Question about Microwave Ovens
Sharp Microwave R-206 800W
Hi, The lamp has gone, how do I change it please.
  • Ron Turner Feb 22, 2008
    Very helpful thanks, just waiting for the new lamp that has been ordered.
    PS: Great site.
  • 958 Answers
Open the housing, look where the bulb is located, unscrew the holder of the bulb and if the b.ulb is screwed at the holder, replace it. if the bulb is attached to the holder then replace the whole bulb assembly. i hope i was able to answer your problem
Posted on Feb 19, 2008
What light bulbs are for a Sharp R-1502 carousel microwave?
Hi,I would try (,you can put the model in and it should give you the right lamp for your microwave,all the best.
Feb 05, 2018 | GE Microwave Ovens
MODEL R-395Y sharp carousel microwave not working. All power outlets are fine. Please help, cheers lyn
I was unable to locate a service repair manual specific to your microwave; sorry.
You'll must likely have to find a Sharp service and repair center.
I've attached a link that contains the user's manual to your has the phone number and address of Sharp; perhaps you can phone them and ask where a repair center is located.
This is the diagnostic check list Sharp recommends before calling for service:
Please check the following before calling for service:
1. Does the display light up?
2. When the door is opened, does the oven lamp come on?
3. Place one cup of water (approx. 250 ml) in a glass measure in the oven and close the door securely. Oven
lamp should go off if door is closed properly. Press the INSTANT COOK/START pad once.
A. Does the oven lamp come on?
B. Does the cooling fan work?
(Put your hand over the rear ventilation openings.)
C. Does the turntable rotate?
(The turntable can rotate clockwise or counterclockwise. This is quite normal.)
D. After one minute, did an audible signal sound and COOK
indicator go off?
E. Is the water inside the oven hot?
If "NO" is the answer to any of the above questions, please check your wall socket and the fuse in your meter box.
If both the wall socket and the fuse are functioning properly, CONTACT YOUR NEAREST SERVICE CENTRE
Sharp Carousel 395Y Operation Manual And Cookbook
Feb 22, 2017 | Sharp Microwave Ovens
Light in microwave does not light up
Possible that the lamp has fused or burnt out, the controller output is absent or that the switch is faulty.
Please check lamp, check the ouput if the microwave works as it is parallel to this circuit.
For tips to identify the parts check :
Aug 30, 2011 | Sharp Microwave Ovens
The microwave oven has completely gone dead Sharp r-1501c. Yesterday the light was on. I went to turn the light off and to put something in the microwave and it lost all power. I've checked the outlet...
It may be the control panel. What ever you do, don't send the control panel to William Miller. He ripped me off, and I have to dispose of my microwave because he never returned my control panel.
If yours has gone dead completely, it's more cost effective just to replace it. I bought an LG to replace mine.
Mar 08, 2011 | Sharp R-1501 Microwave Oven
How do i change the bulb in a sharp R-350F
Replacement of the lamp should be carried out by a qualified appliance repair service.
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its position is adjacent to the vent holes that it shines through.
If you feel confident, disconnect it from the mains power, remove anything in the cavity.
Remove the microwave cover. Purchasing a new replacement lamp will be useful as it will give you an idea of what it looks like. Locate the dead lamp remove the lamp and fit the new one. Replace the covers. Plug it back in and try the lamp by opening the door.
Hope this helps.
Feb 07, 2011 | Sharp Microwave Ovens
HELLO,I have a sharp microwave R314FS every thing works just fine but it appears that my light bulb has blown out is it possible that i can change it myself,if so it look like i would have to remove the...
Looks like you just have to take off the outer cover. From the parts diagram I looked at this looks like a counter top unit. If so, unplug the unit and then remove the outer cover and then locate the lamp and replace it. Looks pretty easy to get to.
Oct 04, 2017 | Sharp R-314FS Microwave Oven
Change the bulb on a sharp R 450 D microwave
Remove mains power, remove the case from the microwave and the lamp is near the door catches above the transformer.
Remove the lamp and fit a new one.
Hope that helps.
Nov 06, 2010 | Sharp Microwave Ovens
Microwave not heating!!!!! Probably Magnetron malfunction. New replacement Magnetron cost, fuse blown out and cost of internal oven lamp?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Troubleshooting Tips
Oct 25, 2010 | Sharp Microwave Oven Microwave Oven
Microwave Ovens Logo
135 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
