Question about HP LaserJet 1300 Printer
Paper wrinkles on one side when comes out of printer
Hi i have printing problem when i was gave print after output on print right hand side in some lines in black form contiuos print on paper.
Posted on Feb 04, 2010
Why does my printer produce wrikled printouts
Your paper feeder is only working on one side causing the paper to try to go sideways. This will wrinkle the paper just like it is fed in crooked.
Jul 19, 2014 | Dell 1160w Mono Laser Printer
Paper wrinkles when printing
You can try these following solutions:
If the paper does not completely eject, press the paper with folded side paper button, then open the printer cover and remove the paper. Also, check the Paper Size setting in your application or printer software.
If the paper is wrinkled when it comes out, it may be damp or too thin. Load a new stack then try to print again. You can also try to check the printer alignment and the printer setting.
Feb 11, 2010 | Office Equipment & Supplies
After paper jamming in printer paper now wrinkles
there still may be a piece stuck somewhere in the unit. Remove printer cover and check inside to see if there is anything at all still in there
Jul 29, 2009 | HP Officejet 5610 All-In-One InkJet...
My Dell 1100 keeps wrinkling and tearing the paper
Depending on wear the tear is at determines the issue. The wrinkling paper and the look of your printer sounds like some sort of fuser issue. Recycled paper is more likely to wrinkle and the grain can cause paper to wrinkle as well. The Long grain paper is up and down the sheet and short gain is side to side on a sheet of paper. If your printer is on a long grain setting and you have the pages coming out sides ways or vice versa then your print outs can wrinkle.
Jun 22, 2009 | Dell 1100 Laser Printer
Paper jams and wrinkles every time
If you slide open the area in the back of the printer where you remove the paper jam, you can see two plastic tabs (one on the left and one on the right). They should both be free for the paper to pass. Look around to see if there's any other obstruction.
See if the paper will print without the wrinkle with the back piece open. If it does, there's an obstruction in the paper path such as a paper clip or money. Has happened.
If there is no wrinkle coming from the back when it's open, there there problem is the paper moving through that last piece. Look for an obstruction (First Paragraph of this).
Dec 04, 2008 | HP LaserJet 1200 Printer
Paper jamed or wrinkled
Dear
this is the problem of hot roller replace it paper jam problem will be resolved.
Nov 25, 2008 | Samsung ML2251N Laser Printer
Paper completely wrinkled
NONERIGHTNOW, HP makes great laser printers, the commercial LaserJets typically last 8+ years without much more than an occasional maintenance kit to keep them going. The 1000 series printers are quite another story, they are designed for the low end printer market and just can?t take hard usage over time. The typical culprits with paper wrinkling are heat from the fuser or paper problems. -In the paper tab of the printer driver make sure the correct media is selected. This controls how hot the fuser gets which also causes paper curl/wrinkling. -Buy some fresh HP grade paper, improper humidity, coatings and storage can also cause problems. -Try a new HP cartridge. If you still have no success starts a print job and turn off the printer while the paper is feeding. What you want to do is try to freeze the wrinkling process so we can identify what area is causing it. Post this information. Also open the rear, straight through door; also let us know what happens. Let us know how it goes and please don?t forget to rate this posting.
Jan 19, 2007 | HP LaserJet 1300 Printer
HP LaserJet 1300 Printer Logo
226 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
