Question about Carrier Heating & Cooling
My Carrier thermostat (installed in 2001) doesn't bring the temp up to the set temp (within a couple degrees)...66, not 68. Should I plug the hole in the wall, to protect from drafts that might affect the sensor?
    Scholar:
  • 185 Answers
That seem to be a problem of the air leaks, poor insulation of the building. the obstruction of the heat exchanger.
If it is forced hot air. It could also be that the ducts need insulation too.
Posted on Jan 31, 2010
In the cooling mode for zone 1, why won't the temperature stay as set on the cool setting?
If it 2 degree cooler then that's fine .adjust your thermostat 2 degrees higher so you will get the temperature
Feb 16, 2018 | Carrier Heating & Cooling
We set it at a temreture of 70 degrees but it wont go of when it gets really warm in my house does that mean that the termostat is old or what ????
Does the temp on the thermostat ever get to 70? As long as its at least 2 degrees below it will keep running, until it gets to the value you set. To test place a thermometer on top of the stat and compare the temp to its readout, if its still accurate it should be within 2 degrees of the reading. Keep in mind the location of the stat affects it (away from drafts, etc.) as well as making sure its vent holes are clean and clear, has good batteries and the area around it has nice unobstructed air flow.
Mar 08, 2015 | Emerson 1F80-0261 Blue 2" Thermostat,...
Pilot and burner light then gas shut off model 7900
How many degrees before it reaches desired temp, does it shut off? A thermostat is designed to shut the furnace off a couple/ few degrees before it reaches set temp. It has what is called a heat anticipater, which shuts the burner down, and lets the blower use the remaining heat from the heat exchanger to bring it up to desired temp making it more efficient. If it is more than a few degrees, replace the thermostat. You can jump out the red and white wires to confirm the faulty thermostat. If by doing this, the furnace never shuts down, until you separate the red and white wires. That confirms a faulty thermostat. Hope this helps someone.
Oct 06, 2014 | Coleman Propane Forced Air Heater...
My Dayton 4lz94 greenhouse thermostat doesn't activate at the set temp. But will turn on when temp is about 5 degrees below. Set temp. Is there a sensitivity adjustment to calibrate for activatio
I am having the same problem with my Dayton greenhouse thermostat, this question was posted in the wrong section...but if you find a solution I'd like to know. I am having problems with the heating thermostat as well as the cooling one.
Jan 27, 2012 | Ovens
My sons bike is running at 100 degrees. Bike overheats within 3km of riding. Have checked for leaks and had to replace water/2 stroke tank as had a hole in. Have checked thermostat as well and works...
The bike should be running at 180 to 190 degrees. It would be impossible for your bike to be running at 100 degrees. Your body temp is 98.6 degrees. Engines are designed to run at higher temps for better combustion.
Aug 04, 2010 | Cagiva Mito SP 525 Motorcycles
Temp cycle span from on to off is 32 and 33 degrees respectvly
Obviously the thermostat calibration is out, most manufactures allow a tolerance of + or- 10%, so yours is outside this range.
You can compensate by setting the temperature lower by say 20 degrees, this will then bring it within accepted tolerances.
Hope this helps you.
Dec 16, 2009 | Whirlpool RBS305PDS Electric Single Oven
Problem with new Carrier Infinity 96 gas furnace
carrier infinity 96 furnace went to turn down the thermostat and their was no power to it and the furnace doesnt run
Nov 14, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
My problem is in addition to moisture near some duct outlets the thermostat always go 2 degrees below the set limit .I also have a carrier infinity system installed only 1 yr, had the problem from the...
if you have a mercury thermostat and it is not leveled properly it will turn the temperatyure on and off by a couple of degrees
some thermostats have the capability of running the unit longer than the set temperature
i would recommend calling a local heating and air conditioning contractor and get the unit cleaned and bring up the issue then
Aug 04, 2009 | Heating & Cooling
Carrier Air Conditioner- not reaching set temperature
if it is set to 76 degrees and its 78 in the house its working fine it is suppose to shut off once it reaches 76 but sometimes there is a 1 or 2 degree differential built ini would keep you filter clean and as long as it blows out cold air i wouldnt be to concerned most airconditioners need yearly cleanings though
Jul 14, 2009 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
76 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
