Question about Car Audio & Video
What are the colors for the wireing on a gmc radio
    Problem Solver:
  • 19 Answers
Red is switched power (only has juice when key is turned) yellow is constant power, black is ground, blue is accessories (amp or e.q.) dual grey, dual white, dual and dual others are for speakers..(usually the one with the marking is the positive side). I hope this helps.
Posted on Feb 01, 2010
Door speaker wiring diagram for 2002 sierra
2002 GMC Sierra C1500 Car Radio Wire Color Codes
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Amplifier Location: Under the center console.
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Dec 20, 2012 | 2002 GMC Sierra 1500
Where is the accessory/ignition hot wire
Ok so the wire color is red i believe, but if your trying to install an aftermarket radio this wire will not work... for some reason this wire only runs .8v instead of 12v so your going to have to tie it to your veicle wire(yellow) and tern off your radio when you shut off your car, or tap the Fuse box for an ACC wire.
Feb 28, 2012 | 2006 GMC Canyon
Steering wheel radio wires, i need a wire color diagram to steering wheel for the aftermarket radio i need to know the wire colors that controls what.
The wires that control the radio from the steering go to the Body Control Module (BCM), not directly to the radio. The BCM sends data over the serial bus to the radio.
Sep 18, 2011 | 2002 GMC Envoy
What's the radeo color code for 2002 GMC sonoma
have to get code from dealer for security purposes he gonna ask you the radio serial numbers or the vin number
Feb 13, 2011 | 2001 GMC Sonoma Extended Cab
Wire harness to switch from stock stereo to cd player will not fit the wires that are supposed to? so what wires are the speaker wires
Not sure I understand your question. Did you buy a harness adapter for GMC, or are you trying to just cut the connector off the factory radio and solder it to your CD player? If the latter, below is the color code for your factory wiring.
1994 GMC Sierra C1500 Car Radio Wiring Schematic
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Nov 20, 2010 | 1994 GMC Sierra
1989 GMC Wiring Question
Red is power when switch is turned on. Orange is power all the time (runs the clock and radio presets when vehicle is turned off). Black is ground. The other wires are for the speakers and there should be 4 wires. You only have 3 remaining wire colors so there must be one missing. 2 wires per speaker=4 wires. Check again and add to this post.
Nov 15, 2009 | Car Audio & Video
Need color codes for radio in 2002 gmc yukon denali
2002 GMC Yukon Car Stereo Wiring Guide
May 23, 2009 | 2002 GMC Yukon Denali
Factory radio wiring color codes
Here ya go. enjoy!
May 14, 2009 | 2002 GMC Sierra 1500
I need the color codes for a 1988 GMC Sierra stereo.
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Dash
Car Audio Rear Speakers Size: 5 1/4′
Car Audio Rear Speakers Location: Rear Doors
Mar 03, 2009 | 1998 GMC Sierra
Parrot to GMC Sierra setup.
here,
When I did this truck I had to go to the amp under the center console. Good luck
#510564: 2007 GMC SIERRA C1500 2DR TRUCK
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery ORANGE (+) RADIO HARNESS
Accesory (CLASS 2 DATA) (+) RADIO HARNESS
THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE. RUN A WIRE TO THE FUSEBOX FOR SWITCHED POWER. THE ACCESSORY TURN-ON AND AMPLIFIER TURN-ON ARE CONTROLLED BY THE CLASS 2 SERIAL NETWORK.
Ground BLACK/WHITE (-) RADIO HARNESS
Illumination GRAY (+) RADIO HARNESS
Dimmer BROWN (+) RADIO HARNESS
Amp Turn On PINK (+) RADIO HARNESS
LF Speaker (+) TAN
LF Speaker (-) GRAY
RF Speaker (+) LIGHT GREEN
RF Speaker (-) DARK GREEN
LR Speaker (+) BROWN
LR Speaker (-) YELLOW
RR Speaker (+) DARK BLUE
RR Speaker (-) LIGHT BLUE
Amp Location UNDER CENTER CONSOLE
Steering Cntrls OPTIONAL
THIS VEHICLE MAY BE EQUIPPED WITH OPTIONAL ONSTAR® TELEMATICS EQUIPMENT. USE AN APPROPRIATE INTEGRATION HARNESS OR INSTALLATION PROCEDURE TO ENSURE PROPER FUNCTION OF THIS EQUIPMENT.
Speed Cntrl OPTIONAL
Radio Security YES
Jan 08, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Car Audio & Video Logo
42 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
