Question about Air Tools & Compressors
My compressor runs fine until it gets to about 100 psi. It then sounds like it labors hard, and then blows the circuit breaker. Any suggestions? It is a Crafstman 6 hp,k 30 gal, 150psi max single cylinder oil free.
  • 234 Answers
Never assume anything; check your pressure guage to make sure it is reading correctly. If a guage gets faulty, it could be showing less pressure than before, but everything else is the same, therefore the pressure is the same as always but the guage says different. If guage is good and 100 lb shows just as there is 100 lb in the tank, then maybe your electric line is not sufficient capacity and the motor starts to labor because it is pulling more energy than the line can produce and therefore everything heats up and the breaker pops. Have you moved the compressor or had a need to change the electric line and maybe it is too long or toosmall to handle what it did in the past ? Or, maybe the motor windings are old and getting deteriorated, thus allowing the motor to lose power and without the extra power to fight the pressure as it builds, the motor and line strain to work, and the breaker pops. Or, maybe the inlet and outlet valves on the head are weak and cannot hold the pressure in check as it builds in the tank thereby forcing the motor to work even harder against the pressure it already built-up; in this case, the head needs to be removed and new valves and springs replaced. Most compressor companies offer a valve kit just for this purpose. Goodluck, Macgvior
Posted on Jan 31, 2010
My porter cable 200 psi air compressor will not run
The curcuit breaker on the motor. Probably a little round button that's about the size of a screw head.
Jan 04, 2013 | Porter Cable Air Tools & Compressors
I have a 80 gallon 5 hp ingersoll model #2475N5 serial #30T900896. Im using 10-3 wire on 40amp doible pole breaker. as its building air when it hits @50 psi it slows down. if I pull the pop off valve on...
T wo suggestions. 1- check the check valve located in top of the receiver tank by letting the unit pump up to 50 psi. shut it off and loosen the copper tube at the HP cylinder. if no air blows out the check valve is good. If it's bad it will blow until it empties the tank. If the check valve is bad replace it. 2- Tighten the drive belt. If neither corrects the problem remove the guard and rotate the pump by hand. If it's hard to rotate you have a pump problem.
May 08, 2011 | Ingersoll Rand Ingersoll-Rand 80 gal. Air...
I have an older model Sears Craftsman air compressor, 1 hp, 100 psi, twin cylinder. Model 106.154541. The compressor comes on fine, but when the pressure gets to 40 psi or so the belt starts to squeal,...
Could be the bearing in the pully wheel rides on,,not the belt,,,While its running spray some belt dressing on belt to see if its the belt,,,while running get a can of wd-40 with long nosel attachment and spray the armeture that tures pully when you spray it if its the bearing it will stop makeing noise momentarly, than come back again than as you spray it it will stop as long as you spray. BE CAREFUL. Bearings wear out when old,,,like us!
Mar 11, 2011 | Craftsman Air Tools & Compressors
Compressor runs until overload release valve opens (pressure at 130 psi) and then air escapes until pressure lowers to 100 psi..Then motor begins to restart, but will not , due to 100 psi and kicks breaker...
There is a check valve between the compressor and tank, and there is also an 'unloader valve' which blows the pressure off the compressor so that it starts under little load. I think your check valve is stuck open and the unloader valve is blowing tank pressure off.. and when the compressor tries to start it's starting against the pressure in the tank.
So check/replace/thaw the check valve and you'll be good to go. It's generally at the tank where the line from the compressor head goes into the tank, it'll be between the two somewhere.
lp
Jan 02, 2011 | Senco PC2001 2 HP 4 Gallon Electric Hand...
I have a Campbell Hausfeld oil type direct drive 7 gallon compressor. It often works fine but it frequently locks up until the internal circuit breaker cuts off the electricity to the motor. When the...
In our shop we have found the conditions you describe are almost always attributable to the power supply. First, never run a compressor on an extension cord, you are always better off running longer air lines. If you absolutely have to run an extension cord use a least a 12 guage cord no longer than 25 feet. If possible plug the compressor in as close to the circuit box as possible. Lastly the circuit the compressor is plugged into should be rated at least 15 amps, 20 amps is recommended for most compressors. Low amp lines cause the motor to overheat trying to get enough power and usually blow the circuit breaker at the motor and not at the circuit breaker. Lastly, use only compressor oil in the pump and make sure it's not overfull. This will also cause the motor to work harder and trip the circuit breaker.
Dec 17, 2010 | Campbell Hausfeld 2 - Gallon Direct Drive...
Freezer begun tripping our 20 amp breaker for some reason
ok hi there i viewed the specs for this freezer
http://www.truemfg.com/catalog/servlet/com.apsiva.servlet.HomeServlet
this unit must be plugged into a 120v outlet with a 15amp circuit breaker dedicated (nothing else should on this circuit) so all by itself. you have to check the voltage outlet where you plug in. you must have at least 115v or better (125v the most) if you have less then 115v it will cause damage. ok you went and checked all this out and everything is 15amp with 115v or better and it still trips breaker.
ok the running amps is 6.8 amps so to blow the circuit you need 15 amp which is too high.
i suggest you call a refrigeration guy because he will be able to determine if the problem is the compressor (which has a 4 year warranty with truemfg.com only in the USA) or something else. Usually but not 100% what would make a freezer like yours to blow the fuse is the compressor. if it overheats it will do this, if there is a sudden high pressure within the system it will do it, if you have a condenser fan that is not running at proper speed it will do this...
the problem cannot be pin pointed understand please... you have to babysit it, watch for changes in the refrigeration system and the running compressor amps, voltage drops ( this will cause high amps) etc...
Refrigeration is not easy and alot of tech stay away... so those who stick it out make money cause you have 2 choices: buy another one and pay big bucks to get it fixed. at least see if you can find someone to come over (for like $40 - $60) and tell you exactly whats wrong with it... whew... hope this was helpful and not confusing...sorry
Apr 03, 2010 | True 19 cu. ft. / 538 liter Commercial...
When the breaker goes the on/off switch as a hard clicking sound that disappears once the breaker is re-set. The breaker is re-set but the compressor still won't start and the on/off switch still has the...
1. Disconnect the power or put the circuit breaker to
off position.
2. Disconnect the motor connection from the on/off
switch.
3. Put the circuit breaker to on position and put
the switch to on position. If there's a hard clicking
sound even without the motor. Then, it needs to be
replaced.
4. If there's no hard clicking sound, then, your motor
must be grounded or partially burned winding.
This must be corrected to get your compressor
running.
Oct 24, 2009 | Black & Decker Dewalt #D55155 2HP 4GAL...
Air Tools & Compressors Logo
73 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
