Question about Tools & Hardware - Others
My furnace is in a 1994 manufactured home. It is
My furnace is in a 1994 manufactured home. It is a Coleman Evcon 7900/D series. On several recent occasions when the house has become cold even though the thermostat is turned up above room temp, I have found the following situation: When the thermostat calls for heat, the small ventilation / purge fan comes on, after a short period the glow plug or igniter starts and becomes bright orange, then the main gas valve opens and the main buner lights as would appear to be normal, however after about one minute, when the main blower should come on, the control panel clicks about twice and the gas valve shuts off and the fire goes out. After that the same sequence repeats itself over and over, with the main burner shutting off before the main blower comes on. The small ventilation fan is running all the time while this is going on. The way I have been able to get the unit running as it should is by rapping on or slapping the various components, resetting the thermostat, and everything seems to work normally for a while. I have carefully checked all visible wire connections and they are all clean and tight. I thank you very much for any ideas that you might have that will help me determine which component is intermittently malfunctioning.
  • 105 Answers
I think it is your fan because when it is supposed to come on (when hood is hot enough) it won't,...and when the gas valve doesn't get the o.k. from the fan that it is working, the unit will shut it self off so it doesn't over heat. Gas boilers and furnaces have alot of safety things like this,....see if the fan has an oiling place on it. I've seen control panels cause this too,....replace whatever is cheapest first. good luck
Posted on Jan 31, 2010
Testimonial: "Thank you very much for your response. That makes sense and narrows it down. I will keep an eye on it. The fan motor when running is quiet & smooth"
Coleman Evcon model DGAT070BDE the red light keeps flashing what does it mean
http://www.cpsc.gov/en/Recalls/2012/Fire-Concerns-Prompt-York-International-to-Reannounce-Recall-of-Gas-Furnaces-for-Manufactured-Homes/
Sep 04, 2015 | Coleman Heating & Cooling
Do I need a outside cooling unit for a Coleman 7900 Presidential lll gas heat and cooling unit
Yeah, youd have to look at the model on the Indoor coil box, furnace will be setting on top of it. Youll need the model off that coil box to get the correct tonnage of the outdoor condensing unit, you can go 1/2 ton smaller on outdoor for greater efficiency.
Feb 12, 2015 | Coleman Heating & Cooling
Coleman EVCON GAS FURNACE ugab075bua
Would need to have a serial number to determine.
Oct 13, 2013 | Coleman 7990-319p Evcon Gas Furnace...
Coleman evcon furnace is noisy loud
To many possible answers to this. A description of the noise will help to diagnose the problem.
Jan 28, 2013 | Coleman 7990-319p Evcon Gas Furnace...
How do you replace a pressure switch on a coleman evcon furnace
The pressure switch is mounted with 1/4" or 5/16" self tapping screws and has 2 wires and a rubber tube that attaches to the induced drafts assembly.
Jan 25, 2013 | Coleman 7990-319p Evcon Gas Furnace...
I have a Coleman Evcon Elec Furnace with the added AC Unit. The blower works great with the AC but only on & off with the heat, what could this be?
Replace the sequencer...which is just a series of snap disc relays that are staged. The first snap disc should kick on the first element & low speed of blower. Depending on how many elements you have, determines how many snap discs are on the sequencer. It could be a 2,3,4, or 5 stack. Generally the coil is 24 volts.
Dec 01, 2012 | Coleman Evcon Furnace Control Circuit...
Mobile home furnace
you probably have a bad thermostat if it wont shut down id replace the thermostat first and then have the thermocoupler checked...replace the thermostat
Aug 20, 2008 | Heating & Cooling
I want to add an air conditioner to my coleman evcon EB17B unit in my manufactured home. What would I need to get.
A kit is available through a Coleman Dealer sized according to the furnace you presently have installed. It should be installed by a contractor.
May 17, 2008 | Heating & Cooling
Tools & Hardware - Others Logo
705 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
