Question about Sony KP-57WV700 57" Rear Projection HDTV
I bought a used samsung HDTV model#PCL5415R 56in manufactured may, 2001. everything is fine except color is reddish and i am not able to adjust what now
  • michaelspigh Feb 01, 2010
    thank you,
    just so i am clear, does your solution suggest that it will clear the color clarity. i am so use to up to date tv, will i ever get a clear picture with rear projection
    President:
  • 2,923 Answers
This is a Convergence issue. Replace the convergence board and it should work fine. The part number of the convergence board for Samsung HDTV PCL5415R is BP94-00383A.
It would be best to contact the manufacturer for the availability of the part or you may also ask for second opinion.
Good luck and have a great day ahead!
Posted on Feb 01, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and check power resistor for leakage, if values are not exact you have to replace them. The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jan 31, 2010
  • Rylee Smith
    Rylee Smith Feb 01, 2010
    Yup, changing the convergence ICs will clear the picture. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
ELMO Visual Presenter (Model EV-2000AF) does NOT display COLOR properly onto HDTV monitor. (Appears Bluish or Reddish w/ 2 Composite Cables connected)
Those jacks you are plugging into on the HDTV are not composite inputs. They are component. The reason the color is not right is, you have to have a Red, Green and Blue connection.
The black and white picture from the 1 cable is because you are using a composite signal into a component green.
Big difference between a composite and a component signal. I hope this helps.
Apr 10, 2012 | Televison & Video
Numerous white spots on my samsung dlp 56in HDTV
DMd Moduel may have bad IC causing this ,but it could also be the optics unit block /Light Engine.
Samsung Parts 1-800-627-4368
PTS rebuilts boards and Parts and Light Engines 1-800-844-7871
Jun 20, 2011 | Samsung DLP HL-P4663W 46" Rear Projection...
Bad color scheme - cannot adjust enough
If you haven't already done so, it may be that all you need to do is adjust the convergence after moving the set. You should find convergence and its adjustments in the setup menu
Feb 25, 2009 | Samsung HC-P4741W 47" Rear Projection...
Samsung series 5 500lcd tv just black & white colors.
thanks for rapid comm.resolved issue .stb is a old version ,does not support hdtv ,changed to a newer version,everything worked fine.once again thank u
Nov 29, 2008 | Samsung LCD PREVIEW MONITOR f/950 AND...
What do I need to get for viewing HDTV
The TV you have will only process an HD via the component video connections. Your cable box needs to have component outputs and you will need to buy a component video cable to connect from the cable box component video outputs to the TV's component video inputs (should be 2 sets, #1 for up to 720p and #2 for up to 1080i...
Oct 28, 2008 | Samsung PCL5415R TV
Samsung model number PCL5415R The blue bulb is weak. where can i get one and can I replace it it is a 52inch projection HDTV ready
You may also have a problem with the convergence. There are three color cans that project the image on the screen. A red one, green one and a blue one. The blue one is the one that you should try and adjust. Have you tried to realign the convergence yet? You should be able to go into the menu setting and locate this option is is typically done using the remote. What you will see is some cross marks starting in the center and move to the four coners. When you adjust it you will want to align all three (red, green and blue) crosses where neither color is more prevalent. If you are unable to get the blue can to align with the others, there is a problem with the convergence board. These boards or ICs can be replaced, if you have a repairman fix it your looking at around $250 - $400. If you would like to fix it yourself you can get the parts from...
http://nfm.partsearch.com/Model/Samsung/Samsung/PCL5415R.aspx
NOTE: "Most of the text above was gathered from another online source"
Aug 28, 2008 | Televison & Video
Sony KDS-R50XBR1 9 red blinks
Isn't that the idicator telling you that its time to change the dlp lamp?
Jun 28, 2008 | Sony KDS-R50XBR1 50" HDTV
Samsung 52 in. projection TV
Is there any way that you can take a pic of what the screen looks like and post it here or send it to me at slinteriors@yahoo.com I could make a more accurate assesment if you can.
May 03, 2008 | Samsung PCL5415R TV
Double Vision
My Dad had a Hitachi rear projection with same problem blue and red were fine green was out of allignment and could not fix. Problem was the acual projector inside TV the cost for repair was more than TV was worth went out bought plasma.
Jan 07, 2008 | Samsung PCL5415R TV
Sony KP-57WV700 57" Rear Projection HDTV Logo
42 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
