Question about Magic Chef CGR3725 Gas Kitchen Range
My Majic Chef Oven model CGR3760 is taking a long time to heat up. It took 1 hour to reach 450 degrees! Not sure if this might be a thermostat issue or burner. Penny
Turns out it was the ignitor going bad but not totally gone. We are waiting on a part to come it to replace it. Thanks. By the way, this is a neat service, keep up the good work!
Posted on Feb 02, 2010
Both oven glow bars stay lit oven takes very long time to heat up and is 25 degrees off from true temp using a oven thermometer. takes over an hour to reach 450 and has a gas smell when unit turned on. any...
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. Sometimes the igniter glows but still does not reach the correct amp draw to fully open the gas valve. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Dec 11, 2010 | Viking VGIC305-4B Gas Kitchen Range
My new oven doesnot cook lasagna through evenly.
Hi Angela,
There are many different possibilities that can cause this issue. From a faulty thermostat, to placement of the food in the oven, or not giving the oven enough time to pre-heat before placing your food item in the oven to be cooked. I have found that on many ovens they can reach well over 450 degrees during the pre-heating cycle. I had a customer who called because her new oven was burning her brownies on the outside and they were not done on the inside. The customer told me that she would wait for the pre-heat signal beep(oven is ready) before putting the tray of brownies in the oven. When I initially checked the oven tempature using a fluke meter and a thermocouple at the center of the oven I found that the oven was close to 460 degrees when the beep went on to indicate the oven is ready! So that is why she was burning her brownies. It took another 10 minutes after that for the oven to stabalize and keep the tempature at 350. So you might want to give your oven 20 or 30 minutes of pre-heating time before you put your tray of Lasagna in the oven. Always make sure to place the food item at the center most part of the oven. And if you are cooking several trays make sure to stagger their position on each rack so they are not right above/below each other. The positioning is important because it can interrupt the natural flow of heat in the oven. So if you let it pre-heat for a half hour and are still having the burning issue then you should have the oven tested for proper calibration to make sure the thermostat is working properly.
Mar 10, 2010 | Garland H283 Gas Kitchen Range
Oven goes on off on off on off and it does not get
This is a common symptom caused by a problem with the ERC (Electronic Range Control / Clock). If you can send us the ERC, we can rebuild it for you.
Bruce
www.fixyourboard.com
Aug 09, 2009 | Magic Chef Kitchen Ranges
15 yr-old GE electric oven takes over an hour to preheat to 450
After jiggling the lower burn element the oven heated up in the normal time. Perhaps a connection had come loose.
Feb 14, 2009 | GE JEM25 Microwave Oven
Built in oven takes hours to reach desired degrees set.
There may be a problem with either the door seal or the thermostat.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails, you can download GE owner's manuals and installation instructions here in case you don't have yours.
Once you look it over, if you still have a problem,
GE Customer Service is here and they should be able to help you check it or send service if you have a problem.
Feb 01, 2009 | General Electric PT970 Microwave Oven
Magic Chef oven won't heat up past 200 degrees
You obviously have one or more elements not working, you need to test same, and replace as req'd.
Dec 12, 2008 | Magic Chef Ovens
MAJIC CHEF DOUBLE OVEN NOT WORKING
I just had a model 976-4CX put in...I have no manual...I'm trying to find one. I thought I had a problem with the element, dial or thermostat. The bottom worked, but the top stopped working. There are 2 timers with dials next to the clock labeled Start and Stop, and Push for Manual. Come to find out my problem was solved by adjusting the Start and Stop dials and/or pushing in for manual!?!
If I had a manual I'd know how these timers worked.
Nov 29, 2008 | Magic Chef 9522 Electric Double Oven
Inacurate temp
The follow suggestions apply if you are at sea level, or a bit above. If you are in the mountains, you'll have to compensate for altitude issues. You need an accurate thermometer to be spot on. One way is to use an electronic thermometer. Another is to set the oven to 217 degrees, insert a small pan of water into the oven, with a metal tray or pie tin on a lower rack to catch spills and see if it eventually boils. If the water didn't boil, you can adjust the temperature upward in  5 degree steps (see your owner's manual for details). If you've lost your manual, you may be able to go on-line and get a pdf copy of your manual.If the water does boil, you know your oven is accurate within 5 degrees. You can then proceed to re-do the experiment at 212 degrees, if you wish. Then you may use the data to adjust the oven temperature.
Dec 03, 2007 | Maytag MGR6772 Gemini Gas Kitchen Range
Oven heating problems
I'm afraid you might need a new thermostat. The only other thing you might check is to make sure that your 'vent' is not blocked with a pan or tea kettle etc., but I'm pretty sure it is a thermostat.
Jun 09, 2007 | Maytag CWG3100A Gas Single Oven
Magic Chef CGR3725 Gas Kitchen Range Logo
140 people viewed this question
Top Magic Chef Kitchen Ranges Experts
paulcarew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
