Question about Frigidaire Over-the-Range Microwave
Fmv156dba microwave oven: microwave stopped working** after baking a potato for 8 minutes. Later discovered that the vent was being held shut. Replaced thermal cutout (60 degree for vent, not the 145 degree for microwave cabin) and the problem still exists. Replaced the 60 degree thermal cutout because the 145 dgree had resistence and the 60 degree one did not, so we figured it was blown. **not working means that you can turn the microwave on and the light comes on in the inside and the timer works, but the table does not rotate and there is no microwaving going on.
  • ltweedy Jan 31, 2010
    I tried to operate the microwave and pushed up on the door - and it works now! THANK YOU! I still have to take it back apart and align the switch properly, but now I know that's all it is!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described this most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common as even the fan is not running & nothing is heating.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jan 31, 2010
Why does my microwave go dead when i bake potatoes 9 minutes, goes dead then comes back
The thermal cutout on either the magnetron or cavity might be opening. Sometimes these cutouts become defective and open at too low of a temperature. Or, you might have an air flow obstruction to the magnetron, or cooling fan problem.
Jun 24, 2016 | Microwave Ovens
I just bought a new rice cooker container for my family to cook rice. It saids use one cup of rice with 1 and a half of water and microwave for ten minutes. Then thought I use 3 cup of rice then must...
you do not need to triple the time when tripling the quantities, example: one baked potato = 8 min, 2 = 10 min,3= 12 min ....
sounds like a triple batch is a bit much for your microwave
so you may want to cut it in half
Feb 09, 2015 | Microwave Ovens
While baking a sweet potato, the potato exploded and caught on fire. The microwave no longer works.a fire bro
I haven't heard of such a thing. You must have cooked it until there was no moisture left in the potato. That would also account for the failure of the oven. It would be the same as no load in the oven.
A thermal protect part is your current problem.
Apr 02, 2014 | GE SpaceMaker Microwave Ovens
Auto Cook not working
If autocook is not working and everything else it, there is an issue with the sensor in the oven that detects the steam, The emission of steam is what triggers that unit to shut off. If it wont cook on any settings then the issue is with the microwave generator not putting out enough power. This could be from a lot of things.
Dec 16, 2013 | Sharp R959SLMA 900 Watts Convection /...
Microwave won't restart after baking potatoes.
If your microwave is not a convection then the moisture most probably is somehow getting to the controls as potatoes has quite a bit.
Oct 27, 2017 | Emerson MWG9111SL Microwave Oven With...
I microwaved something while leaving chinese (metal) container in kenmore 665.61612100 microwave, and it stopped working. What do I do?
The magnetron may have been damaged, the thermal fuse will shut down the microwave to stop further damage and reset itself in 20 to 30 minutes, since that has not happened I recommend a professional at this point.
May 30, 2012 | Kenmore 68361 Microwave Oven
I baked a potato for 10 minutes, burnt it, and microwave oven quit working. Nothing works. Any suggestions for a reset button?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';
Jul 03, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a 3-year old Amana microwave installed above my stove. Last night I was baking two potatoes in the microwave. I noticed that the microwave sounded "louder" than normal. After about 13...
No! But it will need to be repaired. Did you wrap the potatoes in tin foil? The reason for the smoke needs to be found and repaired. Smoking means a short or a part shorted, failed, or wires touching another wire that did not blow any fuss.That is not good.
Trained technicians can help the mfg improve their products if they find the problem and report it to the Mfg.
LOL
Jan 28, 2011 | Amana MVH210W Microwave Oven
Frigidaire Over-the-Range Microwave Logo
199 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
