Question about Canon MultiPASS MP730 All-In-One InkJet Printer
My canon mp 730 has an alarm lit and says wrong cartridge. I tried removing print head and cleaning with alcohol...no luck...put in a different cartridge...no luck. What else can I do
    President:
  • 2,306 Answers
On Canon that error means the printhead is bad, nothing to do with the inks. The translation from Japanese to English made the error confusing. You need to buy a new printhead, the part number is on the side of the printhead and starts with QY6-
Posted on Jan 31, 2010
Mp 730 "Wrong Cartridge" have been using same cartridge w/o any problems
the cartrige has become faulty or the wire strip that connects to the cartrige holder is comming out or a wire in the strip is broke , a new cartrige would then do the same thing
Oct 18, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Remove print head canon mp480
THe print heads are an integral part of each cartridge. When you remove the cartridges you actually remove the print heads. You will need to open the top front panel to access the print carriage which moves left and right over the paper under it. Using cotton swabs you can apply rubbing alcohol to the places the cartridges rest upon and absorb all the dried out ink. Be sure you toss the old cartridges out before you reassemble. If you need to store any ink type printers REMOVE ALL CARTRIDGES and clean off the receivers on the print carriage!
Dec 31, 2012 | Canon Pixma MP480 All-In-One InkJet...
Canon mpc190s imageclass printer error wrong cartridge
Try to remove all ink cartridges, then remove the print head, clean the contacts on carriage with piece of cotton and little alcohol then put all back again.If this not help replace the print head.It's part number is QY6-0037-000.
Oct 05, 2009 | Canon SmartBase MPC400 All-In-One InkJet...
I have a canon multipass 730. It will not work and
Wrong cartridge means that the printhead is bad. Don't take it apart yet, you need a printhead.
QY6-0064-000 about $60.00
Sep 24, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Alarm says "wrong cartridge"
That happens when the print head sensor does not detect the cartridge.
To start unplug printer power cord for two minutes, and see if this can reset the error.
The wrong cartridge error may be caused also by a bad cartridge, therefore ,as first step you need to est a different cartridge, possibly a new original one.
Check also if the cartridge metal sensor inside the ink carriage is dirty and must be clean, in this case use isopropyl alcohol and cotton to clean metal contacts inside the carriage.
If that cannot fix the problem, then there is a lose connection on the wires connected to the ink carriage / print head assembly. TWhen that happens, the wires connected at the back of the ink carriage must be tested and eventually replaced.
Apr 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon MP F50 "wrong cartridge" error
remove all cartridges leaving printhead intact.
close cover, turn off
turn on, let power up, error message should be gone.
open cover, reinstall cartridges
if you cleaned your print head like I did you'll probly
eventually end up getting a new one anyway, due to the color variations
but I can at least print text.
Apr 08, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Canon MultiPass F60
You need to do the print head cleaning. The steps are listed below.
Print Head Cleaning / Head Refreshing
If the printed Nozzle Check Pattern is broken, missing, or a specific color is not printed, clean the print head.
1. Press the <Menu> button on the printers operation panel.
2. Press the left [<] or right [>] arrow buttons to select [MAINTENANCE].
3. Press the <Set> button.
4. Press [<] or [>] to select the cleaning setting you want. Select [HEAD CLEANING] for normal print head cleaning. Select [HEAD REFRESHING] for deep print head cleaning.
Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
5. Press <Set>.
6. Print a Nozzle Check Pattern and perform at least two Head Refreshing if the pattern is not correct.
Sep 15, 2008 | Canon MultiPASS F60 All-In-One InkJet...
PIXMA MP780 "WRONG CARTRIDGE" MESSAGE?
Here is what I did and it now works just fine.I turned off the printer and unplugged the power cord, and unplugged it from my computer. I then removed all the ink cartriges and removed the print Head I got some rubbing alcohol put it on some toilet paper and wiped down the back and bottom of the print head.Plugged everything back in and It now works better then ever.
Feb 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
411 people viewed this question
old marine
old marine
