, if you know ITT DNS use them otherwise tick "Obtain DNS server address automatically." You have to connect the DellXP with the DellVista using a crossover networking cable. On the Dell Vista- 1. In your Network Connections, right click on your Local Area Connection, Properties, click on Internet Protocol (TCP/IP), click on Properties, tick Use the following IP address: IP address 192.168.0.2, Subnet mask 255.255.255.0, Default gateway 192.168.0.1, if you know ITT DNS use them otherwise tick "Obtain DNS server address automatically." The above method will also work with peer to peer wireless networking. It might also facilitate connection if you enable auto-detect proxy settings in your browser. There are other methods. This is also better explained at Microsoft support Hope this be of help/idea. Post back how things turns up or should you need additional information. Good luck and kind regards.
Sep 30, 2007 | Computers & Internet
HP Compaq Presario CQ50-110US Laptop Logo
47 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
