Question about Panasonic PT50LCX63 50" Rear Projection HDTV
I want replace broken screen on on Panasonic Rear Projection TV Model PT50LC-14 from a non-working PT50LC-13 (BULB WENT OUT) model. I want to know whether these models are compatible and Step-By-Step instructions to replace the screen.
  • 2 more comments
  • Mujahid Mohammed Feb 01, 2010
    Thanks for the link. I would call the tech support number to find out the compatability questions. I still need to know the step-by-step instructions, as how to swap the screen from another similar tv.
    From the specifications on both the models, I noticed that pt50lc14 has LCD panels 0.7" Poly silicon TFT LCD panel x 3 compared to 0.9" on pt50lc13. I don't know whether that would be issue. Please advice.
    Thanks for your help. I hope those service manuals would guide me in the right direction.
    Will let you know the result.
    Regards
    Regards.
  • 10,515 Answers
Is the problem Fixed?
If needed any assistance, let me know.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 02, 2010
    Sergeant:
  • 380 Answers
I can get you service manuals for both of those model numbers. Email me at XPxAxBxLxOX@comcast.net and I will bounce back the manuals to you.
Posted on Feb 01, 2010
  • 10,865 Answers
Hello. The best place to get the answer to your compatiblity issue will be directly from the technical department at panasonic. here is the private link to allow you to ask them directly.
http://www2.panasonic.com/consumer-electronics/support/?cm_sp=Homepage%20Support-_-Get%20Support%20Light%20Box-_-Go%20To%20Support%20Home%20Link
Regards, Joe
Broken mirror for panasonic tv model pt47wx54j
A regular mirror will not work correctly---best bet is Google the model number with "mirror" as some sell mirrors and if that fails call Panasonic to see if available, part number, cost and where to order it.
Apr 08, 2012 | Panasonic PT-47X54 47" Rear Projection...
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
Picture on tv went dead. How do I know if it's lamp or ballast or both?
open it on the bulb hatch remove it it will be broken to look at it usually like a normal light bulb would be ballast requires a meter to confirm it needs replaced
Dec 21, 2010 | Panasonic PT-50LCX63 50" Rear Projection...
The tv has power , the volume comes on ,but no picture,just black screen. The red change lamp light has been on for some time,and it is still on
I believe this is a DLP set. There is a single high power bulb that shines thru the dlp chip and onto the screen. My old Panasonic 55" (forget the model) had the bulb access on the front left side-1 phillips screw to remoce the door and another to pull the light assembly. Replacement bulbs are available plain or in the assembly-your choice. Just google your make and model plus DLP bulb and you should be good to go- I paid $85 for the bulb alone- order 2 as the life span is much shorter than what panasonic claims- there was even a class action lawsuit over this issue that covered about 10 different set.
Dec 19, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Have a Pansonice HDTV 1080i. Model PT-47WX42F. Turns on but the
You DO NOT have a DLP set, you have a conventional rear projection set with 3 picture tubes in it. If your led's are blinking then you have a problem loading down the power supply. I recommend you call a service company.
Jul 15, 2009 | Panasonic PT-47WX53 47" Rear Projection...
PT-53wx53 replacement bulb
Your model doesnt have a bulb. The PT 53WX53 is a progressive scan CRT projection TV. You have 3 CRT Tubes, Red, Green And Blue. Hope this helps. If you need more info let me know.
Jan 30, 2008 | Panasonic PT-53WX53 53" Rear Projection...
TV Image not bright enough
leagreen
I'm not sure if my answer will help much, but it is free. My experieence with this site is that without paying for premium service, you won't get much help.
I had a similar problem with a different model Panasonic projection set.I got no answer on this site, but I did from an outside repairman.
Turn your color all the way down. If it looks black and white it is probably not a bulb problem. If you see a tint (blue, green, red) over the screen, it probably is a weak bulb.
The entire bottom front of my model was held on by velco and could be pulled off.
Behind this was a removable black panel. Behind this were adjustment screws for the three bulbs. This will probably only help temporarily if the bulbs continue to weaken, but it might buy you some time as the replacement bulbs are quite expensive. Good Luck
Oct 29, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT50LCX63 50" Rear Projection HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
