Question about Memorex Televison & Video
Can't get color when playing color movies, picturee is in black and white. sound OK. tv color OK when watching tv only. Visio TV, memorex home theatre vcr. what's the problem.
  • 5 more comments
  • gene_p Feb 01, 2010
    I said vcr on my original complaint but the Memorex is a DVD player. Is their head cleaners for dvd?
    tried a philips laser lens cleaner, did not work. how does one realign the heads?
  • gene_p Feb 02, 2010
    The dvd player is a Memorex model STS71E-R, manufactured in 2006. Serial # EJ210FC
    050220. The TV is a Visio VW32L HDTV40A Serial # LUTDJA0105937 purchased new in Feb 2009. Does this info help?
    HD
    what type of cables do you suggest? rca type cables are what I am now using,
  • gene_p Feb 03, 2010
    My Memorex model STS71E-R dvd player produces color on my RCA model 20F420T Television using the same RCA cable that I was using when connected to my VISIO model VW32LHDTV40A television. The VISIO TV
    I connected my Memorex model STS71E-R dvd player to a RCA model 20F420T tv using the same RCA cable that was used when connecting the dvd player to my VISIO model VW32LHDTV40A tv. Perfect color, only black and white on the VISIO tv. You mention menu, what menu? Is there a different cable for VISIO? The dvd player does not have HDMI DTV capability. Any suggestions? Please be specific. Thank you.
  • Anonymous Apr 01, 2014
    won't play in color--why
  • 3,037 Answers
Any number of problems can cause no color. For example, a very dirty video head, a defective head or even mechanical misalignment to name a few. Try using a wet type head cleaner, they seem to work better for excessive dirt on the video heads which is usually the problem with no color and is the easiest to fix.
Let me know how this works out for you.
Benjamin
Posted on Jan 31, 2010
  • 3 more comments
  • Benjamin Patri
    Benjamin Patri Feb 01, 2010
    Is it a new player?
    Usually it is a S-Video cable that is bad or loose or a PAL/NTSC (video type) problem, which the second can be fixed in the menu usually.
  • Benjamin Patri
    If it isn't a VCR, then it doesn't have heads. Like I said in my previous post, it is either a video cable or the format that the player is reading is off. PAL and NTSC are two different formats depending on where in the world you are.
    You also did not answer my previous two questions which would help me help you.
  • Benjamin Patri
    Benjamin Patri Feb 02, 2010
    Alright, yes that helps, thank you.
    Now have you tried connecting the player with a new set of cables at all? Try doing this then if you haven't. You can get new cables from a local tv or electronics store.
    Also are there any other players or anything else connected to this tv that are having the same problem? Have you tried checking the menu on the tv and dvd player for possible settings that may have been switched in the video format sections?
  • Benjamin Patri
    Benjamin Patri Feb 03, 2010
    I'm just saying to try a different RCA cable to see if that is the problem. Otherwise you may also just want to reset both the tv and the dvd player or check the menu on both of them to see what type of video format that they are set to.
  • Benjamin Patri
    Benjamin Patri Feb 04, 2010
    If you have multiple inputs that you can try to connect the cable to on the tv that is showing up black and white, try that first. Otherwise your tv either has a bad tuner/converter for the input you are on OR you can go into the menu of that tv and see if the video input format can be changed or set to AUTO. Let me know what you find.
After the dvd plays for like 10-15 minutes(when dvd player warms up?) all the colors on the screen turn to black, yellow and purple for the rest of the movie. What's wrong?
I gotta know more clearly about your question, i am going to explain in 'Guide Solutions'
Guide 1: Is it the color just cover the main grid? (Color cover like blocking the others, such as watching 70s TV shows, the colors blocked in black and white.)
Source 1: Audio input problems, your dvd audio input linked with three different 'rops', they are appeared to be push by pressure.
Solution 1: Determine more spaces to them!
Guide 2: Is it the color cover the photon grid? (Color cover at all pictures, each of them doesn't stand the other colors instead of replaced by unique color)
Source 2: Undefined
Solution 2: The TV setting menu seems to b set by specific colors, change it on your own using remote. OR this is a specific part that the DVD need to show the color in unique color (only one)
(No problems, keep watching)!
Jan 22, 2011 | Panasonic Home Theater System System
I am trying to hook up the mvd2016 to a visio tv that is hooked to our cable converter box. I hooked it up, i have the tv but no sound.
your RCA jacks from the DVD player....should be connected to the Vizio a/v 1 in the back of TV (yellow to yellow, red & white to red & white)... now to view using the remote to TV switch to a/v (play a DVD, you should now have a picture and sound)
Dec 19, 2010 | Memorex MVD2016 DVD Player
Why does my dvd player have two pictures with PSCAN displayed across the screen?
The progressive scan it´s for high definition Tv´s and if you´ve got standard tv need to disable that function
Jul 16, 2010 | Memorex MVD2022 DVD Player
Im a girl, & i need help hooking up my ps3 to my flatscreen
ok it should all go into your tv ok? and there should be a row of yellow white red or any order (ON THE FRONT). you should look on the back of your tv or side for alot rows of inputs and each row should be for an different input on your tv like input 1 2 3 4 5 6? you follow? so just match the colors up on the back or side of your tv or front do not hook it up to your cable box..........Ahh i see the cable box is using the yellow one well maybe unplug that while your playing or there would prolly be other (RED WHITE YELLOW) on the back of your tv like i said or on the side
Aug 16, 2009 | Sony Playstation 3 (PS3) Console
Panaonic Home Theatre DVD system only plays movies inblack white
Check the region and picture settings on the home theatre's dvd player, it could be set to put out a component signal, or it could be set to a PAL region rather than NTSC
Jul 06, 2009 | Audio Players & Recorders
Black and White picture when watching TV
Check color syestem of tv,select Auto
Jul 05, 2009 | Televison & Video
Prolem with attached DVD player
u are using composite red,white,yellow. then connect it on video1. as there is only 1 yellow connectore on the tv.
Jan 23, 2009 | Sanyo DP42746 42 in. Plasma Television
Movie playing black and white
the problem sounds like its with the s video connection, try using the composite video input
Mar 27, 2008 | Sony DAV-S500 System
Playing movies in black and white
Use a scart lead to connect it to the TV, that should cure it.
Dec 08, 2007 | Sony DVP-NS315 DVD Player
Color on the T.V. i think is gone
Ok what we need to do here is determine if the picture tube is still good or not??.. If you turn the tv to a station thats has a brighter scene and turn off the color what does the pic look like ??is it Black and white or a certain color overall on the screen??
Apr 02, 2006 | Hitachi 36FX48B 36" TV
Televison & Video Logo
304 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Radames Pagan
Radames Pagan
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
