Question about Car Audio & Video
How do you wire the speakers into the amp its two 12 inch kicker comps i need to know how to wire them into the amp a diagram would be best
  • 2,926 Answers
What model receiver is it?? What model amp is it?? How old are these units: (Receiver,amp and speakers).
Posted on Jan 31, 2010
I have a lanzar vibe pro VBP251 2200 watts and two 12" kicker comp subs. What do I set the amp on
You need to figure out what ohm capacity is of the amp and the speakers. It then comes down to wiring.
Mar 02, 2015 | Kicker Car Audio & Video
2-12 inch kicker comp 4ohms each to conect to a interfire a700.2 amp best wire setup so i dont keep getting a protection led when volume i increased...thanx n advance.
Turn the gain down and try that, usually 25-40 is all you want.
Also make sure the AMP is well ventillated, or it will overheat and cut off...
Id no - go, then wire it without a bridge, two wires from each channel to each speaker.
Jun 17, 2014 | Car Audio & Video
My kicker 12 inch cvr's arent hitting as hard as they should
amps and wiring kits are very optimistic on the output. If you want proper wire, buy some welding cable "0" or "00" guage. That solves the power delivery. Put a 1 Farrad (or more) capacitor near the amp, that solves the surge power issue. Make sure the box is suitable for the subs. Lastly I'd say do some research and find the right amp that can deliver the clean, huge current required to move some serious air!
Jan 28, 2014 | Kicker Comp CVR 12 x 12 Car Subwoofer
How do I properly wire 2 12 inch 40 cwr122 subs to a Kicker 12cx1200.1 mono amp
Need to know the resistance of the speakers you are wiring, are they 4 ohm or 8 ohm speakers? Is this for car or home audio? What resistance does the amp show it is capable of handling?
Oct 13, 2013 | Kicker CVR12 Car Subwoofer
2 kicker cvr 12's in prewired kicker box with 1 wire terminal, kicker cx1200.1 amp. Whats the best way to wire this combo?
Well you really can't run both speakers on one term. because you will over heat the amp , unless your amp is rated at twice the capability of your subs , Then if so , Try positive to one sub , then neg. to the other sub , then bridge the remaining positive to the remaining negative terminal , But it is really best to get a two channel amp for your subs !!!
Sep 23, 2013 | Kicker Comp CVR 12 x 12 Car Subwoofer
I have a comp s 12 2ohm kicker and a comp vr 12 dual 2ohm kicker how do i wire these to stay at 2ohms to the amp
you can wire them to be at 2ohm load you need two of the same speaker. its is very bad on the amp to run like that and you will not get a good bass sound because one will over power the other sound wise
Mar 23, 2013 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
What's the best way to wire a 12 inch kicker CVR
Ok, first you need to have at least ten gauge wire cause the amp needs agility of juice. Next you want to find a good ground to frame of the car (if its wrong you'll hear road noise through speaker.) Next look on the fire wall and find the terminal that has other wire coming to it (one from positive to the amplifier on battery the rest out top other you want to put an inline fuse to amp.and have ground write other side of the cart than the power. run write to amp then to your speaker I believe I made it is simple for you as possible good luck
Dec 07, 2011 | Kicker Car Audio & Video
How do i wire a 8 ohm kicker comp 10" sub inside the box? and what is the best way to get more bump with a 600 w mtx amp and kicker comp 10" sub?
Ok, for an 8 Ohm sub, it is advisable to get another 8 Ohm sub. wire them in parallel down to a 4 Ohm load. You would wire both + wires together, and both - wires together to yield a 4 Ohm load at the amp. Majority of the amplifiers on the market are designed to give more power at a lower impedence, or Ohm load. You just have to make sure that your amp will take a 4 Ohm load. Without knowing the model of the MTX amp, I can't give more advise. However, this should be able to give you and idea of where to start. The main problem is that you have a single 8 Ohm sub in the Kicker Comp.
Apr 30, 2010 | Kicker CompVX CVX104 Subwoofer - 10" Dual...
I need to know how to bridge a a 4 ohm 15 inch sub down to1or2ohm
Hello solo7908,
With a single 4ohm DVC sub there are only two possible wiring solutions, parallel the voice coils for a final 2ohm load or series the voice coils for an 8ohm load. In your case, you want to wire them in parallel, both positives and both negatives connected to the amp terminals.
Here are the diagrams: (-) to (-) and then to the amp - (+) to (+) and then to the amp. Impedance = 2ohms.
Hope this helps.
Jun 06, 2009 | Kicker CompVR 12" Subwoofers/Enclosure...
Mono amp
well first check ur wireing next the amp is turned down or just bad amp let me no if that helps
Sep 26, 2008 | Kicker CVR12 Car Subwoofer
Car Audio & Video Logo
16 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
