I have a Canon Multipass 390 which has an error message waste ink near full. Can I replace or clean this myself. I can order the part but Canon won't give instructions.
  • 4 more comments
  • info73677 Jan 31, 2010
    Thank you, how can I easily get to the ink pad to clean it?
    Hello again, what do you recommed to use to clean it?
    Thanks, Paula
    Hello again, I can see them but I don't want to damage them trying to get them out. They are behind a cover and although I can reach them, I am unable to see how they come out.
    Thank you,
    Do you know how they come out? Do they snap in? Is there a side I should pull up from? Is there a way to get closer to them so I can see how they come out?
    I took out and cleaned the pad, now I am trying to follow your initial instructions on how to reset the machine and the power will not come on with the Stop/Reset button pushed. This is line 1 of your instructions. I feel I am almost there...
  • info73677 Feb 01, 2010
    Wow, that one worked. You are really fast at responding. I started to worry but that last one did it. The only thing that differed from what happened is that it did not restart on it's own. When we started it again the error was about ink...yea!!! We tried the copier and it worked GREAT!!!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described you’ll need to clean the Ink Pads out first that are located inside the printer on far right where the print head rests.After this is done you need to reset the printer by following:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jan 31, 2010
  • 2 more comments
  • Rylee Smith
    Rylee Smith Jan 31, 2010
    Thanks for your reply Paula. To get to the pads you'll need to open the front cover of the unit and they are located inside the printer on far right where the print head rests. Once the print heads are out just wash them with hot water and dont place them back till the time they dry out. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    You can then just take them out and replace them, or else the other way would be buy a new printer which I hope you wont want. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    Just pull them out so that they can come out.
  • Rylee Smith
    Thanks for your reply Paula. Kindly refer to these instructions instead of the old one:
    1)With the Printer on, press Additional Functions, Scan, Copy, Scan
    Now you should be in service mode from there for waste ink tank reset
    2)Select Test mode which is like the last avalabe selection
    3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other option this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button
    The menu will now say EEPRON Clear
    Select Ink count which is option (0) and press set
    Then press Stop/Reset Followed by the power button and then wait for it to restart. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
I have a Canonmp390 printer & a message keeps
Error "Waste Ink Near Full"
Cause : The waste ink tank (which holds the ink used for print head cleaning) is nearly full.
Action : Contact the Canon Customer Care - Center.
Have a good day.
Dec 03, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Stopped printing after 'waste ink full message' how to I fix it.
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 20, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Message "wasted ink tank near full" on Canon Multipass F80
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
May 17, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Where is a waste ink i have error message says WASTE INK NEAR FULL help me on that, thanks
I have had this problem. There is a counter in your printer that must be reset to move on. The ink tank may not be full, but the counter estimates it is full (and maybe it is an instruction to you to buy a new Canon printer), and to actually empty the ink tank would be an uneconomical task. How do you do it, there are a number of helpers here so Google: MP730 waste ink near full.
Apr 27, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Waste ink near full error
Canon's a little shady when it comes to this, since any waste ink pad I've seen never has been more than 30-40% full. You can reset that status without cleaning the waste ink out and the printer should return to normal.
1) On the printer, press Additional Functions, Scan, Copy, Scan. This will put you in service mode.
2) Select Test mode at the bottom
3) Select #8 Printer Test, wait for more options. It should say 8-2 or 8-3; push the + or - button until it says 8-3 then hit Select. The menu will now say EEPRON Clear
4) Select Ink count which is option (0) and press set
5) Press Stop/Reset, then the power button and wait for it to restart.
I hope this helps!
Apr 15, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Canon multipass mp730 / waste ink near full
Ok try using the codes
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you need to clean out the waste ink it inside the printer go to open up all.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 30, 2009 | Canon MultiPASS MP700 All-In-One InkJet...
Error waste ink tank near full
This page gave me a solution, try it.
Let me know if worked for you as for me scoring this solution. Thanks
Jan 30, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Canon MultiPass F60 "Waste ink near full"
Okay, follow these steps below to reset this message:
1) Enter SERVICE MODE. By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Then call Canon 1-800-828-4040
Just inform them that you have already reset the counter so the error is gone, but you needed to know if there is a part that needs cleaned or replaced to prevent further problems.
Jan 19, 2009 | Canon MultiPASS F60 All-In-One InkJet...
Waste ink near full message
Take paper towels and absorb the excess ink. Make sure that the electricial contact  that tell it is full are clean.
Dec 27, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Used ink tank full
I have a error message on my Canon Multipass 390, used ink tank full.
Where the heck is the used ink tank?
Jul 13, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Computers & Internet Logo
David Payne
David Payne
