Question about Kohler Cimarron 2-PC Elongated Toilet with EcoSmart Technology, Left-Hand T...
Tiled bathroom floor. Went to install toilet
Tiled bathroom floor. Went to install toilet (new)..wax ring didn't compress like I thought it should, actually didn't feel like anything sqeezed on it. Would the tile raise the height to where the toilet wouldn't seat...do you have to use an oversized wax ring?
  • 105 Answers
Hi, the tile is supposed to go under the toilet flange (the thing you put the wax ring on), very common "oops", can be rectified by placing another wax ring right on top of the first on. best to make the first one a "horn type" wax ring, then put the plain one (no horn) on top of first and try to smoosh it on just enough to stay in place so when you install toilet it doesn't move,.....cheers!
Posted on Jan 31, 2010
HELP! How do I fix a toilet that will not flush? I suspect the wax seal has not sealed properly due to tile floor being added and raising the level of the toilet. Could this be the problem?
I would have used low power jet wash with pipe cleaning attachment when the toilet was off, I know karcher do a good 1 but there are cheaper alternatives. The last toilet I fitted had a large rubber type seal between the wate outflow pipe and the out pipe of the toilet that fitted over the base of the pipe. I have never seen a wax type seal as you describe, admittedly I have not changed many toilets, but I would have changed the seals when the tiolet was lifted. Hope this helps
Mar 04, 2017 | Home
How to change toilet bowl
Shut off water to tank and drain tank by flushing , then use a sponge to soak up any left. Disconnect water line, then 2 of 1/2" nuts at base of toilet ( floor ) . Lift toilet off, clean old wax off toilet and flange at floor, and install new wax gasket. Set toilet down straight and aligned with gasket and flange as well as studs. Make sure toilet is all way down on new wax gasket ( sit on it and move around a bit until toilet feels steady on floor ) then put nuts washers etc back on and snug it up. Don't tighten too much and snap base, just good and snug.
Aug 03, 2012 | Home
Toilet leaks into floor and lower level ceiling, no water on bathroom floor.
Either wax ring or sewage pipe is leaking. If you cant open the ceiling from below to look for leak you may have to remove toilet inspect pipe and look to see if it was leaking from wax ring and if it could have gone downstairs without leaking out too. If leak couldn't have come from wax ring the leak must be coming from a pipe in the floor. Find the simplest way to access it to repair it.
Sep 14, 2010 | Toto Round Carusoe Two Piece Toilet, 1.6...
Do you have to put toilet cauking under base of toilet
No, you don't have to, but it makes for a nicer job. The wax ring must provide the complete seal to the sewer and must not leak at all. The use of caulking under the outer edge provides for a neat seal so that water or waste that gets on the floor does not collect under the edge of the toilet where it meets the floor. The caulking can also provide a bit of stability if the floor is uneven and the flange is a bit high, in which case the toilet might rock a little - which could compromise the seal of the wax ring. If a plumber installs a toilet, they will put the caulking down right away because they are confident in their installation of the wax ring and they need to move on. If the floor is a soft material (anything except stone or ceramic tile), then the home meowner might want to wait a couple of days before applying caulking to be certain that they don't conceal a leaking wax ring. If your toiled does rock a little, give the caulking a day to dry before using it again. On the other hand, if you do have a hard surface floor, it's a good idea to apply the caulk to the bottom of the toilet before you put the bowl down to give a bit of cushion where the porcelain bowl meets the hard floor.
Aug 23, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
REMOVAL OF TOTO AQUIA TOILET
first shut off water and then flush the john. this will remove most of the water. for water remaining in tank us a sponge or similar to remove remaining water. find where toilet bolts to floor and remove these bolts or nuts. then pick whole toilet from floor, there should be a wax ring under toilet, replace wax ring when putting back in. when putting back in just push down on toilet to squish wax ring and bolt to floor, turn on water and check for leaks. good luck
Apr 16, 2010 | Toto Aquia II Dual Flush Toilet
Kohller Rialto toilet, can not get toilet to seat properly, leaks from bottom. Tried 3 different wax seals and it still leaks. Toilet was purchased online from Home Depot, and cannot return to store. Same...
If you tried regular sized wax rings and they failed to seal, try using a double thickness wax ring, maybe the space between the floor flange and the toilet exceeds a regular wax ring size. If the floor has been re-tiled and the floor flange was not adjusted this could be your problem, anyhow good luck!
Jan 24, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
Toilet on uneven floor
I believe that I qualify... over 300 toilets installed in the past 15 months!!
I would go with the wax rings... but I would press the ring into the base of the toilet before installing the toilet....that way you are sure to have a good seal to the toilet....
If you actually read the directions, the manufacturer will tell you to press the wax ring onto the toilet....then install it onto the floor drain.
I guess that a PLAIN wax ring placed on the floor drain (since it is recessed) before placing the rubber-sleeve equipped ringed toiled is a good safety measure... I have done that an it work about 37 times out of 40.
Good question - BTW.. and well worded. THANKS for being specific and precise!!
Dec 31, 2009 | Jacuzzi BK37959 White Era?? Two-Piece...
No toilet flange
Go to a hardware outlet(Lowe's, HomeDepot, etc.) and ask for a commode drain extension that can be placed over the existing and bring it up to the level of your floor. I also like the wax rings with the cup molded in. These can be doubled up also but not as reliable as the extension.
Eric
Dec 30, 2009 | Jacuzzi BK37959 White Era?? Two-Piece...
Leaking toilet
check the seal between the tank and the toilet.tighten it as necessary. (not to tight! you will crack the ceramic). Mkae sure the tank is square to the toilet.
also the water inlet connector.
Nov 24, 2008 | Saniflo 013/003/005 Sanibest Toilet with...
Kohler Cimarron 2-PC Elongated Toilet with EcoSmart Technology, Left-Hand T... Logo
359 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
