Hitachi PIP problem
Help! My Hitachi is a 42HDS52A. Great TV, except I can't get PIP to work. Is it true that when the main picture is a digital channel, you can't get the PIP from a different digital channel - that it has to be an "air" signal? Seems silly. TV is 2-3 years old. Paid too much for it not to be able to use PIP function. Any help you can give would be appreciated!
  • 2 more comments
  • Foamy64 Oct 06, 2008
    I have the exact same problem. In PIP, my sub picture does not give me the ability to choose an input video source- it only offers "air" as the input. Even if I had an antenna to use with PIP, it wouldnt do me much good after February '09. I have 100% digital Cable TV on the Main picture. I have emailed Hitachi customer service regarding this problem, and I am awaiting their response.
  • Anonymous Oct 19, 2008
    Please Let us know if you hear from Hitachi! You are very right about paying that much for it not to work.
  • Anonymous Nov 09, 2008
    The pip function is working but one of the options cannot be changed from air.
  • touriskinc Nov 23, 2008
    I have the same problem on a 42 inch Plasma. Tried everythng - but cannot get any input from "air". All input work fine on one screen but in over a year have never been able to get any input on PIP.
5 Suggested Answers
SOURCE: Digital Tv is stuck on a channel
I have found the solution at last :)
Put the TV in standby and press these buttons in order
Info, Menu, Mute and Power on.
You will then see a hidden menu, on line 12 select reset
Bingo :)
Posted on Dec 30, 2007
  • 4 Answers
SOURCE: no signal on digital TV
If you are talking about over the air digital channels I would lean toward ant problems
Posted on Apr 26, 2008
SOURCE: My JVC PIP Won't work, pls help!
I was told that in order to view 2 different channels at the same time u have to subscribe to SKYCable and use the digital input instead of the antenna input and the antenna input you will have to use the regular antenna since there is only one tuner in the TV
Posted on Jul 26, 2008
SOURCE: 37" Polaroid LCD TV No signal appears when select channel
I was having same problem, and think I got lucky and found fix.
Try unplugging the TV and waiting 30 seconds, then plug back in.
You will likely get blue screen with "No Signal".
Go to Menu, then scroll down to "Setup". Select "Factory Reset" then hit "Yes."
This did it for me. Wish you all luck.
Posted on Dec 03, 2008
I have a Hitachi 55" rear projection television but it has no picture.
If you get a picture via PIP the set is working, check the usual suspects: on right input or tuner, does a DVD hooked to rear input work, rule out cable or sat box.
It would also be helpful to know the model number,
SD TECH
Dec 05, 2012 | Televison & Video
Signal Problem
When the sound is working and the picture is not it indicates the main power supplies are working but the picture supply is not. The picture supply that powers the projection tubes is a high voltage generator and is very expensive to repair. Not even most tv techs now how to troubleshoot them. So, I cannot recommend you repair it yourself unless you are a trained high voltage tech.
The cost of repair - my wild guess - would be around $300. However, the real cost can only be determined by someone who can make an accurate diagnosis - which will require a hands-on approach the problem.
If you have any other problem please ask me..
Goodluck,
Please don't forget to rate me as fixya..
Feb 09, 2008 | Televison & Video
FV-27KV300 WEGA 27" Sound Problem
adjust the sound IF in the tuner or in the IFblock
May 03, 2008 | Sony FD Trinitron WEGA KV-27FV300 27" TV
Oct 15, 2007 | Televison & Video
Pic n pic
can get my pc n pic to work. it says can not view same channel please clarify problem in more detail thanks
Sep 09, 2007 | Mitsubishi WS-65615 65" TV
PICTURE IN PICTURE TV RCA
The PIP puts a smaller picture on your main picture. Usually, the smaller picture is generated by a second source, such as a VCR. The VCR must be connected to the main cable signal and connected to the TV through the red, white, yellow RCA jacks. The VCR picks the smaller picture whilt the tuner in the TV picks the main pucture. The PIP circuits digitally add the smaller picture to the larger picture. The PIP cannot be used to veiw 2 different channels at once on satellite systems because the satellite receiver sends only one channel to the set at a time.
Aug 22, 2007 | RCA F32665 32" TV
NO Picture in Color except for PIP
have a tech check your tv the color circuit needs to be looked upon.good luck
Apr 29, 2007 | Akai PT5492S 54" Rear Projection...
Hitachi 53fdx20b rear projection color tv with no picture
Reset tv to factory settings refer to your owners manual. If still no picture attach a DVD or video player and test. If still no pic refer to tech.
Apr 08, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Televison & Video Logo
760 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
