Indesit wg1185 washing machine
No drum action , brushes .ok . has remco 5506 module fitted . when looking for spares it seemes remco 5504 fits same machine ! can anyone enlighten me please . indesit wg1185 washer
  • bigstefanuk Mar 11, 2008
    Does anyone know where to get a cct for this W1185 .indesit washing machine. I have the same problem (the tub won't rotate). What I want to do is to bypass the timer and connect power directly to the motor (this wil eliminate possible switch problems etc). But it has several connections probably for the two speeds and reverse. Or does someone know the generic connections for a washing machine motor.
5 Suggested Answers
  • 641 Answers
SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Posted on Aug 16, 2007
  • 641 Answers
SOURCE: how to fit drive belt to zanussi washing machine
Does it a new belt or the existing one ?
Posted on Sep 04, 2007
SOURCE: Indesit wg1234t wont spin
I also have this common problem with my WG1234T. - The pump still works but the motor no longer spins. The brushes have a ton of life left in them. I tested the motor by connecting directly to power and it spins so the fault is most likely with the 'controller' unit - i.e. the switch/timer device behind the program knob. This device was not really working perfectly before and sometimes caused erratic working but I think it has now died altogether. I'll try to get it to bits to fix it as I don't believe you can still get a replacement controller for this machine.
CJ.
Posted on Sep 17, 2008
  • 6277 Answers
SOURCE: no supply to hot water valve. require circuit
I'm so sorry but this forum does not, nor is in a position to, supply any type of manual (service or otherwise), parts list, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained probably over many years.
Manual
You will need to type into your search engine/web browser '(make model number) washer service manual' and you may be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct but often it will supply only to registered agents.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Oct 23, 2011
The message flashing says 'door' what do I do?
You have a problem with the door switch interlock.
Indesit WIDE 146 (DE) Washing Machine Spares ' eSpares
www.espares.co.uk > Home > Washers & Dryers > Washing Machines > Indesit
  1. Cached
Items 1 - 10 of 60 - Universal stacking kit suitable for most washers and dryers measuring 60cm across More information. In Stock. Stock Number ES187394.
Get Indesit Washing Machine Spare Parts ' eSpares
  1. Cached
  2. Similar
Genuine Indesit washing machine spares including Drum lifters, Indesit ... Start your Indesit parts search by selecting your washing machine model number from ...
Indesit Washing Machine WIDE 146 (DE) Spares - indesitspares
www.indesitspares.co.uk/washing-machine/wide-146-de.../catalogue.pl?path...
  1. Cached
Indesit WIDE 146 (DE) Washing Machine Spares ... Fits models with serial number from 30127.0001 Please Note the above serial number changes does not ...
Indesit Washing Machine IWDE 146 UK Spares - indesitspares
www.indesitspares.co.uk/washing-machine/iwde-146-uk-f084074/catalogue.pl?...
  1. Cached
Indesit IWDE 146 UK Washing Machine Spares ... This part fits the following models: WIL133UK, WIL133UKCO, WIXE127UKV & Does Not Fit Mod. .... If you have just replaced the door seal on your appliance then you may need this retainer ...
Indesit Ecotime IWDE 146 Built-in Washer Dryer - White
www.indesit.co.uk/appliances_i/Washer_Dryer_IWDE_146/pid_F084074UK/42.do
  1. Cached
  2. Similar
Rating: 8.5/10 - ‎19 votes Indesit Ecotime IWDE 146 Built-in Washer Dryer - White, ... News & Offers; Service & Spares. Service · Spare Parts ... IWDE 146 reviews · Ask-an-owner ...
Washer dryer no wide 146 Google Search
Mar 24, 2017 | Washing Machines
My fisher and paykel smartdrive wont agitate or spin but it pumps the water out it , when i spin the drum there is a bumping sound. can i get into the drum part to see if anything has gotten inside?
That is fault code 130
130.(10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
Jul 31, 2012 | Fisher and Paykel Fisher & Paykel Washer
10 year old miele 300 washing machine jumps to
Most likely brushes. Fit carbon brushes part no.4297411 as they are less then half the price of the brush module Part no. 4229779.
Jun 15, 2010 | Miele 300 Front Load Washer
Drum dose not turn belt is ok no smell or dust
Fit new motor brush kit if well worn cost about £25 ...
Nov 13, 2009 | Washing Machines
Replace broken drum paddle on indesit wixl123 washing machine and were to purchase part
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the laterwashing machines often come loose and come off altogether. They can bereplaced. call them lifters. You usuallyinsert a small screwdriver down one of the holes (it's the 3rd one on ) andgently press down while sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
On hotpoint, creda, Ariston ,indersit and someother makes see video
To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
Huge selections of lifters are available on thewebsite DrumPaddle lifters
Oct 19, 2009 | Indesit W 123 Front Load Washer
Drum not turning
If it fills and pump works, then it can only be the motor or module, there is no sure way of determining which it is without trying to fix it with new parts.
You can look at the module to see if it has blown a track, if it has, then the moor has caused the prob.
Please rate my solution.
Thanks.
Jul 21, 2009 | Hotpoint WMA40 Front Load Washer
Indesit wdg1295 W
aproximate price £22.00 +p&p delivery this week if in UK.Need to now if it is a CESET motor 3 types fitted.Will only fill hot on 90 degree wash.If a problem fit Y piece connector.
Oct 12, 2008 | Indesit W 123 Front Load Washer
Indesit 2000 (washer/dryer)
hi there first remove the back panel and check belt has not jumped off failing that remove the motor and check that the carbon brushes have atleast 12mm of carbon left on them any less than that and they will most likley need replaced, if you still have no drum action after this you will need to replace the speed control module located next to the motor.
hope this is of some help murdozzz.
Dec 09, 2007 | Indesit WA 115 Front Load Washer
Washer won't agitate
this sounds like it is a relay on the module (main pcb) if the carbon brushes have been fitted correctly then there is a fault on the module, these items are replaced as a unit, i would also look to see if the machine has a capacitor fitted, this also could have the same effect and would be a much cheaper repair to start with, a capacitor is normally situated at the top where the mains wire enters the machine, its normally about 2 inches long and 1 inch round with 2 wires from it, work with safety unplug before doing anything
Sep 09, 2007 | Bosch WFK 2401
Continually spinning
indesits dont have carbon brushes they have a module which controls everything to your tomer if this is faulty or your timer then its not worth doing too much in money to replace get a hoover or candy same machine just ones the uk model and the other is the us model dont go for hotpoint though because indesit own hotpoint now and there changing the carbon brushes to modules which is a big mistake alot dearer to replace then the carbon brushes but maybe thats why there doing so customers have to buy another washer check the price by going to indesit customer support web site but i always keep customers away from indesit due to that module some hotpoints are still the carbons but some arent cheaper to buy a slight damaged from a washer repay shop they usually have damaged at a fraction of the price save at least £125 per washer or buy a repossed one may off been used at the most 10 times nothing wrong with them and you will save £200 plus m8
Aug 23, 2007 | Indesit WA 115 Front Load Washer
Washing Machines Logo
156 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
