Question about Canon Office Equipment & Supplies
When I turn on my Canon ip5000 printer, the print head makes three quick ''clack'' sounds, stops, and then the light flashes, alternating between green and yellow. The print head doesn't move through its normal warm-up routine. When I open the lid (as I would if I were about to change an ink cartridge) the print head remains in it initial right-hand position and refuses to move out into the center. My local Canon repair company will charge me $45.00 just to walk in the door. Does it seem that this problem might have a quick fix or at least a small enough problem that the authorized dealer's repair cost would still be less than the cost of getting a new printer? Please advise. Thank you.
  • 1 more comment
  • krop0507 Jan 31, 2010
    Rylee,
    Thanks for your prompt response. I am presently soaking the print head overnight.
    The fact that I have about $100.00 worth of ink both sitting in the machine and standing by in reserve is what makes me not want to be too quick to get a new printer. I will have to hope that this works.
    I don't know if the following info will help to shed any light as to the source of the mystery but after I removed the ink cartridges and the print head, the printer still acted the same way.
    If I push the print head carriage to the center or far left side and then turn the printer on, the print head carriage first moves over to its typical right side position, makes its normal jog back towards center, then goes back to the far right side when it makes the "clack, clack, clack" sound and then dies.
    The light then flashes in a green-yellow sequence three times and then repeats.
    I will let you know tomorrow if the cleaning of the printer head resolved the issue.
    Thank you,
    Kevin
  • krop0507 Feb 01, 2010
    I would hope that at this point I don't need to reiterate my aforementioned Canon Prixma 5000 printer problem as i would like another's take on my problem.
    I did soak the printer carriage overnight as Rylee suggested but the problem remains the same.
    I have already looked into purchasing a new printer that uses the same type of ink, to salvage the $100.00 in ink that I still have, but apparently Canon doesn't make printers that use those model number ink tanks anymore.
    Any other suggestions would be greatly appreciated.
    Thank you
  • krop0507 Feb 03, 2010
    This solution seems to have gotten the closest to the source of the problem. Once I took the machine apart, however, I realized that the cure wasn't as obvious to my untrained eye as I had hoped it would be.
    With my fingers coated in ink, I declared the patient dead and consigned the carcass to the land fill. As with so many other electronics and small appliances these days, the investment of time and money for repairs is just not worth it. Unfortunately.
    Thank you for all of your time and helpful thoughts.
  • 583 Answers
Something is interfering with the travel of the print head. If you remove the power from the unit, can you move the print head manually (don't use excessive force). If you can't, using a flashlight and small mirror, look at the entire travel path of the print head, including any tracks, belts and the platen. Since it is making a clacking sound, it seems it is trying to move, but it can't. Let me know what you find.
Posted on Feb 02, 2010
  • Mark Tidwell
    Mark Tidwell Feb 02, 2010
    From the information you described, this has nothing to do with your print cartridges or print head. There is a sensor that detects when the print carriage returns to the full right position. This sensor is not functioning and so the servo tries to continue moving the carriage to the right, but it can't, thus the clacking sound as the servo slips from synch. The circuitry picks up a problem as a carriage path issue, when it is not really getting the signal that it has returned. This sensor can be optical or mechanical. It probably is mechanical because the optical, if obstructed, would always sense the carriage in the far right position. It you feel like taking the machine apart (you may be able to see the sensor (a small switch) that activates (or is pressed) by the carriage on the right side. Check to see if the switch is broke or maybe has fallen out of place. There could also be a broken "plunger" or other item on the carriage that is broken that activates the switch.
    Brigadier General:
  • 4,090 Answers
Usually when a printer is banging its head against the back wall the problem is a faulty head. But before rushing out and buying a new printer, take some sewing machine oil apply it to a cloth and wipe the drive rails. Even a quick spray of WD 40 close to the carriage often resolves the problem for a while. Worth the try My IP5000 did this twice, but has been good for 6 months now. Thanks for using FIXYA
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Start with cleaning the print head. To clean the print head take a hot water towel with the printer unplugged and the cartridges out, clean it till the time you see there is no ink residue on the towel. If still the issue is not resolved then soak the print head in hot water then leave it overnight, then try it again. If still it won’t help then instead of spending $45 for a service repair call you can buy a new printer in same price. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jan 31, 2010
  • Rylee Smith
    Rylee Smith Jan 31, 2010
    Thanks for your reply Kevin, if the issue is not resolved you buy a new printer of same make and model# so to avoid loosing $100 ink. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
Why doesn't paper feed after "print" instruction? Printer merely makes a mechanical noise and states "paper out" condition.
Hello.
There are lots of reasons why this would happen:
Foreign object (could be very tiny)
Any power lights flashing ?
Paper feed rollers may need cleaning - try (from Canon Support):
1. Ensure that the printer is turned on. If any paper is loaded in the printer, remove it.
2. Select which roller to clean, the auto sheet feeder's or cassette's, by pressing the <Paper Feed> switch on the printer.
3. Hold down the <Resume/Cancel> button; when the Power lamp flashes green three times, release the button. The paper feed roller will rotate as it cleans itself.
4.. Repeat step 3 twice.
5. Load three or more of A4 or letter sized plain paper in the auto sheet feeder or cassette, as selected in step 2.
6. Repeat step 3. The paper that is loaded in the printer will be fed through the printer and ejected.
7. If printing problems persist, repeat step 6 up to three times.
Could be a hardware error and the printer would need servicing - still under warranty ?? If so, return to Canon for repair or replacement.
Hope this helps.
Jul 05, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
Five flashes pause then a further 5 flashes
This error mean "non installed or defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number is QY6-0057.
Nov 25, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Instructions to clean print head of Canon iP5000 printer, please.
Try first with cleaning tests on maintenance mode.Make sure all cartridges are not empty.If not help try manually cleaning.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.
Nov 23, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Had paper jam. Now PIXMA IP5000 shows service error 6A00 and light alternates between green and orange 12 times. Have tried unplugging, turning off,etc.
Print head might be stuck. Try opening the lid and sliding the cartridge tray over to the left. Check to make sure there is no piece of paper left jamming it. While you are at it, clean the base pad by dabbing with a piece of paper towel to remove excess ink. You may also want to remove the Print head itself and then reattach. Make sure there is no gunk buildup. Hope this helps.
Sep 07, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Pixma IP5000 printing pink
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Power light is blinking and it is not printing
It is possibly a jam warning or "printer cleaner head full" warning. Check your manual for what the canon warning lights mean for your particular unit.
A quick fix you can try. Unplug your printer, press and hold the power button and plug it in while holding the power button, it should reset your printer...
If the blinking still persist, have a qualified technician take a look at it...
Mar 10, 2008 | Canon PIXMA iP5000 InkJet Photo Printer
old marine
old marine
